jsteele05 Samba Member
Posted: Fri Apr 20, 2012 8:07 pm Post subject: All rev and no go??? |
| I really don't know whats going on with my motor. Think its around a 2180 CC engine dual carbs magnaspark dizzy,everything seems to be dialed in near perfect, last week it overheated just a little when the belt snapped ever since the engine behaves the same as it ever did in neutral but going down the road its almost like im driving with the brakes on i don't know if my clutch could be slipping or what. lifted up each wheel today and rolled it to make sure nothing got caught up in the drums. then with tried it out in each gear to see if the clutch is still grabbing and it seems to be holding up well really confused. |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 8841 Location: No F*uck Vagina
Posted: Fri Apr 20, 2012 8:18 pm Post subject: |
Do a compression check, you may have stretched a valve. Also have a look at your valve lash, if it's changed from last tuneup it's time for new valves. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
| mark tucker wrote: | | make up your own##s.that way you will still sound like an exspert. |
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7557 Location: Whittier,CA
Posted: Fri Apr 20, 2012 8:23 pm Post subject: Re: All rev and no go??? |
| jsteele05 wrote: | | last week it overheated just a little when the belt snapped |
Define "just a little". Oil temps, head temps, oil pressure, how do they look now compared to before the belt broke? _________________
| Mitey62 wrote: | | Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on. |
| RockCrusher wrote: | JB weld the case halves....that'll keep the fretting to a minimum.  |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 55685 Location: Long Island, New York, USA
Posted: Sat Apr 21, 2012 4:21 am Post subject: Re: All rev and no go??? |
Is that like "just a little pregnant"?
2180 has 92mm cylinders, are they thick walls? _________________ Glenn
HBB/RW
www.DasVolks.com
Long Island's Aircooled Club |
mark tucker Samba Member
Joined: April 08, 2009 Posts: 8529 Location: SHALIMAR ,FLORIDA
Posted: Sat Apr 21, 2012 10:50 am Post subject: |
| i tried to get a woman a little pregnet one time,she got worse!!!. yes adjust the valves by all means do it, the heads are aluminum, and like all aluminum heads are prone to warpage when overheating& seats moving around,if it hasent droped a seat by now it should be fine, but the heads are cracked,but dont let that worry you too much they all do it(so I am told) you might need to also retorque the heads, but if thats needeed you probably need a set of rings too& a fine hone with a sunnen hone.I dont think it would hurt the valves .check for added blowby.and keep a spair belt & rench in the car!!!hmm I should probably do that too, but I dont have issues with my car... it has issues with me.good luck |
bugguy076 Samba Member
Joined: December 11, 2007 Posts: 500 Location: Dover, PA.
Posted: Sat Apr 21, 2012 4:01 pm Post subject: |
| I would make sure the fan is free. The belt broke for a reason. The bearings in the gen/alt may be getting tight. |
Posted: Sat Apr 21, 2012 4:44 pm Post subject: |
| bugguy076 wrote: | | I would make sure the fan is free. The belt broke for a reason. The bearings in the gen/alt may be getting tight. | or the hampster has died and stuck in the blades. |
Posted: Sat Apr 21, 2012 4:54 pm Post subject: |
| mark tucker wrote: | | or the hampster has died and stuck in the blades. | Now that's really sad.  _________________
