Replacement wheel stud for wheel adaptors?
Chris070780
Chris070780 is offline
PostPosted: Sun Apr 29, 2012 5:15 pm    Post subject: Replacement wheel stud for wheel adaptors? Reply with quote
I took off my wheels today and snapped two lugs. I have the standard VW to Chevy adaptors. Any clue what size stud they take? Autozone couldn't find anything but I think they might have been lazy looking. Everything they brought me was just a little too big. Anyone know the exact size??
Dale M.
Dale M. is offline
PostPosted: Sun Apr 29, 2012 6:53 pm    Post subject: Reply with quote
Any numbers on head of studs?
They are about a hundred different studs.... And is adapter cast aluminum or steel....
Master list of stud is in this catalog... Starts around Section 10...
https://www.dormanproducts.com/catalog/2006_hardware.htm
IF you can determine diameter of stud and threads per inch (like 1/2 inch by 20 tpi which happens to be Jeep for example), you can find something that will work....
Studs can be ordered most anyplace under DORMAN brand name if you can determine a part number....
More information about "studs" that may help...
http://www.mydune-buggy.com/forum/viewtopic.php?f=10&t=163
I usually order through here using DORMAN part number (Part Number Search button) ....
http://www.rockauto.com/
Dale
Lives his life vicariously through his own self...
1970 "Kellison Sand Piper Roadster" For Street & Show.
John Antoncew
John Antoncew is offline
PostPosted: Tue May 01, 2012 8:21 pm    Post subject: Reply with quote
Just went through this with the cast aluminum adapters. Mine used the Dorman 610-186's. Still your best bet is to find an auto parts store with the big Dorman chest of drawers and match them up side by side.
bartman
bartman is offline
PostPosted: Tue May 01, 2012 8:30 pm    Post subject: Reply with quote
I didn't even know those studs were repairable. Just knock it out and knock another one in?
Remember, kids------> KCR Transmissions SUCKS
Chris070780
PostPosted: Wed May 02, 2012 5:29 am    Post subject: Reply with quote
yep, I found some at Advance Auto. They are a little longer, but they work!
