SGKent Samba Member
Posted: Fri Apr 20, 2012 8:00 pm Post subject: |
VWGirl wrote: |
ddesh wrote: |
Thats the missing bolt that holds the whole westy together |
I'll throw it back on top of the engine for good measure then.. really it had like axle grease on it.. random |
sounds silly but post a photo of it next to something of known size like a quarter etc. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
weez Samba Member
Joined: June 27, 2010 Posts: 2 Location: Flagstaff, AZ
Posted: Fri Apr 20, 2012 8:19 pm Post subject: |
just my two cents... only because batteries are my business...
if it's not cranking only when it's cold, then it's a battery that's going bad. every battery has a consumer date code on it somewhere. depending on who makes it, the code could be different too. so look for something like C4 (which could be from march of 2004). an average battery will last 5-7 yrs. heat is the #1 killer and will shorten the life even more... hope that helps... |
Posted: Fri Apr 20, 2012 9:19 pm Post subject: |
If your ignition system is getting weak, it will be hard to get a good spark when the battery voltage is low. The ECU also needs sufficient voltage to work well.
Check that your points are in good condition and properly adjusted.
How old is your coil? Have you checked it according to the book? Even if it checks out good if you aren't getting a spark when cold, the coil would be suspect.
Check and if necessary clean all your FI connections, pay special attention to the grounds.
Check the resistance of the TTS to ground when the engine is cold. One terminal should read a few ohms of resistance and the other should be close ~0 ohms.. |
VWGirl Samba Member
Joined: June 03, 2003 Posts: 2462 Location: Powder Springs, GA
Posted: Sat Apr 21, 2012 2:02 am Post subject: |
Battery is for sure less than two years old. At oldest it would be July 10, sorry I forgot to check it. I'll get a pic of the bolt but won't be able to post it til I get back Sunday. Coil is also less than two years old. I haven't tested it in quite a while.
Will know in an hour if its the battery connection... Here goes nothin... _________________ Without love in the dream it will never come true |
VWGirl Samba Member
Posted: Sat Apr 21, 2012 3:03 am Post subject: |
Still some hesitation but its 60 and she started _________________ Without love in the dream it will never come true |
Islero Samba Member
Posted: Sat Apr 21, 2012 5:53 am Post subject: |
Check your battery with a voltage tester. Anything under 12.4 v is an obviously faulty battery. |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Sat Apr 21, 2012 1:38 pm Post subject: |
Collie wrote: |
Speaking of "Ladies that own Bays".....
Sunshine, did you see that thread? |
i was thinking that as soon as i saw the username...lol _________________ Stuart Zickefoose
206-841-7324
[email protected]
Last edited by Stuartzickefoose on Sat Apr 21, 2012 1:38 pm; edited 1 time in total |
VWGirl Samba Member
Posted: Sat Apr 21, 2012 2:09 pm Post subject: |
Stuartzickefoose wrote: |
Collie wrote: |
i was thinking that as soon as i saw the username...lol |
Was there a thread about this or something? Sorry, didn't search on my phone... _________________ Without love in the dream it will never come true |
Collie Samba Member
Joined: April 03, 2006 Posts: 1285 Location: Virginia
Posted: Sat Apr 21, 2012 2:30 pm Post subject: |
VWGirl wrote: |
Collie wrote: |
Was there a thread about this or something? Sorry, didn't search on my phone... |
In retrospect, I think I *may* have confused you with somebody else....a young lady from Kansas..... |
Posted: Sat Apr 21, 2012 5:12 pm Post subject: |
Collie wrote: |
VWGirl wrote: |
Collie wrote: |
http://www.thesamba.com/vw/forum/viewtopic.php?t=508449
206-841-7324
[email protected] |
Posted: Sat Apr 21, 2012 5:13 pm Post subject: |
on a side note, have you tested voltage at the battery, with the car running and not running? whats the voltage? _________________ Stuart Zickefoose
206-841-7324
[email protected] |
VWGirl Samba Member
Posted: Sat Apr 21, 2012 5:45 pm Post subject: |
I'm at a car show and don't think I packed my multimeter... Though I should llook cause I remember having my hands on it just prior to leaving. While I may be able to get whilst of one here, I would rather just wait til I get home tomorrow _________________ Without love in the dream it will never come true |
VWGirl Samba Member
Posted: Sat Apr 21, 2012 6:00 pm Post subject: |
As far as girls with bays go... I thought you all knew me by now. The old timers do I guess. I come and go. Sometimes I'm in the bay forum, other times its beetles or type 3s or vanagons. It just depends on what the flavor of the week is. I eliminated my cars in my Sig line long ago as I was told way back when that it was too long. I do all my work myself except paint and body, and I am two for two at getting screwed over with that, so I'm going to have to come up with some time somewhere to fit that in my schedule. _________________ Without love in the dream it will never come true |
Posted: Sat Apr 21, 2012 6:52 pm Post subject: |
cool!
....any pics of current bay(s)? _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Tcash Samba Member
Posted: Sat Apr 21, 2012 8:51 pm Post subject: |
Hi VW Girl, Memeber June 03,2003. That's neat, long time Member. Sounds like you may have a parasitic draw (something draining the battery) You need to give some battery voltage readings. Take a reading first thing when you park it for the night, record reading. In the morning take reading and record. If you have someone that can help. Take a reading in the morning while someone cranks the engine. Good Luck |
Posted: Sun Apr 22, 2012 7:50 am Post subject: |
Tcash wrote: |
if it was a parasitic draw, it would not start later in the day either, so i think that one can be ruled out, although, doing said test is not a bad way to find out where some of the problem is at. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
VWGirl Samba Member
Posted: Sun Apr 22, 2012 3:53 pm Post subject: |
well, bus started up this afternoon to drive home... not that it was cold, but she drives so nice I thought I would share. No trophies to be won, but she's still my bus and that's all that matters... idk why i didn't take more pics this weekend, always seems to be the case.
This is my bus next to my notch
Posted: Sun Apr 22, 2012 9:03 pm Post subject: |
AWESOME BUS! lets see some more pics _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Simbo Samba Member
Joined: February 25, 2013 Posts: 4 Location: Wirral, England
Posted: Mon Feb 25, 2013 2:49 pm Post subject: |
Hi VWGirl, just wondered if you had resolved your problem because I'm having the exact same trouble with my 1500 Beetle and have been for ages. If you've fixed it I'd love to know how. Thanks. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51131 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Feb 25, 2013 3:52 pm Post subject: |
Simbo wrote: |
Welcome, you do realise this thread is discussing a late bus with L-jetronic fuel injection, right? Unless your bug is injected it likely won't help much, apples VS: oranges.
Please describe the exact symptoms you are experiencing. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
