joemama Samba Member
Joined: February 09, 2006 Posts: 1636 Location: La Crescenta, California
Posted: Tue Apr 24, 2012 10:47 am Post subject: need info on converting to a pyramid bus trans, and 3 x 3 |
So on my swing axle buggy, I want to convert to a pyramid bus trans, and add 3 x 3 arms. I would like to keep the shifter in the tunnel. What do I need? I have a 2" lift, and my body is a very good clone of a Manx, including battery tray and spare tire indent. |
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6767 Location: Northern California
Posted: Tue Apr 24, 2012 1:30 pm Post subject: |
I think there are 3 basic options for keeping the shift rod in the tunnel.
One is to use a piece like this in place of the coupling. The piece comes up out of the tunnel.
The second option is to use 10 degree mounts to mount the transaxle/engine at an upward sloping angle. That's how Joe Sellars (jsturtlebuggy) has his 091 mounted in his Manxter
Third is to buy and have the Gene Berg intermediate-housing installed on the bus (002)transaxle
http://www.geneberg.com/cat.php?name=BUS%20600A%20and%20BUS%20600L%20Adapter&cPath=363
BTW, you didn't mention what kind/how powerful an engine you are going to use but short of a turbo'd 150hp+ engine, a professionally built/upgraded Type 1 transaxle should reliably handle it and shift better at the same time.
http://ranchotransaxles.com/vw-transaxles.html |
Posted: Wed Apr 25, 2012 7:50 am Post subject: |
Its not about being able to handle horsepower, but lower gear ratios for steep rocky trails. |
