Need a short block
Forum Index -> Performance - Engines/Transmissions Share: Facebook Twitter
douger0500
douger0500 is offline
PostPosted: Sat Apr 28, 2012 2:27 pm    Post subject: Need a short block Reply with quote
What is the best option? My block is trash. I wanna reuse my jugs and pistons if they are still in spec. 1776 jugs. Oversized valves. Ready to put my buggy together. I really wanna get something that will work and not have to worry about the bottom giving up on me for some time. It is a 1600 dp block.
thanks,
Doug
Little Harry
Little Harry is offline
PostPosted: Sun Apr 29, 2012 1:23 am    Post subject: Reply with quote
What's your budget? Are you looking at buying new or at buying a used case and re-using it? CB Performance has these http://www.cbperformance.com/catalog.asp?ProductID=184
1973 VW Karmann Ghia - 1679cc, Kadrons, MoFoCo 041's, Tri-Mil Euro, Interstate Battery, and a little rust.
Zack1978 wrote:
From my perspective vintage VW's are beyond being used for daily driver purposes. It would be best to have your car parked in a garage, and kept away from the elements on a daily basis. Zack
Uhhh...yeah...I disagree
douger0500
PostPosted: Sun Apr 29, 2012 7:41 pm    Post subject: Reply with quote
Budget is a thousand or two. Don't want the headaches of somebody elses junk. Was thinking rotary or ford 2.3 as options also
KopfenJager
KopfenJager is offline
PostPosted: Sun Apr 29, 2012 8:14 pm    Post subject: Reply with quote
No no no....Stay aircooled.
SI VIS PACEM PARA BELLUM
DarthWeber
DarthWeber is offline
PostPosted: Sun Apr 29, 2012 8:43 pm    Post subject: Reply with quote
Unless you are pretty good at fab work, those choices will be a headache.
Mitey62 wrote:
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on.
RockCrusher wrote:
JB weld the case halves....that'll keep the fretting to a minimum. Laughing
douger0500
PostPosted: Tue May 01, 2012 9:42 am    Post subject: Reply with quote
Ok so with a budget of 2 grand what are some options?
gearhead91
gearhead91 is offline
PostPosted: Tue May 01, 2012 10:27 am    Post subject: Reply with quote
pick your poison Smile
scat:
http://www.scatvw.com/master/engine_kits/
CB when they get more in stock:
http://cbperformance.com/catalog.asp?ProductID=1781
carcraft:
http://carcraftstore.com/enginemechanical.aspx
brothers machine shop:
http://brothersvwmachineshop.com/parts.htm
aircooled.net:
http://vwparts.aircooled.net/VW-Performance-Engine-Kits-s/344.htm
mark tucker wrote:
I hate those race cars that are not driven,I think they should have a desigination on them.hmm like RC. Samd gos for show queens that dont get driven.or the guys porsche they he is afraid to drive it it might get fly shit on the windscreen. if it's yours drive it like you stole it.EVERYDAY.
Reply to topic    Forum Index -> Performance - Engines/Transmissions All times are Mountain Standard Time/Pacific Daylight Savings Time
