Robertjm Samba Member
Joined: May 22, 2011 Posts: 254 Location: San Francisco Bay Area
Posted: Thu Apr 19, 2012 10:09 am Post subject: frozen screw for removing lock cylinder in cargo door handle |
Hi all,
Been away from a bit. Anyways, I went to a local locksmith who said they can rekey my cargo door handle. Unfortunately, the micro screw you need to remove to get to the cylinder seems to be frozen, and they won't want to risk breaking the head off.
So far, I've sprayed a generous amount of PBBlaster on the screw each day for four days now. However, it looks like the screw is still not moving, and the only thing I've managed to accomplish is perhaps munging up the screw head. It's so small, it's really hard to tell.
Does anyone have any suggestions on getting this screw unstuck?
Thanks!!
Robert _________________ 1967 VW Double Cab Pickup
1995 Saab 900SE Turbo Convertible
1972 VW Squareback (Autobahn in the Sky) |
EverettB  Administrator
Joined: April 11, 2000 Posts: 42216 Location: Phoenix, AZ
Posted: Thu Apr 19, 2012 10:37 am Post subject: |
I haven't had this trouble with a handle but I recently had this problem with the screw on a wiper base. It's a little larger.
First I did what you did - I sprayed it with PB Blaster for 3-4 days, tapping with the screw driver handle from time to time.
(I think it says to do this on the can)
That didn't do anything so I took a small junk screw driver I had and filed/ground it down so it was a perfect fit in the slot.
Then I alternated trying to tighten and loosen it and it came loose.
Whenever I tried to turn it I had it in my vice so it could not move. I clamp a pair of vice grips on the screwdriver handle so I can push down with one hand with some force while turning the screwdriver via the vice grips with the other hand. _________________ How to: Post Photos | Search
Everett Barnes - [email protected] | My VWs | My wanted ads
"Water is the only drink for a wise man" | "Communication prevents complaints" |
Posted: Thu Apr 19, 2012 11:48 am Post subject: |
Good ideas! I'll try it after I've had a chance to get some padding for the vice so I don't mar up the chrome on the handle.
Robert
| EverettB wrote: |
Whenever I tried to turn it I had it in my vice so it could not move. I clamp a pair of vice grips on the screwdriver handle so I can push down with one hand with some force while turning the screwdriver via the vice grips with the other hand. |
2Pack  Samba Member
Joined: September 20, 2005 Posts: 634 Location: Virginia
Posted: Thu Apr 19, 2012 1:05 pm Post subject: |
I've had a couple where someone punched an indent in the metal right next to the screw, presumably to make the screw unremovable. _________________ Please buy my Treasure |
Posted: Thu Apr 19, 2012 1:42 pm Post subject: |
Now that's a charming thought. I'm assuming it was a pretty obvious dent?
| 2Pack wrote: |
| I've had a couple where someone punched an indent in the metal right next to the screw, presumably to make the screw unremovable. |
2Pack  Samba Member
Posted: Thu Apr 19, 2012 1:47 pm Post subject: |
Yeah I don't know why you would do that?
The dent was small (about 1/32" in diameter) but definitely noticeable and right in the region around the screw. _________________ Please buy my Treasure |
Posted: Thu Apr 19, 2012 7:22 pm Post subject: |
| Robertjm wrote: |
Yes, I use a towel inside the vice to protect the part when I do this.
| EverettB wrote: |
That didn't do anything so I took a small junk screw driver I had and filed/ground it down so it was a perfect fit in the slot. |
I retract that - I bet the PB Blaster helped but my tiny screw driver was slipping out until I "made" one from a bigger screw driver. The slot still got a little messed up.
On this same subject, I do the same for the small pop-out window screws - I use a nice, clean screw driver that fits the slot perfectly. _________________ How to: Post Photos | Search
rustyfastback Samba Member
Posted: Thu Apr 19, 2012 8:34 pm Post subject: |
| Use a propane torch. Not much heat is needed, too much may damage the handle. After the heat spray some pb blaster. I have used this method several times & it has always worked. |
Posted: Fri Apr 20, 2012 8:49 am Post subject: |
Unfortunately, the screw head looks pretty messed up when I held it under a photographer's Loop.
If it's to the point where it cannot be removed is it possible, though I know not very desirable, to drill out the top of the micro screw so I can get the cylinder out? Of course the next problem would be to get the screw shaft out after the cylinder has been removed from the handle.
Wouldn't that wreak havoc on the chrome?
| rustyfastback wrote: |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 6381 Location: Casa de Oro, California
Posted: Fri Apr 20, 2012 9:37 am Post subject: |
| If you really want to save that handle and lock and not buy another and have that new lock re-keyed then take it to a clock repair shop. They will extract the screw. You could save your original lock by cutting away the entire cross section of the set screw down to the lock with a thin cutoff wheel. |
DubStyle SBS Hit Squad
Joined: July 26, 2003 Posts: 5464 Location: SBS headquarters: SoDak
Posted: Thu Jul 12, 2012 10:21 pm Post subject: |
Try some heat on the area around the screw hole. _________________ Anthony
SBS #1
"The original & best lowered Split Bus website/club" |
Posted: Fri Jul 13, 2012 8:30 am Post subject: |
Thanks DubStyle. I ended up sending if off to a VW locksmith to deal with since I was going to have it rekeyed anyways.
Later,
Robert
| DubStyle wrote: |
| Try some heat on the area around the screw hole. |
Posted: Fri Jul 13, 2012 9:55 am Post subject: |
Let me know how much he charges you to remove the screw. _________________ Anthony
SBS #1
Posted: Fri Jul 13, 2012 10:12 am Post subject: |
$35 for drilling out the screw and replacing it with a pin. And he also rekeyed the tumbler.
I used Justin, who is up in Pennsylvania. He's had good, as well as some bad, reviews here. But, I didn't have any issues. He's a professional locksmith so you have to take that into account.
Later,
Robert
| DubStyle wrote: |
| Let me know how much he charges you to remove the screw. |
