luVWagn Samba Member
Joined: February 21, 2008 Posts: 1340 Location: Snoqualmie (WA)
Posted: Fri May 03, 2013 7:11 pm Post subject: |
IrideWheelies wrote: |
They are. If you want to know more read the odyssey technical manual: http://www.odysseybattery.com/documents/US-ODY-TM-001_0411_000.pdf
Also look at the warranty from Sears. 4-year free replacement and 100 month pro-rated. You can't beat it.
Don't just take my word for it. Google die hard platinum and odyssey battery and you'll find that they're very well regarded in commercial and automotive enthusiast cultures. |
My concern was that you can never be 100% sure that a DieHard is an Odyssey (if Sears ever changes their supplier), and this thread mostly had P-2 specs in it so far.
That said, my concerns are alleviated, because I took your advice and read this page:
http://www.sears.com/diehard-platinum-automotive-battery-group-size-65-price/p-02850065000P, where the battery is stated as "Deep Cycle" (if you can believe them).
I'm still curious why BillM installed his with posts up (resulting in mods to the battery cover) _________________ '91 Syncro 16 Reimo Hightop Conversion, eTDI |
IrideWheelies Samba Member
Joined: July 09, 2009 Posts: 386 Location: Olympia, WA
Posted: Fri May 03, 2013 7:15 pm Post subject: |
I think the swivel base interferes with side mounting. Also, the existing battery cables might not reach when side mounting.
Go get one and give it a shot. Take pics and report back. It's Sears so you can probably return it if you're not happy. _________________ 89' Dove Blue Syncro Hightop |
Posted: Fri May 03, 2013 7:34 pm Post subject: |
Go get one and give it a shot. Take pics and report back. It's Sears so you can probably return it if you're not happy. |
Will probably do so next summer. I'm not on-hand at the moment, and am having my mechanic just put in something cheap and easy initially to keep my stereo/lights working on aux. If I was there, I'd probably prefer to just find two matched batteries that'll fit and do things that way.
I'll replace the cheapie with a dual-batt install next summer, probably around the same time as solar and 12V fridge :p _________________ '91 Syncro 16 Reimo Hightop Conversion, eTDI |
jasknucklehead Samba Member
Posted: Thu Jun 13, 2013 7:56 pm Post subject: Install into 1987 Westy of the Sears Platinum P2 |
Thanks for all the input. I went this way too.
Have the P2 under the driver seat, no issues with rotating the seat and the battery door closes just fine.
1987 GL Westfalia "Molly"
Here are is a weblink with pictures of the install:
http://www.jasinclair.com/molly/house_bat/ |
BillM Samba Member
Joined: June 18, 2004 Posts: 1381 Location: Stonington,CT
Posted: Fri Jun 14, 2013 3:07 am Post subject: |
luVWagn wrote: |
I'm still curious why BillM installed his with posts up (resulting in mods to the battery cover) |
I have locking RMW storage drawers installed in the front of both seat
pedestals. It is in the way when trying to lay the battery down. It
was easier to notch to battery door then try to modify the storage
drawer. With the carpet down its hardly noticeable. The storage
drawes are great for locking my guns,wallets,medications,etc
up when camping.
I plan to do a little work on my dc electrics soon. Want to install
a switch panel. That way I can just flip a switch to turn off the USB
outlets,night lite in poptop,fridge, and one to control the yandina.
Pulling fuses has gotten old and I really don't want to wear out
their position in my aux fuse box.
I am also considering how,where,and with what , some sort of
shut off between batteries and alternator. I would like to fuse
the entire system at both batteries. I worry about electrical
issues and fire as lots of modification have been done to my Westy.
I am also considering what I should replace the Promariner Marine
charger with. It's a few years old (I got it before GoWesty) started
selling them. I want something that will charge both batteries and
tolerate supplying 12v to run lights etc when batteries are low.
Last is wondering if I replacing my main battery with an
AGM battery instead of the Lead battery will simplify my charging
needs.
Perhaps a schematic will make things easier for all of us. I will make
one and post it up today. _________________ Bill M
87 Westy |
peet1 Samba Member
Joined: June 29, 2012 Posts: 51 Location: Missoula, MT
Posted: Wed Jul 24, 2013 6:20 pm Post subject: Re: Install into 1987 Westy of the Sears Platinum P2 |
jasknucklehead wrote: |
I'm surprised to see this in a van with swivel seats. I picked up a P2 for my 1984 full camper and there was no way that I could have fit it on its side without trimming big chunks of the swivel plate.
Peet |
syncroid Samba Member
Posted: Wed Jul 24, 2013 6:39 pm Post subject: Re: Install into 1987 Westy of the Sears Platinum P2 |
jasknucklehead, What was the "minimal adapting" to the compartment that you had do.
Thanks for posting this. |
Wanderingman Samba Member
Joined: May 30, 2013 Posts: 22 Location: Nomadic, but currently Georgia
Posted: Wed Jul 31, 2013 5:14 pm Post subject: |
I really like this set up too. It appears the minimal mods were moving the relay under the swivel seat area and cutting off small sections of either end of the battery hold-down.
What I want to know is specifically where is the relay mounted and how did you get the isolator, etc. mounted under the swivel base, as it appears they are screwed down from the top? _________________ '87 Westy, 2.1L Stock Engine, 4-Speed Manual |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17110 Location: Retired South Florida
Posted: Thu Aug 01, 2013 7:24 am Post subject: Re: Install into 1987 Westy of the Sears Platinum P2 |
peet1 wrote: |
Peet |
Peet, I think there are two versions of the swivel seat. Early and late. My 82 it barely fit the UB batteries. I have since removed the swivel for more head and leg room and that really opens up the battery box area. What is the available amps on this battery? Also is it a deep cycle type? _________________ ☮️ |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9603 Location: Western WA
Posted: Sat Aug 10, 2013 1:17 pm Post subject: |
This seems like a good battery. Any problems with this Diehard P2?
Thx!!!
Repeating some P2 info here for those whose eyes are bleeding:
Group 65 DieHard P2
http://www.sears.com/shc/s/p_10153_12605_02850065000P?prdNo=4&blockNo=4&blockType=G4
- Fits laid on its side in some battery boxes (newer vanagons?) if you move the relays out of the battery box
- 75 Ah capacity
- AGM Absorbed Glass Mat construction
- ~$229 cost
- Sears calls it a "deep cycle battery"
A post above (pg 4) of this thread has some great pics showing installation ( http://www.thesamba.com/vw/forum/viewtopic.php?p=6709847#6709847 ) _________________
....KTMs, GasGas, SPOT mtb |
big swifty Samba Member
Joined: August 21, 2007 Posts: 246 Location: Formally in Republic of VT; now in Hollywood, FL
Posted: Sun Aug 18, 2013 5:44 pm Post subject: |
I just purchased and installed this battery vertically. Pursuant to the above cited post and IMHO more elegant solution photodocumented by jasknucklehead, I will be breaking out my angle grinder and laying that bad boy on its side. That is the extent of modifications I am willing to perform on my DS battery box.
Pics to follow. _________________ Evan
1987 Vanagon Syncro // Westfalia pop-top graft // Factory new ALH. 11mm IP. AFN 110 RC 2,3,4 // S7 turbo// Titan P502's
2013 Golf 4d TDI. No mods. Yet.
[1991 Jetta coupe TD. Giles Superpump. Custom tall 5 speed. SOLD |
slo356 Samba Member
Joined: February 18, 2002 Posts: 365 Location: Central Calif Coast
Posted: Mon Mar 03, 2014 7:45 am Post subject: |
SEARS has their $229.99 PLATINUM series batteries on sale today only for $183.99. Online purchase, pickup in store.
Best deal I have found on Odyssey Grp 65 is $247, but they do have a 60 month warranty, Sears version is 48 months. _________________ '65 T1 Sedan
'87 T3 Syncro |
Sodo Samba Member
Posted: Mon Mar 03, 2014 8:37 am Post subject: |
slo356 wrote: |
SEARS has their $229.99 PLATINUM series batteries on sale today only for $183.99. Online purchase, pickup in store. |
Search on Sears website does not return a listing of this battery. Tried stuff like: Diehard 65 battery & Diehard platinum
They do have the "Diehard advanced GOLD 65", but the "Dihard advanced PLATINUM 65" has disappeared. _________________
slo356 Samba Member
Posted: Mon Mar 03, 2014 9:08 am Post subject: |
It should work unless it restricted by state for some corporate reason.
Give this link a TRY: http://www.sears.com/search=car%20battery%20prices..._Batteries
If that doesn't work: go to Sears Automotive > then to auto battery > then check 48 month. It should show you Groups, 65, 35 and 34/78 in the Platinum series. _________________ '65 T1 Sedan
'87 T3 Syncro |
DeadSetMonkey Samba Member
Joined: April 15, 2010 Posts: 532 Location: Denver, CO
Posted: Tue Mar 04, 2014 12:33 pm Post subject: |
slo356 wrote: |
If that doesn't work: go to Sears Automotive > then to auto battery > then check 48 month. It should show you Groups, 65, 35 and 34/78 in the Platinum series. |
you snooze, you lose.
price up $20 since slo365's post.
shoulda bought mine yesterday! _________________ ----------------------------------------------------
'90 Syncro Westy 2.5Subi Turbo, BFGs 215/75/15 Rheins |
Posted: Tue Mar 04, 2014 1:00 pm Post subject: |
interesting to see if this could fit in the battery box, with the P2 or Odyssey
http://www.4wheelparts.com/Electrical/Odyssey-PC-1...7AodCTgANg
would require post to stick up, it would seem.
it's already pretty snug in there, but just an idea.
probably not for those wanting the battery on its side. _________________ ----------------------------------------------------
Posted: Thu Mar 13, 2014 12:09 pm Post subject: |
Sodo Samba Member
Posted: Thu Mar 13, 2014 12:53 pm Post subject: |
Deadset, you RULE!
Just ordered a Diehard Platinum Group 65 deep cycle battery (for pickup at a nearby Sears Auto center). It was $229-$46 = $183 (+tx) _________________
Posted: Thu Mar 13, 2014 1:03 pm Post subject: |
Will this battery also fit under the passenger seat? _________________ ----------------------------------------------------
Sodo Samba Member
Posted: Thu Mar 13, 2014 1:27 pm Post subject: |
DeadSetMonkey wrote: |
Will this battery also fit under the passenger seat? |
I am not the expert on this battery. I don't know the answer to your question. But to fit it under the driver seat (as a house battery) you have to cut off the terminals and lay it on its side.
Cutting off the terminals is (probably) OK for a house battery but not advisable for a starter battery. _________________
