Daniangel Samba Member
Posted: Sun Apr 29, 2012 4:52 pm Post subject: Early Ghia seat belt mounts |
My 62 has the mounts on both sides for the top of the belt, and on the inside, behind the brake, but the 2 on the out side by the doors are nowhere to be found. Whats going on?
I have NON-RETRACTABLE 3 point belts from Wolfsburg West.. |
ovghiaguy Samba Member
Joined: November 07, 2009 Posts: 827 Location: Orangevale Ca.
Posted: Sun Apr 29, 2012 6:14 pm Post subject: late model seat belts. |
| look underneath the car at the pan and see if the bolthole for the belt is there. (both sides) |
glutamodo  The Android
Joined: July 13, 2004 Posts: 18022 Location: Douglas, WY
Posted: Sun Apr 29, 2012 7:18 pm Post subject: |
I think Ghias were like Bugs when seat belt mounts were added. At that time, shoulder ("diagonal") belt mounts were standard, but outer lap belt mounts were not and were an option. VW had a technical bulletin in 1962 about it:
O2COOLED Samba Member
Joined: May 22, 2007 Posts: 165 Location: Northern California
Posted: Mon Apr 30, 2012 2:08 am Post subject: Re: late model seat belts. |
| ovghiaguy wrote: | | look underneath the car at the pan and see if the bolthole for the belt is there. (both sides) |
X2. I would check this first. Should be near the heater channel right by the door pillar. _________________ "Sometimes people forget they signed up to a HELP & SHARE Forum not a pissing contest"
Current: '69 Ghia
VW History:'63 Bug;'70 Bug;'73 412;'83 Rabbit;'86 Golf;'76 Fat Chick; 67 Ghia; '70 Bug |
sputnick60 Samba Member
Joined: July 22, 2007 Posts: 944 Location: Sydney Australia
Posted: Mon Apr 30, 2012 3:35 am Post subject: |
This is how it is on a '66, Probably the same on a '63
Nicholas _________________ 66 Ghia Vert - in progress...
"In theory there is no difference between practice and theory. However, in practice there is." |
Posted: Mon Apr 30, 2012 3:44 am Post subject: |
I think the seat belt mountings changed in 1965...
Angus Dowrie Samba Member
Joined: March 07, 2005 Posts: 19 Location: Brisbane, Australia
Posted: Mon Apr 30, 2012 3:49 am Post subject: |
My early '63 model (Oct '62 build) has the shoulder mount, and the one on the tunnel as you have circled. However it didn't have the third one behind the seat rail as a factory mount - it had an aftermarket bracket with two bolts through the floor (and doubling plate under the floorpan) with a 90 degree bend and single mounting hole for the belt. I've seen similar ones fitted to a few beetles as well I've owned.
Australia didn't have compulsory belts until the late60's/early 70's, people started retro-fitting belts to old cars in the late 70's and 80's when they got used to them - there was a backlash against them at first. I think Victoria was the first state to bring them in, and most followed within a couple of years.
I can take a photo of the bracket if you want, but any seat-belt supplier/installer should be able to supply them.
Angus |
c21darrel Samba Member
Joined: January 22, 2009 Posts: 1063 Location: San Dimas
Posted: Mon Apr 30, 2012 2:15 pm Post subject: |
| If the pans have been replaced, it may not have them. The replacement pans need to have these drilled and welded during the install. |
Jeromerino Samba Member
Joined: February 28, 2013 Posts: 59 Location: Colorado
Posted: Mon May 13, 2013 8:46 am Post subject: |
| glutamodo wrote: | | I think the seat belt mountings changed in 1965... |
Nasty 1964 seat belt plug adapters and bolts.
30 minutes later, not so nasty.
 _________________ 1964 Karmann Ghia Coupe |
