Not a morning bus anymore. cold start issues
Page: Previous  1, 2, 3, 4
airschooled
Air-Schooled
airschooled is offline
PostPosted: Thu Feb 28, 2013 8:53 am    Post subject: Reply with quote
Will your engine get going with a lively push start down a hill when it's cold?
Learn how your vintage VW works. And why it doesn't!
www.airschooled.com
nathansnathan
nathansnathan is offline
PostPosted: Thu Feb 28, 2013 6:15 pm    Post subject: Reply with quote
I've never tried doing that. I've seen them do this on Top Gear UK, and it doesn't look like something I would want to do. I thought about trying it in the parking ramp at my work, like practice, just in case.... Laughing
airschooled
Air-Schooled
PostPosted: Thu Feb 28, 2013 6:20 pm    Post subject: Reply with quote
Starter: turns the engine over by turning the flywheel.
Roll start: turns the engine over by turning the flywheel.
(I'm sure there's a flaw with this, as it can't be good for the clutch, but people here tell stories of living in San Francisco and going 8+ months without a starter.)
Make sure you're doing it in an appropriate gear. Anything more than 3 mph use 2nd gear. As soon as the engine catches get in in neutral. Same thing applies around town. Engine stall going 15? 3rd gear. Stall going 30? 4th gear. But get it into N then an appropriate gear asap.
www.airschooled.com
Wildthings
Wildthings is offline
PostPosted: Thu Feb 28, 2013 7:14 pm    Post subject: Reply with quote
Try and get your speed up above 5 mph, preferable up to 8 or 10 and then use third and let the clutch out gently. At 15 you can use 4th and you will have the engine spinning way faster than the starter could do it.
Gently is the key word here as you can really stress the drive line if you let the clutch out quickly especially in the lower gears. Even in third at 10 mph you may drag the rear wheels if you are on gravel or even smooth concrete.
CoastalAirCooledVW
CoastalAirCooledVW is offline
PostPosted: Thu Feb 28, 2013 7:53 pm    Post subject: Reply with quote
You have never done this? Shocked . I do it all the time because it is fun Laughing . Now that I have thought about it I might be damaging something Confused . I don't think I am because when I do it the bus starts just as smooth as when I turn the key without any lurching or slamming.
1966 Velvet Green Standard
nathansnathan
PostPosted: Thu Feb 28, 2013 10:56 pm    Post subject: Reply with quote
It's that part that makes me cringe. - You can get by without the starter, but the solenoid... the "human solenoid", "Get it out of gear real quick" Laughing
In Top Gear they seem to always do it in reverse gear. I was thinking the tallest gear would be best, but I am going to study these responses here just in case I do need to do this.
ncstagger
ncstagger is offline
PostPosted: Fri Mar 01, 2013 1:29 am    Post subject: Reply with quote
i made it through half of summer tour 91 with no battery... just push starting so its possible, not good for the drivetrain for sure but works in a pinch!
71 Westy Tintop - 1600 DP 34PICT3/009 - Pastel White
Resto thread here: http://www.thesamba.com/vw/forum/viewtopic.php?t=549162
"Take your most realistic time frame and dollar amount.. then add half of that amount. When you get that total... double it. Only then will you be in the ballpark." - sofaking
airschooled
Air-Schooled
PostPosted: Fri Mar 01, 2013 8:55 am    Post subject: Reply with quote
Let me clarify. You're not going to kill anything by doing this. The "get it out of low gear part" is so you don't roll start it in 4th gear at 20mph and them try to drive away. I retract my ASAP statement and substitute:
Make sure you don't continue to drive in your roll-start gear. Get it in to an appropriate gear to continue driving and all will be good.
www.airschooled.com
Simbo
Simbo is offline
PostPosted: Sun Mar 03, 2013 2:49 pm    Post subject: Reply with quote
Wasted youth/adulthood wrote:
Anyone ever found out what happend with the original theme of this thread? Did the slow starter/difficult start when cold problem get resolved Question What was the problem?
I think it's the starter motor bush that needs replacing. I'm going to attempt it when I'm off work next week. Smile Shocked
Never lose faith in the colour of the sky.
Page 4 of 4
