Tie rod replacement
65Busstop
65Busstop is offline
PostPosted: Tue Apr 24, 2012 7:48 am    Post subject: Tie rod replacement Reply with quote
My tie rods need replaced on my 65. On the left adjustable one I assume you just take it off and adjust the new one to the same length as old one. If the bus front end was aligned properly, camber fine prior to replacement will any front end adjustment need to be made after installing new tie rods?
olliehank47
olliehank47 is offline
PostPosted: Tue Apr 24, 2012 8:12 am    Post subject: Re: Tie rod replacement Reply with quote
The only change in alignment from tie rod replacement would be toe-in. In theory, replacing the adjustable tie rod with one of the exact same length should result in no change to toe. However, reality is a bit different and you may be off a few mm in the adjustment and though you probably wouldn't notice any driving difference, for peace of mind you might have the alignment re-checked.
Scooterboyd
Scooterboyd is offline
PostPosted: Tue Apr 24, 2012 8:19 am    Post subject: Reply with quote
Check it yourself by measuring the distance between the front tires. Measure from the front of one tire to the other front, then measure the distance between the rear tires. The front distance should be 1/8 inch shorter for proper toe-in.
President of "Society of Unappreciated Overachievers"
62 - 23 Window Bus
60 - Karmann Ghia Convertible
Campy
Campy is offline
PostPosted: Tue Apr 24, 2012 12:49 pm    Post subject: Reply with quote
Yes, do set the toe-in, and adjust and grease the link pins.
Don't worry; be happy. (Baba)
