WestyDreamer Samba Member
Posted: Fri Apr 27, 2012 2:17 pm Post subject: Cracked Heads |
When we took apart our engine to do a reseal we found a small hairline crack between the valves..
Is this a major problem?
I was told that WBX engines are known for this problem.
Someone also said that the crack will close as soon as the engine is started and begins to warm up and expand the crack close.
So is it a problem or No? Just cash strapped and trying to get by..
NWB Samba Member
Joined: March 27, 2012 Posts: 23 Location: Lakewood,WA
Posted: Fri Apr 27, 2012 2:38 pm Post subject: |
It's a very common crack.
I tore apart 3, 2.1's and a 1.9 last week and out of all them there was only 1 head that didn't have that crack.
Put it back together and run it. _________________ '85 Westy 2WD
'69 Chevelle SS
'00 Land Rover Discovery |
vwaaron Samba Member
Joined: October 21, 2009 Posts: 20 Location: Portland,OR
Howesight Samba Member
Joined: July 02, 2008 Posts: 3274 Location: Vancouver, B.C.
Posted: Fri Apr 27, 2012 4:44 pm Post subject: |
That area between the inlet and exhaust valve has no water jacket, so you only need to worry if the crack has upset the valve seat (which is almost never). That can be checked by lapping and/or using Prussian Blue to check whether a valve seat has been tipped/slanted by the cracking.
If your valve stem clearance is within specified limits, then just lap the valves to refresh the seal and save the full valve job or head replacement for when you have the cash. There are lots of Youtube videos on hand lapping.
Clean the valve lapping compound out VERY carefully when done. It will destroy your bearings if it gets in your oil. _________________ '86 Syncro Westy SVX |
