55veedub Samba Member
Joined: May 12, 2008 Posts: 541 Location: North Bay, Ontario, Canada
Posted: Wed Apr 25, 2012 6:20 pm Post subject: Replacing 009 |
I have a 1600 DP with 34pict3 and 009.
Im not a fan of the 009 and the flat spot.
Would anyone reccoment changing the 009 out with the SVDA?
http://www.cip1.ca/ProductDetails.asp?ProductCode=VWC%2D043%2D905%2D205
Thanks,
<Mike _________________ '62 Single Cab
'68 Bug eye Baja.
'69 Volksrod
'70 Canadian standard bug. |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 55651 Location: Long Island, New York, USA
Opticsguy Samba Member
Joined: December 29, 2011 Posts: 146 Location: New Hampshire
Posted: Wed Apr 25, 2012 6:54 pm Post subject: |
I replaced an 009 (aftermarket) with a pertronix svda that I bought from amazon.com of all places. Once I figured out how to install and adjust it,
it works like a champ. Vertually no flat spot on take
off. _________________ 72 sb convert
Past vws
98 jetta gl
03 20th gti
03 jetta gls tdi wgn |
torsionbar Samba Member
Posted: Wed Apr 25, 2012 7:12 pm Post subject: |
x2. i made the mistake of buying the chinese one a few years ago. it's poorly made junk. get the good one from aircooled.net. _________________
| Max Welton wrote: |
[air cooled vw's] are no longer suitable for the general public. The owner has to be be able to maintain the car. And that is after fixing all the deferred maintenance items and ill-conceived modifications. If you can't do those things you are pretty much screwed. |
neil68 Samba Member
Posted: Wed Apr 25, 2012 7:15 pm Post subject: Bosch SVAD distributors |
You might want to try the VW dealers. I purchased one for a Mk 1 Rabbit and IIRC, it's very similar, and some dealers still have those on their shelves... _________________ Neil.
"Real men run drums."
Der Kleiner Rennwagens
68 Beetle 2332 cc
12.8 seconds @ 104 mph
http://www.youtube.com/watch?v=FF2gCti3dro |
Glenn  Mr. 010
Posted: Wed Apr 25, 2012 7:23 pm Post subject: Re: Bosch SVAD distributors |
| neil68 wrote: | | You might want to try the VW dealers. I purchased one for a Mk 1 Rabbit and IIRC, it's very similar, and some dealers still have those on their shelves... |
That would be a mistake. _________________ Glenn
HBB/RW
www.DasVolks.com
Long Island's Aircooled Club |
bug-ugly Samba Member
Posted: Thu Apr 26, 2012 2:34 am Post subject: |
Hey, I'm new here.
I recently purchased a '72 standard (my fourth VW but my first in almost ten years). It has a 009 and a German 34 pict 3. I've got it running like a damned top! It MAY be too far advanced, as I don't have a timing light at the moment and static timed it to 7.5. I don't know, yet. I haven't driven it on the highway or very long. I will be getting my timing gun this weekend and IF the hesitation doesn't come up, I will give you specs. AS41 block, completely stock as far as I can tell. Although, it has been rebuilt... NO OIL LEAKS! So, I am not sure on the displacement. It feels very peppy!
Anyhow, I will post some specs. in this thread after I time the full advance and assure the driveability. |
drew8372 Samba Member
Joined: January 20, 2012 Posts: 74 Location: Massachusetts
Posted: Thu Apr 26, 2012 3:19 am Post subject: |
| I have a 34 pict 3 carb and i added a svda from aircooled.net and a was surprised how well my super ran. she hasn't run this good in ten years. it had more pep and no flat spot. |
zombiebug Samba Member
Joined: August 18, 2011 Posts: 1012 Location: Webster, MA
Posted: Thu Apr 26, 2012 4:20 am Post subject: |
I had a 009 with a Bocor 34 pic 3. For those who are new thats a copy cat Solex. Anyway The SVDA works incredible. Defiantly worth the money, not just for the no flat spot, but for the increase in fuel economy. _________________ '74 Super |
Greg in GA Samba Member
Posted: Thu Apr 26, 2012 7:58 am Post subject: |
| bug-ugly wrote: | It has a 009 and a German 34 pict 3. I've got it running like a damned top! It MAY be too far advanced, as I don't have a timing light at the moment and static timed it to 7.5. I don't know, yet. I haven't driven it on the highway or very long. I will be getting my timing gun this weekend and IF the hesitation doesn't come up, I will give you specs. AS41 block, completely stock as far as I can tell. Although, it has been rebuilt... NO OIL LEAKS! So, I am not sure on the displacement. It feels very peppy!
You can't static time a 009, if has to be timed a full advance. _________________ 1969 Beetle
1974 Westy 1800cc FI conversion |
Posted: Thu Apr 26, 2012 8:03 am Post subject: |
| Greg in GA wrote: |
You can't static time a 009, if has to be timed a full advance. |
I though the SVDA was the same way? _________________ '74 Super |
rlutterb Samba Member
Joined: January 10, 2006 Posts: 1140 Location: Cincinnati
Posted: Thu Apr 26, 2012 8:44 am Post subject: |
My 009 ran well till I added the 34, at which point I finally gave in and got the bosch SVDA. They work well together. _________________
| God wrote: | | ....and on the 7th day, I created the super beetle |
.../___\.
(o\_!_/o) '73 Super |
mattintheboxx Samba Member
Joined: July 02, 2011 Posts: 24 Location: bakersfield,ca
Posted: Thu Apr 26, 2012 10:02 am Post subject: |
| So if you add the pointless igniting in the 009 it doesn't matter what carb you have on it? |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 2517 Location: Sunset, Louisiana
Posted: Thu Apr 26, 2012 10:07 am Post subject: |
| mattintheboxx wrote: | | So if you add the pointless igniting in the 009 it doesn't matter what carb you have on it? |
The electronic ignition is just a points replacement. It doesn't change the advance properties of the distributor.
On smaller carbs, the 009 can work well. But if you run the larger 34pict you will be happier with the stock type SVDA. _________________ Brian
'69 Dune Buggy, http://www.thesamba.com/vw/forum/viewtopic.php?t=419624
'69 Beetle Convertible
'70 Beetle, http://www.thesamba.com/vw/forum/viewtopic.php?t=544918 |
Kabasue Samba Member
Posted: Thu Apr 26, 2012 6:48 pm Post subject: |
I had the 009/34-3 combo, and switch to a SDVA from aircooled. Best thing ever, it was like owning a new bug. _________________ Remember to get your VW spayed or neutered
71 standard beetle (mine)
71 SB convertible (also mine)
73 Westy 80 hp T4 engine (misses resto project)
72 Super bug (parts bug, any one need a part pm me)
75 westy parts bus |
Dwayne_71SB Samba Member
Joined: February 26, 2009 Posts: 256 Location: Atlanta, GA
Posted: Fri Apr 27, 2012 8:29 am Post subject: |
I was using an 009 and Kadrons. Switched to an SVDA from aircooled.net. Made a huge difference in driveability, low-end responsiveness and torque. You can have my SVDA when you pry it from my cold, dead hands. _________________ '71 Super Beetle |
Posted: Thu May 03, 2012 2:31 pm Post subject: |
| Greg in GA wrote: |
Yes, I know. Of course it is the full advance that matters, with the 009. I have done my research...
On the other hand, how would you get your engine running? You have to start with static timing to get it running and then adjust the full advance. Did you read my post? |
Posted: Thu May 03, 2012 2:33 pm Post subject: |
| zombiebug wrote: |
I though the SVDA was the same way? |
I believe the SVDA can be statically timed. |
Randy in Maine Samba Member
Joined: August 03, 2003 Posts: 29743 Location: The Beach
Posted: Thu May 03, 2012 4:10 pm Post subject: |
| bug-ugly wrote: | | zombiebug wrote: |
You are wrong. |
Posted: Thu May 03, 2012 9:03 pm Post subject: |
| Randy in Maine wrote: |
You are wrong. |
Rob and Dave's aircooled guide has never steered me wrong.
"The double-vacuum advance distributor must be timed with the engine idling, using a strobe timing light. The 009 and single-vacuum distributors CAN be statically timed at 7.5o BTDC, but timing with a strobe light is recommended."
According to them, you CAN set the SVDA statically. It is not ideal, but it will be close. Obviously, a light is the most accurate way to set the timing.
Anyway, I'm not here to argue. Continue on with whichever method you prefer. |
