2110 with stock 1600 exhaust.
Forum Index -> Performance - Engines/Transmissions Share: Facebook Twitter
Tinsnips
Tinsnips is offline
PostPosted: Wed Apr 25, 2012 3:30 am    Post subject: 2110 with stock 1600 exhaust. Reply with quote
For a sleeper appearence.
How bad would it supress performance? Say if it had 125 HP at the crank with a tuned exhaust, what would the stock 1600 exhaust knock it down to?
Opinions welcome, and if anyone with any type of hot engine has done this, I'd like to know what the results are.
bugguy076
bugguy076 is offline
PostPosted: Wed Apr 25, 2012 3:53 am    Post subject: Reply with quote
It's not going to work.
yamaducci
yamaducci is offline
PostPosted: Wed Apr 25, 2012 3:57 am    Post subject: Reply with quote
The exhaust would self limit your performance in terms of max RPM and power output. To what degree; that would have to be tested.
If I were to guess I would think it would limit to about 75-80 HP; Tops.
Your next concern will be overheating the heads and exhaust valves; as well as your MPG would be terrible.
Take a look at http://store.vintagespeed.com.tw/index.php?option=...;Itemid=80
If you want a performance engine with stock'ish appearance.
-John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
Cox Racing Engines
Class 5-1600's; Stock 1600 to 2498cc Type 1's. Custom Built for you in Maryland
billy270
billy270 is offline
PostPosted: Wed Apr 25, 2012 6:16 am    Post subject: Reply with quote
My car ran like a raped ape then i put heater boxes on now like a turtl in the fast lane. my motor is a 1600 with a cam and dual carbs.. not that big but i just orderd j tubes for sunmer
twomonkeysayoyo
twomonkeysayoyo is offline
PostPosted: Wed Apr 25, 2012 8:16 am    Post subject: Reply with quote
Forgive my ignorance, but I would think that the head sizes would matter more to the problems a stock exhaust would cause than the motor size. Obviously you want an exhaust that works with your system but as far as over heating goes if you run a stock head on that 2110 it's not going to be the problem running 42mm heads is going to give you. Is that completely off base?
Looks like trouble.
ALB
ALB is offline
PostPosted: Wed Apr 25, 2012 8:38 am    Post subject: Reply with quote
You're right; to be making 125hp in any motor (large or small) will take more than stock heads, which requires the right intake, and to get it all out takes the right exhaust. Putting a stock exhaust on any motor making 125hp will choke the thing and make it run hot because what's happening in the combustion chamber can't get out fast enough.
On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!!
Slalombuggy- Now I understand my trust issues...
Patrickvw
Patrickvw is offline
PostPosted: Wed Apr 25, 2012 8:50 am    Post subject: Reply with quote
I have a result. I was experimenting with different exaust systems I have. I once had a relativaly stock 1600cc dual port engine. I put on a GT4 tip sports exaust just for the looks. http://www.cip1.ca/ProductDetails.asp?ProductCode=ACC%2DD%2D2070
Then went with the 2 tip header exaust http://www.cip1.ca/ProductDetails.asp?ProductCode=ACC%2D35067
This one worked awsome on the 1600cc.
Then last year I built a 2161cc (steve timms stg2, dual dellorto 40's, 120 cam etc. I have a 1 5/8 ceramic merged header with magna flow muffler. Just for fun I tried the GT 4 tip exaust on it. this motor ran horrible. would only rev to about 4500rpm. I couldn't even spin the tires. you could feel the restriction with this exaust. (keep in mind I can rev this motor to 7000rpm with other exaust on it) Don't waist time trying this, It was 30 mins. of my life waisted I can't get back. Also keep in mind that the stock exhaust on stock motors are even a big restriction.
I would also like to add. beetles look like sleepers anyways. at least in my town. A lot of people pull up next to me and laugh because its loud and I have a different looking exhaust than normal. then when the light turns green im shifting into 2nd and doing 110kmh before they are even through the intersection. Who's laughin now! im canadian, I speak in kmh.
twomonkeysayoyo
PostPosted: Wed Apr 25, 2012 9:47 am    Post subject: Reply with quote
You must have 66" rear wheels! (167cm for the lame). Laughing
Looks like trouble.
Tinsnips
Tinsnips is offline
PostPosted: Wed Apr 25, 2012 10:19 am    Post subject: Reply with quote
Message received. I'll never entertain this thought again. Especialy what with the heat problem. Egads.
Tip of the hat to Patrick for the real world example.
bugnut68
bugnut68 is offline
PostPosted: Wed Apr 25, 2012 2:31 pm    Post subject: Reply with quote
Defined "raped ape." Laughing
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
Reply to topic    Forum Index -> Performance - Engines/Transmissions All times are Mountain Standard Time/Pacific Daylight Savings Time
