csterl Samba Member
Posted: Sun Apr 22, 2012 6:26 pm Post subject: Add caster on 75 thing? |
| I have been working on the front suspension on a 75 (mexican) thing. All components with the exception of the ball joints were good. I replaced all 4 ball joints and, after alignment, it still pulls to the right. In talking to the alignment technician, he told me that both sides needed an additional 1 degree +/- caster and it was as close as he could get it with the cams on the upper joints. I know the joints have alignment slots on them; do the joints have an offset built into them and could the joints be reinstalled offsetting the slots to possibly gain a little camber? Is there any other way to add camber? Ride height appears to be at or just slightly below stock. |
Shadd Samba Member
Joined: January 18, 2007 Posts: 863 Location: Athens, Ohio
Posted: Sun Apr 22, 2012 6:49 pm Post subject: |
Hey csterl, welcome to the samba,
I believe that you can get some additional caster by adding shims between the beam and the lower mounting point on the frame head. (at least this is true for king/link pin beams) _________________ Athens Euroworks
Service - Repair - Parts
Specializing in VW/Audi/Porsche/BMW/Mercedes
11 Hudson ave. Athens, OH. 45701
(740) 707-6210 |
Posted: Sun Apr 22, 2012 10:38 pm Post subject: |
| Have been thinking that mine would steer a bit better with more caster as it tends to wander a bit. Anyone have a feel for what the maximum amount of shimming that can reasonably be added is? Don't have enough adjustment to get the camber to come into spec on one side, but can't see that anything is bent or made wrong. Any ideas here would be great as well. |
SilverThing  Samba Member
Joined: July 19, 2004 Posts: 633 Location: Boise/Seattle
Posted: Mon Apr 23, 2012 4:07 am Post subject: |
| Wildthings wrote: | | Have been thinking that mine would steer a bit better with more caster as it tends to wander a bit. Anyone have a feel for what the maximum amount of shimming that can reasonably be added is? Don't have enough adjustment to get the camber to come into spec on one side, but can't see that anything is bent or made wrong. Any ideas here would be great as well. |
You can check for bend pretty easily (well as quick and easy as removing all of the brake parts from the spindle is). The factory had a tool for checking for spindle bend, but also stated that it can be done with a straight edge and a caliper. You put the straight edge on the backing plate mounting surface of the spindle (hence why the brakes have to come completely off) and measure the distance from the spindle to the straight edge all the way around (just below the threads and at least three places). If the difference between all of the measurements varies more than 0.25mm, it needs to be replaced.
If you remove the tie rod at the same time, you can also check the steering arm for bend. Straight edge on the backing plate surface to the outer edge of the tie rod hole should be 117.75mm to 118.25mm. _________________ "I like how everyone likes talking about Zeke's Thing yet he's the only one that's ever seen it." - Katie
"I've seen pictures..." - Jeremy |
citroen Samba Member
Joined: February 28, 2010 Posts: 808 Location: louisville ky
Posted: Mon Apr 23, 2012 6:42 am Post subject: |
i think this will fix your problems they are from bugpack. Caster shims, longer bolts and camber adjusters. They fixed mine.
Posted: Mon Apr 23, 2012 7:19 am Post subject: |
I will have to check the spindles for straightness at some point, but would have thought the drum would rub against the backing plate if the spindle were bent much.
I have heard about eccentrics with more offset, but can Bug eccentrics be used on a Thing? I thought the Thing ball joints used larger studs. |
74 Thing Samba Member
Posted: Mon Apr 23, 2012 7:50 am Post subject: |
Those eccentrics will not fit a 181 ball joint.
Those caster shims will though-get a set and loosen the 4 front beam bolts and slide the two shims between the lower beam and the frame then retorque. |
drscope Samba Member
Joined: February 19, 2007 Posts: 13422 Location: Baltimore, Maryland USA
Posted: Mon Apr 23, 2012 8:11 am Post subject: |
I think you need to find a better front end alignment technician who doesn't belive close is good enough!
Probably one of the eccentrics is stuck and he can't get it to turn.
Why is this post in the split beetle forum? _________________ Mother Nature is a Mean Evil Bitch! |
Posted: Mon Apr 23, 2012 8:42 am Post subject: |
| drscope wrote: | I think you need to find a better front end alignment technician who doesn't belive close is good enough!
Probably one of the eccentrics is stuck and he can't get it to turn. |
Why would anyone use an "alignment technician" to align an ACVW front end? You just need a dead level piece of concrete to work on, a torpedo level and a tape measure. I can check my alignment and have it reset in less time than it would take me to drive to an alignment shop.
| Quote: | | Why is this post in the split beetle forum? |
Obviously someone's alignment is off
Posted: Mon Apr 23, 2012 3:02 pm Post subject: |
| Sorry i have a thing axle with bug arms and ball joint so the adjuster work on mine. Correct the caster shims will work on bug or things. |
Ian Epperson Samba Member
Joined: January 12, 2005 Posts: 2252 Location: Alameda, CA
Posted: Mon Apr 23, 2012 4:13 pm Post subject: |
I put a set of castor shims on my Thing a couple years back - I highly recommend them as it makes freeway driving much more stable.
For most other ball joint front ends, they're an easy install. However, for a Thing, you've got to either eliminate the side brackets for the front beam or oval out the holes to allow you to bolt them in place with the modified castor.
I removed the side brackets, installed the shims, loosely bolted in the side brackets for the holes that fit and used the new offset hole to mark the new shape of the bracket hole, removed the brackets, used my neighbor's mill to reshape the holes, reinstalled the brackets. _________________ VW-181 shirts and stickers.
http://ian.epperson.com/vw |
csterl Samba Member
Posted: Mon Apr 23, 2012 4:59 pm Post subject: |
Sorry, first post and am having a hard time getting anything it to post at all. Is there a button to respond somewhere I don't see?
Thanks for the responses. I will get a set of shims and see if it gets it to not pull. |
csterl Samba Member
Posted: Mon Apr 23, 2012 5:04 pm Post subject: |
| csterl wrote: | | drscope wrote: | I think you need to find a better front end alignment technician who doesn't belive close is good enough!
The eccentrics were loose, as I deliberately left them loose before taking it to the tech. He said it was as close as he could get it but not in spec. He's usually really good at even hard to align vehicles, but he is not familiar with ball joint vw's. No-one around here is. |
Posted: Mon Apr 23, 2012 5:06 pm Post subject: |
| Ian Epperson wrote: | I put a set of castor shims on my Thing a couple years back - I highly recommend them as it makes freeway driving much more stable.
I removed the side brackets, installed the shims, loosely bolted in the side brackets for the holes that fit and used the new offset hole to mark the new shape of the bracket hole, removed the brackets, used my neighbor's mill to reshape the holes, reinstalled the brackets. |
Thanks for the advice. Sounds like it is worth pursuing. Where your shims made from aluminium or where they steel. |
Posted: Wed May 02, 2012 12:19 am Post subject: |
| Ian Epperson wrote: | | Aluminum. | How much caster did your shim set add? Do you think the same, or more, or less would be better? |
Posted: Wed May 02, 2012 8:07 pm Post subject: |
| Wildthings wrote: | | Ian Epperson wrote: | | Aluminum. | How much caster did your shim set add? Do you think the same, or more, or less would be better? | I'm not exactly sure. More would, I think, require longer bolts. I don't think it needs any more than a single shim. Maybe I'd feel different if I were to go drag racing or lowering it. _________________ VW-181 shirts and stickers.
Posted: Thu May 03, 2012 11:15 am Post subject: |
| Just presuming that the shims are about 3/16 thick that would give just shy of 2° of extra caster. Since I want to replace the body mounts above the front axle assembly, I might as well add the shims at the same time. |
