joshuabozarth Samba Member
Joined: December 09, 2007 Posts: 61 Location: las vegas
Posted: Tue Apr 24, 2012 10:42 pm Post subject: interior light stopped working all of a sudden. |
so i took out the tester check the fuse for it good to go. but power to the light its self no go. any ideas? _________________ owner of 1970 bus
| VDubTech wrote: |
| Take off your skirt and pull that sumbitch into place. |
420GOAT Samba Member
Joined: March 31, 2006 Posts: 3299 Location: Wilmington 90744 actually driving and fixing my bus.
Posted: Tue Apr 24, 2012 10:57 pm Post subject: |
| 420GOAT wrote: |
| CHECK POWER AT THE LIGHT |
i just said i did. _________________ owner of 1970 bus
| VDubTech wrote: |
Tcash  Samba Member
Joined: July 20, 2011 Posts: 548 Location: San Jose California
Posted: Tue Apr 24, 2012 11:06 pm Post subject: |
| Hi, did you make sure you had a good ground connection on your tester when you tested for power at the light. Wiring dia. does not show any connectors between the fuse box and the light. So you may have a bad connection at the fuse box, the light or the wire to the light has a break in it. The ground side uses the door contact switches on one side and a ground lug located on the nose just under the fuse box on the other side of the switch. Gotta ask is the bulb good? Hope this helps. Good Luck |
ccpalmer  Samba Member
Joined: September 17, 2006 Posts: 3519 Location: Ann Arbor, Michigan
Posted: Wed Apr 25, 2012 4:17 am Post subject: |
| joshuabozarth wrote: |
| 420GOAT wrote: |
i just said i did. |
And you said there is no power...
| so i took out the tester check the fuse for it good to go. but power to the light its self no go. any ideas? |
Do you mean there is no voltage at the light? If no check bulb + contacts. _________________ '71 Westy
'77 Bay/rusty shed on wheels
Chris Palmer
Cocobolo Co., LLC
ccpalmer.com |
