billy270 Samba Member
Joined: April 28, 2010 Posts: 267 Location: radcliff/louisville ky
Posted: Mon Apr 23, 2012 7:50 am Post subject: want to lower the front of my 66 |
| Ok i know there is a lot about lowering and all that i have a stock 66 vw i just orderd cb disc for the frount and 2 1/2 drop spendals... i am running 185/65/15 on stock wheels will i run in to any issues |
60ragtop  Samba Member
Joined: March 13, 2006 Posts: 2454 Location: Big Wonderful Wy
Joey Samba Member
Joined: August 12, 2005 Posts: 3695 Location: Halifax, Nova Scotia, Canada
Posted: Mon Apr 23, 2012 8:56 am Post subject: |
I think you will need a narrowed beam. Dropped spindles alone adds 1/2" of track to each side. _________________ Joey
'56 Beetle
'65 Beetle
'74 Bus
'79 Panel
vintagevdubbers.ca |
Posted: Mon Apr 23, 2012 9:27 am Post subject: |
| I am wanting to narrow my beam 4" i like the acn adjusters but kinda high any good leads to some narrowed tierods with ends for a good price and also what all will i need to rebuild my bj beam |
slalombuggy Samba Member
Joined: July 17, 2010 Posts: 3723 Location: Canada 306
Posted: Mon Apr 23, 2012 11:19 am Post subject: |
Why don't you put on the dropped spindles and disk brakes and THEN see if you need a narrowed front beam. Chances are you won't. We've lowered cars for 25 years without narrowed beams.
brad _________________ BB Buggy 121.253mph @ Bonneville 2012
http://www.youtube.com/watch?v=57hMyJmIU10
Raisin cookies that look like chocolate chip cookies are the main reason I have trust issues |
Posted: Mon Apr 23, 2012 7:36 pm Post subject: |
| Well i deff would love to but it is the only car i have u know so if i put that on it has to be driveable what all do i need to rebuild a beam |
smitty24 Samba Member
Joined: April 28, 2008 Posts: 2186 Location: Salem, Oregon
Posted: Mon Apr 23, 2012 8:09 pm Post subject: |
I agree with Brad.
It is amazing what just tire change and spindles can do, alone! My last setup was pretty low to people here in Utah, funny thing was that 80% of the front drop was just spindles and small tires. I dont think you will need a narrow beam with 185/65 and just spindles. One of my setups last year was 175/65, a 2" beam, and 5" wheels. I barely rubbed on tight turns but that was due to the fact the beam was down more than the range of just spindles.
Another example= my old '67 had an adjustable beam (stock width) with 165/80 (taller than your current tires). The beam was literally 4" down. Tires rubbed on bad turns. The 2.5" a spindle drops, aint much. |
Posted: Tue Apr 24, 2012 1:18 pm Post subject: |
| well what is involved in a beam rebuild |
Posted: Tue Apr 24, 2012 3:04 pm Post subject: |
| removing beam, removing arms, rebuilding spindles if there is play, setting the steering geometry all back correctly when putting everything back together, new bushings or bearings. It is easier for me to just buy a new CB 2" beam compared to factory beams, especially since most of us run wider wheel/tire combos nowadays, along with discs/spindles etc. The CB are superior to anything else I have ever used. They have precise adjustment, exact tolerances, inner Delrin outer needle bearings. When you get one, you install the new leaves all greased up, then add new grease to zerks in beam. You setup your arms properly using a manual or two and shim the pins correctly, then adjust pins and grease spindles. You setup your brake system again, adjust brakes, wheel bearings, wheels back on and do some final toe stuff and you are done. Its a good weekend full of work if things go smooth. |
Dubbydubdub Samba Member
Posted: Tue Apr 24, 2012 3:31 pm Post subject: |
| billy270 wrote: | | well what is involved in a beam rebuild |
what do you want to rebuild? leaves? torsion arms? ball joints? ie. not too many components to the front beam.
As far as removing the beam, the important tools you'll need is a balljoint remover for the torsion/trailing arm balljoints and tierod ends. Other than that, most of the nuts are 17 and 19mm. beam itself is only held to the chasis by 6bolts. pretty simple job.
probably the most important tool for the job:
http://www.google.com/products/catalog?q=ball+join...LUBEPMCMAc |
Posted: Tue Apr 24, 2012 3:47 pm Post subject: |
| my bad...didnt realize it was ball joint! You want a good pickle fork and a shop to press the new joints in to the arms. I strongly recommend extra travel joints. The only guy I ever knew that rebuilt a stock beam had a real hell of a time locating new needle bearings. When he found some and had the old ones removed, the cost exceeded the cost of a new US built beam by far! As DDD said, the job isnt that bad. If the beam has never been off or rebuilt, it will take a bit longer. |
Posted: Tue Apr 24, 2012 4:03 pm Post subject: |
| Well where can i geet the barings.... what about bushuigs and all the inturnal stuff |
drscope Samba Member
Joined: February 19, 2007 Posts: 13426 Location: Baltimore, Maryland USA
Posted: Wed Apr 25, 2012 7:38 am Post subject: |
Billy, reading your posts, it obvious you don't know how the front suspension works or how it goes together.
Thats fine - we all had to start somewhere and we all started with NO knowledge.
BUT, do you really think it's a good idea to jump in and make major modifications like this if you don't understand how it is all supposed to work?
I'm suggesting you be a little more cautious and take your time before you start tearing into things. Learn about how and why it works before you try to make changes. And know what you want the results to be when those changes are done.
If you jump in with out that knowledge you can get into trouble really quick.
And since you mention that this is your only car, you run the risk of either having it out of commission for a really long time, having a very poor end result, or having to spend a lot of money to get it to someone who can finish it for you when you discover you are way over your head.
Doing it yourself does have it's rewards. But you need the knowledge, the skills and the tools to do the job. And if you don't have those things, this can get really expensive in many ways very quickly.
So I suggest you sit back and think about your abilities and the tools you have to work with.
Get a copy of Muier's "Idiot" book and read and learn about how the front end works. He explains things very well.
Then explore your other options.
You can get trailing arms with new ball joints already pressed in if you don't have a press. And you can also buy a beam in MANY different configurations from a bare beam to a fully assembled drum to drum or disc to disc set up.
All it takes is money! _________________ Mother Nature is a Mean Evil Bitch! |
Posted: Wed Apr 25, 2012 10:46 am Post subject: |
| I have all the tools needed for the job...and I understand how it works. I just never been in the beam. i dont know what to check are where to get parts if needed thanks for the concern ... |
Posted: Wed Apr 25, 2012 11:31 am Post subject: |
| billy270 wrote: | | I have all the tools needed for the job...and I understand how it works. I just never been in the beam. i dont know what to check are where to get parts if needed thanks for the concern ... |
All parts can be found in aircooled performance stores, all the way up to completely built beams. I gotta go with scope on this one, you can't even spell alot of the things you are referring to. I'm not trying to put you down but even someone like me who have a pretty good understanding of vw suspension get backed up months based on the lack of tools or something breaking. It's a lengthy process when one little thing go wrong. I.e. I couldn't get the tierod stud to stop spinning for the life of me. It can also get very costly.
But as car as all the components you need, no fear, you'll be able to find it all over. |
Posted: Wed Apr 25, 2012 12:18 pm Post subject: |
| well.. I do have a bit of experiance in this area just wanted to know where i can get barings if needed |
Posted: Wed Apr 25, 2012 12:46 pm Post subject: |
This place should have everything you need.
http://www2.cip1.com/
Good Luck! _________________ Mother Nature is a Mean Evil Bitch! |
Posted: Wed Apr 25, 2012 1:19 pm Post subject: |
| billy270 wrote: | | well.. I do have a bit of experiance in this area just wanted to know where i can get barings if needed |
seems like "barings" seem to be what you are concerned about. Please clarify what you mean, "bearings?" like wheel bearing? |
Posted: Wed Apr 25, 2012 1:51 pm Post subject: |
| I did not know i had to say what baring when i am talking about the beam the needle barings..not wheel barings are crank not even rod barings |
Posted: Wed Apr 25, 2012 3:46 pm Post subject: |
| Most people will not just sell you new bearings for your old OG beam. The ones I have seen are from a bearing house and NOT cheap; hence the reason why I said earlier a new CB setup might be more up your ally, especially if you might need a couple more inches of clearance in the future. I highly recommend their beams. |
