MNKMcNeilly Samba Member
Joined: June 03, 2009 Posts: 29 Location: Nashville, TN
Posted: Mon Apr 23, 2012 12:00 pm Post subject: Fuel Filter help |
| I feel dumb asking this because I have always had a fuel filter in my engine compartment (before relocation), but with my '76 fuel injected engine I can't find the filter. Is it under the car? I can't seem to find it in the engine compartment or under the front hood. Please try not to flame me too hard. Thanks! |
RailBoy Samba Member
Joined: March 10, 2008 Posts: 1553 Location: Virginia
Posted: Mon Apr 23, 2012 12:07 pm Post subject: |
| Could be before the engine, above the transaxle, think that is were VW put them on carbed motors... Check that area..... RB |
Big Hoss Samba Member
Posted: Mon Apr 23, 2012 12:12 pm Post subject: |
On my '77 it's attached to the fuel pump, located under the tank by the right wheel housing. _________________ 70 & 77 Bugs, 71 & 72 Supers |
75smith Samba Member
Posted: Mon Apr 23, 2012 12:13 pm Post subject: |
| if you have an electric fuel pump->check under the fuel-tank(passenger side) |
PatterBon Samba Engine Connoisseur
Joined: September 27, 2008 Posts: 3228 Location: Seattle, Washington
VW never actually installed a see through filter near the engine. The factory filters were installed right after the fuel tank and generally were replaced a long time ago. There's also a filter "sock" inside the fuel tank. _________________ PNW Dub Folk & Kitsap dub Folk (KdF)
1973 Standard VW Beetle
1969 Cessna 172K Airplane
| johnshenry wrote: |
"Crusty"??
It would be easier to restore the Titanic. |
Posted: Mon Apr 23, 2012 12:14 pm Post subject: |
| Gotcha, all hear say on my end, good thing to know though, sorry for the misconception there on my part...... RB |
Joel Samba Member
Joined: September 04, 2006 Posts: 8106 Location: NSW Australia
Posted: Mon Apr 23, 2012 2:39 pm Post subject: |
It was only fuel injected bugs and 73 onwards supers that ran inline filters under the tank from the factory.
Before that they just relied on the sock filter in the tank over the pick up and gauze mesh filter inside the fuel pump.
In most cases though, 4 decades worth of POs have fitted inline filters in all sorts of stupid places. |
JerryMCarter1 Samba Member
Joined: January 07, 2007 Posts: 6245 Location: N.W. Phoenix
Posted: Mon Apr 23, 2012 8:49 pm Post subject: |
ya probably do not have one -- ditch the mechanical and run one on the driver side with an electrical pump
Jerry _________________ Experience always triumphs over hearsay and You get to select which theory to believe |
Joel Samba Member
Posted: Mon Apr 23, 2012 8:54 pm Post subject: |
Jerry, it's a fuel injected bug, it's not gonna have a mechanical pump.
Anyway even if it were carbed fitting an electric pump is just stupid, they cause more problems than they fix. |
candymustang66 Samba Member
Posted: Tue Apr 24, 2012 10:31 am Post subject: |
fuel injected bug
get the bentley's and find out what is stock and not.
only you, can say, or with photos presented we can too.. |
Posted: Tue Apr 24, 2012 1:46 pm Post subject: |
Thanks All! I found it right where you said it would be, behind the front passenger tire. Swapped it last night and feels a bit better today. Thanks again. Quick note... make sure you pinch the hose from the tank as it is gravity fed and will continue to flow when you disconnect the filter. Ask me how I know
[/img] |
Posted: Tue Apr 24, 2012 4:36 pm Post subject: NEW PROBLEM?!? |
Okay, so after the fuel filter change, it felt like the bug was running a little smoother. However, after work I fired it up to a nice backfire and then it wouldn't idle. I drove it home nursing the gas to keep it running and having it die multiple times on the way home. Is this a result of the filter being changed? Is the fuel injection computer confused (is that even possible?). Please help. _________________ Matt
1976 Standard Beetle |
Posted: Tue Apr 24, 2012 5:34 pm Post subject: |
I really suggest getting the orange bentley, it will help with the fuel injection issues
without knowing more I would say it is running lean, which means a possible air leak after the airflow sensor?
did it have problems before replacing the fuel filter? |
Posted: Tue Apr 24, 2012 6:00 pm Post subject: |
It would die once in a long while, but never like this. It literally will not idle at all. _________________ Matt
Posted: Tue Apr 24, 2012 6:24 pm Post subject: |
Might have more rust goodies in the tank and it has clogged your new filter. I mean if it worked temporarily then maybe there is a problem right there
Is there any way that you can eliminate the gas tank and see how it runs just off of a gas in a can
Could be pretty dangerous but if you can pull it off - it might tell you that you need to remove and clean the tank
If that does not work – try some injector cleaner – maybe you have one clogged
