Bobnotch Samba Member
Posted: Fri Jan 22, 2016 11:49 am Post subject: Re: Montehms 67 Prairie Square |
MonT3 wrote: |
Put my air cleaner back in as I wanted to work on the extension piece that attaches to the shell. I have two rubber boot pieces. I tried to attach each one to both the extensions and the air cleaner with clamps added and they're not adding up. SO here's what I have...
Somewhere on the engine sits a bolt that went to the one of these clamps...
I looked over the blue book and I see the pics showing these clamps attached to the extensions and rubber boot. These are not attaching. Any recommendations? |
The lower clamp in the pic above, goes to the black piece on the body, and not on the boot. You must have picked up an extra clamp while you were out parting cars. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Fri Jan 22, 2016 12:00 pm Post subject: Re: Montehms 67 Prairie Square |
MonT3 wrote: |
On one of my outings, I found a complete set of these angled caps for the distributor.
I was looking to swapping them out with the ones on my cables. I noticed the termination point on the cable is crimped.
Has anyone removed these and used/screwed in the angled ones? |
The angled ends are actually for FI cars, but can be used on other type 3s. They are designed for solid plug wires though. You could either cut the end off your Bosch wires, and screw them on in place of the crimped end, or contact Jim Adney, and get 10 ft of spark plug wire from him, and make up a set of wires using the angled ends and your existing screw on spark plug ends. If you're using a tall distributor cap, then the angled ends are a better way to go, otherwise your existing plug wires will rub against the bottom of the hatch cover (the real reason VW went to the angled end). Just something to think about. Also, those ends ARE getting hard to find. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
MonT3 Samba Member
Joined: January 07, 2012 Posts: 1988 Location: South Dakota
Posted: Sun Jan 24, 2016 8:04 am Post subject: Re: Montehms 67 Prairie Square |
Bobnotch wrote: |
MonT3 wrote: |
The angled ends are actually for FI cars, but can be used on other type 3s. They are designed for solid plug wires though. You could either cut the end off your Bosch wires, and screw them on in place of the crimped end, or contact Jim Adney, and get 10 ft of spark plug wire from him, and make up a set of wires using the angled ends and your existing screw on spark plug ends. If you're using a tall distributor cap, then the angled ends are a better way to go, otherwise your existing plug wires will rub against the bottom of the hatch cover (the real reason VW went to the angled end). Just something to think about. Also, those ends ARE getting hard to find. |
I only have the set of angled ends that fit to the cap. I haven't checked the spark plug end. Not sure they screw out or are crimped as well. Might contact Jim and inquire on pieces to make a set.
I have the next couple of days off. During these next couple of days the brakes will get bled, oil added with some zinc additive and some fuel. I'm planning on doing an electrical shakedown with possibly turning the key for the first time in 2.5 yrs. _________________ MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild |
Posted: Sun Jan 24, 2016 8:33 am Post subject: Re: Montehms 67 Prairie Square |
MonT3 wrote: |
Bobnotch wrote: |
MonT3 wrote: |
I have the next couple of days off. During these next couple of days the brakes will get bled, oil added with some zinc additive and some fuel. I'm planning on doing an electrical shakedown with possibly turning the key for the first time in 2.5 yrs. |
On the Bosch plug wires, the spark plug end IS screwed onto the plug wires. This is mainly because the end has a resistor inside, that can go bad, hence the need to be able to replace just the end.
Good luck on the brake bleed and other stuff, as I know you're getting close. I normally use a battery charger for testing the car's electrical system. I only say that, as if I have a problem, I really don't want to drain the battery (and have to re-charge it). That, and with the battery charger, you can take your time checking things (I don't work as fast as I used too ). _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
MonT3 Samba Member
Posted: Mon Jan 25, 2016 7:10 am Post subject: Re: Montehms 67 Prairie Square |
Damn, I didn't even think of that as my battery charger has been sitting on the bench right where I'm working and never gave it a thought. Must have been too focused on other things to think about that option. Thanks Bob. Oh, Will look into these angled caps.
I miss-placed the small fastener that holds the bar script in place. I'll be picking up some suitable replacements as well as some wire for the reverse light, oil, some brake fluid as well as some heater fluid as the temps are sucking at the moment and winds are picking up. Hopefully this afternoon/evening I can start on the electricals. _________________ MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Mon Jan 25, 2016 10:12 am Post subject: Re: Montehms 67 Prairie Square |
I've used small squares of inner tube w/ice pick hole in the center for script fasteners. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
MonT3 Samba Member
Posted: Tue Jan 26, 2016 10:47 am Post subject: Re: Montehms 67 Prairie Square |
Today I suffered a setback. While bleeding the brakes, one of the bleeder valves snapped off the rear brake cylinder. Two of the bleeder valves up front are hard to loosen and looks like I may have stripped them. I'm taking a break from this for a day or two while I source some new valves to replace all of them. I may need to get another set of cylinders for the rear as well. _________________ MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild |
MonT3 Samba Member
Posted: Tue Jan 26, 2016 10:48 am Post subject: Re: Montehms 67 Prairie Square |
Mike Fisher wrote: |
I've used small squares of inner tube w/ice pick hole in the center for script fasteners. |
I found a nice thick, rubber fender washer and plan on making some fasteners to secure that script on. Thanks Mike. _________________ MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild |
69 Notchback Samba Member
Joined: September 12, 2011 Posts: 714 Location: Bailey Co
Posted: Tue Jan 26, 2016 12:43 pm Post subject: Re: Montehms 67 Prairie Square |
Stay positive MonT3. We have all seen you deal with much worse. Some days I feel like flicking matches at my square and others days are good but its a roller coaster of emotions for sure. |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4921 Location: Southern AB
Posted: Tue Jan 26, 2016 9:31 pm Post subject: Re: Montehms 67 Prairie Square |
W1K1 wrote: |
you should be able to get some push nuts from your local automotive supplier
That's what was on the originals
I thought the originals were a nylon tube? If so, contact Lee Hedges, as I believe they are the same that the T-34 used for the VW script, along with the 1500, and "S" emblems. I'm pretty sure he's still got a few, as he had to buy a box of 1000 so he could do his own car(s).
Note: These are for the thin style pins used on early cars, and not the thicker pins like the front VW emblem uses. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
MonT3 Samba Member
Posted: Thu Jan 28, 2016 9:55 am Post subject: Re: Montehms 67 Prairie Square |
Ok, re-energized. Yesterday I ordered some new brake cylinders from ISPW. Always great to deal with Anthony and Alex out there. So thins AM I'm getting into placing these stickers. I got all in place with exception of this one. I have three options and the Blue book didn't give me a clue on it's location for placement. I did see in the classified for glove boxes that these may have been placed in the inner door. However, I've it placed on both sides.
Does anyone know the true location of where it resides on the car? Also, I noticed the large sticker has more info than the smaller ones. Which re-popped one is THE closest one?
I have to make a trip to the local paint supply store so I'll be looking for the clips. Thanks for the pic! _________________ MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild |
Posted: Thu Jan 28, 2016 10:54 am Post subject: Re: Montehms 67 Prairie Square |
MonT3 wrote: |
I have to make a trip to the local paint supply store so I'll be looking for the clips. Thanks for the pic! |
Unfortunately those stickers are for a beetle, as called out on the 2 smaller ones, and the wrong tire size on the large one (type 3s didn't get 5.60's or 155's, they came with 6.00, or 165's.
That said, I believe putting the sticker on the left, on the inside of the glove box door is the correct place for it (type facing you). _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Donnie strickland Samba Member
Joined: December 21, 2009 Posts: 2403 Location: Moody, AL
Posted: Thu Jan 28, 2016 11:26 am Post subject: Re: Montehms 67 Prairie Square |
Here's the glovebox lid on my 71 -- is it the same on a 67? Tire sticker on left, A/C sticker on right:
And a closeup of the tire sticker:
_________________ 71 Elm Green FI A/T Squareback |
MonT3 Samba Member
Posted: Thu Jan 28, 2016 6:24 pm Post subject: Re: Montehms 67 Prairie Square |
Bobnotch wrote: |
MonT3 wrote: |
That said, I believe putting the sticker on the left, on the inside of the glove box door is the correct place for it (type facing you). |
Well, that sucks. I guess there's an opportunity for a Sticker Stud to get a Type3 spec sticker right. These'll go back into a bag and given to my bug friend. _________________ MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild |
MonT3 Samba Member
Posted: Thu Jan 28, 2016 6:26 pm Post subject: Re: Montehms 67 Prairie Square |
Donnie strickland wrote: |
Thanks for sharing that sticker. That validates Bobs info. I haven't seen what a 67 would look like but I'm going to hold off on putting this on. Thanks again. _________________ MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild |
Posted: Thu Jan 28, 2016 6:52 pm Post subject: Re: Montehms 67 Prairie Square |
No problem! I did notice the sticker has a 361, Squareback-only part number. _________________ 71 Elm Green FI A/T Squareback |
MonT3 Samba Member
Posted: Wed Feb 03, 2016 7:27 am Post subject: Re: Montehms 67 Prairie Square |
In the last couple of days, I've been at some small things while I've been waiting for my brake cylinders to get in. I was notified they may be delayed due to the weather conditions in Co. Started by getting my tac in place
Then started on the vinyl for my parcel tray...
Got my strap sorted out and covered my engine lid. Will be stitching the hook in place today. Also need to trim the edges down.
Also pulled my mats to show Leo my set up versus his for reference.
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild
Posted: Wed Feb 03, 2016 7:45 am Post subject: Re: Montehms 67 Prairie Square |
Thanks MonT3. The car is looking good. I like the individual Matt's I just went with over the tunnel as that is what I had as a teen. What do u have for the rear?my rear is also over the tunnel and the rear is where my mats look a little short.bit a bunch done yesterday but can't post picks at the moment. |
MonT3 Samba Member
Posted: Wed Feb 03, 2016 10:16 am Post subject: Re: Montehms 67 Prairie Square |
69 Notchback wrote: |
The rear ones are singles as well. Heading into the garage to finish off the parcel tray piece until I can get my material from the upholstery guy. _________________ MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild |
