62 Electrical issues
Goto page 1, 2  Next
55veedub
55veedub is offline
PostPosted: Wed Apr 25, 2012 6:05 pm    Post subject: 62 Electrical issues Reply with quote
62 single cab with dual port 1600, 009 Dist, 34 pict3.
I did not do the 12V conversion. I am having the following issue and am unsure where to start.
Engine fires up and idles fine...after a minute or so it bogs down as if the alt is charging and if the headlights are turned on and you rev it up the lights will get brighter and as the RPM falls back down to bogging idle they dim down a bit...
Where should i start looking for the problem and what could it be?
Any help would be great!
Thanks!
Mike
'62 Single Cab
'68 Bug eye Baja.
'69 Volksrod
'70 Canadian standard bug.
Eric&Barb
Eric&Barb is offline
PostPosted: Wed Apr 25, 2012 8:06 pm    Post subject: Reply with quote
Full tune up.
In Stereo, Where Available!
55veedub
55veedub is offline
PostPosted: Thu Apr 26, 2012 7:07 am    Post subject: Reply with quote
I just did a complete tune up, carb rebuild, points, condenser, plugs, cap, rotor, wires, oil, air filter.
It just seems the alternator (or something else) is drawing power and setting the alt to charge...
Is there a way to test the alt or regulator?
Another issue was that the gauge lights will come on and the taillights with the switch in the off position...but this is intermittent.
'62 Single Cab
'68 Bug eye Baja.
'69 Volksrod
55veedub
55veedub is offline
PostPosted: Thu Apr 26, 2012 6:03 pm    Post subject: Reply with quote
Ok so I did more investigating and its almost like the system is being back fed.
With the alternator connected and engine running, the fuel gauge reads 1/2. with the alternator charge wire disconnected the fuel gauge reads R (which is where it should be, theres less than 5gal of fuel in it)
any ideas??
'62 Single Cab
'68 Bug eye Baja.
'69 Volksrod
quartermilecamel
quartermilecamel is online now
PostPosted: Thu Apr 26, 2012 6:40 pm    Post subject: Reply with quote
Im kinda lost here, as usuall Surprised , but how can you not do a 12v conversion, yet have an alternator? Bad ground at the fuel guage?
Looking for the U shaped swing arm for sliding door split. Left hand drive. Baywindow arms are 1/2 inch longer.
55veedub
55veedub is offline
PostPosted: Thu Apr 26, 2012 6:42 pm    Post subject: Reply with quote
I personally did not do the 12V conversion...so i dont know what was done. it is 12V though.
Its also effecting the park/gauge lamps aswell as the fuel gauge...
'62 Single Cab
'68 Bug eye Baja.
'69 Volksrod
Eric&Barb
PostPosted: Thu Apr 26, 2012 6:55 pm    Post subject: Reply with quote
Sounds like you need to fix grounds and go through the wiring cleaning, tightening and checking for voltage drops as you go.
55veedub
55veedub is offline
PostPosted: Fri Apr 27, 2012 7:02 am    Post subject: Reply with quote
So would bad grounds cause this?
'62 Single Cab
'68 Bug eye Baja.
'69 Volksrod
Eric&Barb
PostPosted: Fri Apr 27, 2012 7:16 am    Post subject: Reply with quote
Park and gauge lights yes.
Headlights getting dim/bright with engine revs more likely is wiring voltage drops. Need to check voltage at battery and how much of that is getting to various places in the wiring. Have found 2 or more volts drop, and have been able to reduce that to less than 1/10 of a volt.
quartermilecamel
PostPosted: Fri Apr 27, 2012 3:15 pm    Post subject: Reply with quote
How hot does the headlight switch shaft get when you turn on the headlights? If it gets hot at all, or warmer, then its time to get it rebuilt with soldered internal connections, or get a replacement. Thats one major voltage drop right there.
IN2RUST Premium Member
IN2RUST is offline
PostPosted: Fri Apr 27, 2012 4:53 pm    Post subject: Reply with quote
That is an open circuit as well.
Dawerks wrote "the heat is too much for the shaft"
$$ Wanted, Original Paint 15 or 23 window Deluxe Bus.
RUSTFARMER....I like anything old and rusty (Aged).
I'm stuck in Folsom Prison.... and time keeps Dragging On..........
55veedub
55veedub is offline
PostPosted: Fri Apr 27, 2012 8:21 pm    Post subject: Reply with quote
Ok so heres the scoop. I went through the under dash wiring... what a mess. I rewired it back to stock configuration. There were lots of strange wiring with the light bulbs, and such and wires not going where they were supposed to.
Results:
-So far the park lights and gauge lights do not come on.
-With headlights on I am now able to dim the gauge lights, I was not able to before, they were always on.
One more issue i cant figure out.
My fuel gauge still reads 1/2 when i know it should be at R. When i disconnect it, it drops to E.
I read alot about bad grounds and gauges being stuck at full or E. But what would make it stay at 1/2?
'62 Single Cab
'68 Bug eye Baja.
'69 Volksrod
olliehank47
olliehank47 is offline
PostPosted: Sat Apr 28, 2012 8:04 am    Post subject: Reply with quote
Results:
Don't understand one thing from above. You said the gauge lights do not come on but then you say, "I am now able to dim the gauge lights..." Can you clarify?
The gas gauge can act very strangely if the body of the gauge is not well grounded to the dash, via the clamp that holds it in. If the ground is poor, the gauge will read incorrectly as soon as the light switch (which controls the gauge light) is turned on. Try polishing up the rear of the dash where the clamp teeth bite and securely tighten the thumb nuts for the gauge.
55veedub
55veedub is offline
PostPosted: Sat Apr 28, 2012 9:21 am    Post subject: Reply with quote
Yes before I went through the wiring, with the engine running the park lights would stay on full with the switch in off position (gauge lights were wire to the same circuit) and i was unable to dim them, they were just on full..
After rewiring, the park light havent come back on with the switch off and the gauge lights aswell. With the light switch on the park lights and the gauge lights are now on and the gauge lights are now dimmable.
Ill try to ground the gauge better and see what happens.
'62 Single Cab
'68 Bug eye Baja.
'69 Volksrod
Eric&Barb
PostPosted: Sat Apr 28, 2012 9:23 am    Post subject: Reply with quote
There also should be a ground wire going from the fuel sender to the body, but that is kind of hard to get to with engine in.
55veedub
55veedub is offline
PostPosted: Tue May 08, 2012 5:47 pm    Post subject: Reply with quote
Ok so heres the status.
I rewired the dash, switches, and gauges.
Added ground wire to the fuel gauge.
Re did gorund on fuel tank sender.
The back feeding problem was from a wire from drivers taillight that was connected to fused side of fuse panel (so it was being powered with fuses pulled.) Which in turn went through the improperly wired gauge lights keeping them on full.
SO my only issue now is that the fuel gauge still reads half full when empty. as the tank is filled, it goes up from there.
'62 Single Cab
'68 Bug eye Baja.
'69 Volksrod
Eric&Barb
PostPosted: Tue May 08, 2012 6:29 pm    Post subject: Reply with quote
Darn! Sounds like you will have to pull the fuel tank sender and either fix it or replace.
BenTen
BenTen is offline
Have you tested your fuel sender? Sounds like it may either be shorted or the float isn't sliding all the way down in the tube.
busdaddy
busdaddy is offline
PostPosted: Tue May 08, 2012 6:39 pm    Post subject: Reply with quote
Where are you disconnecting it?, at the gauge or at the tank?
Wanted, 68-73 westy OG plaid curtains, singles OK.
55veedub
55veedub is offline
PostPosted: Wed May 09, 2012 7:07 am    Post subject: Reply with quote
If i disconnect it at the gauge it reads Empty
If i pull the ground on the sender, it reads full. I think..... cant remember exactly.
'62 Single Cab
'68 Bug eye Baja.
'69 Volksrod
Goto page 1, 2  Next
