spencerfvee Samba Member
Posted: Fri May 04, 2012 4:40 am Post subject: |
hay darth i bet if gas was 3.59 in Cal. there would be the biggest line at gas staintions . cars all over the place . that gas staition would have its tanks drainned in a heart beat lol talking about that around here guys are stealing gas by parking there vans over the tanks at gas staitions and pumping the gas out of the gas staintions tanks into big tanks in there vans and driveing away spencerfvee
DarthWeber wrote: |
Spencer you kill me! Gasoline has been well over $4 here in SoCal for MONTHS!! I'd love to pay only $3.90 for gas, $3.59 in my dreams.
Hey, $10 more for a blue coil, just consider it your contribution to reviving the economy!! |
Boolean Samba Member
Joined: January 19, 2012 Posts: 1712 Location: Stockholm
Posted: Fri May 04, 2012 9:05 am Post subject: |
If it was 3.50 it wouldn't be worth the queue unless you bought like 500 gallons.
Just get used to it.
You have the second cheapest gasoline in the world. |
bugguy076 Samba Member
Joined: December 11, 2007 Posts: 1068 Location: Dover, PA.
Posted: Thu May 10, 2012 3:49 am Post subject: |
I did another milage check with the good coil. Got 38 mpg. Did not improve as much as I thought it would. The engine runs much better and has more power.
I'm going to take the car on vacation next week. I think a 500 to 600 mile road trip will tell if the milage numbers are right.
The only problem I see is where I'm going. The Catskill Mountians is not the best place to be checking fuel milage. Along with my lady friend and her luggage. You know how much they have to take along! Like checking the mileage on your pickup with a full load of dirt.
This should be a real test. |
TomSimon Samba Member
Posted: Thu May 10, 2012 3:15 pm Post subject: |
Here's a few tips I know to work from first hand experience...
1) air up your tires to max inflation listed on the sidewall, plus some. The ride will be a little rougher but, I've netted 5% increase in average MPG with my Metro by doing this alone. If you are putting on new tires, tires with the lowest rolling resistance will typically have the highest wear rating and lowest traction rating.
2) make sure the brakes aren't dragging. Check your front and rear toe-in. The closer to zero toe, the lower the rolling resistance. You can verify by pushing the car around by hand. Warning; toe out condition can be a handful to drive in the wet and in cross winds.
3) Less weight, the better. More tools for a long trip in an old car, sometimes the better, so it's a tradeoff. Have your chick pack as if she's going backpacking (that's how I convince mine to pack light on a road trip, we make it a game). I tell her 'look, if it turns out YOU need that extra jacket you want to bring, I'll let you use mine instead'
4) adjust your driving style: shift early, accelerate gently, ease onto the freeway ramps, timing your entry between cars. Your goal is to accelerate smoothly and gradually, never having to decelerate or brake. Shift into neutral and coast for 1/8 mile down to 50mph before exiting an offramp. Slow down your cruising speed by 5mph, drive up short hills with your throttle foot fixed, allowing the car to naturally slow a little going up the small hill, keeping throttle angle the same. Your acceleration rate should mimic that of a tractor/trailer rig for highest mpg's. Plumbing in a cheap vacuum gauge will help you do that.
5) don't use any higher octane fuel than you absolutely need. Too much octane makes an engine run lazy and loose power. Check your points if you have them, and timing often. Use a lighter oil, like 10w30 wt. Fee the engine some Chevron Techron, Seafoam, or some sort of FI cleaner. It keeps the combustion chambers, valves and piston tops clean which help an engine resist pinging. Run as much timing as you can without pinging in 4th gear going up a steep 6-7% grade at 3/4 throttle. Most freeways have 3-4% max. If it pings at full throttle, don't do that.
Hope that helps |
Posted: Thu May 10, 2012 4:32 pm Post subject: |
I do understand what you are saying. But my girl packs like she is moving, not going for a long weekend. LOL. We have had "the talk"and is improving.
I did go over the entire car for the trip.
The bag of tools and spare parts is a mandatory item, as is a spare tire. I would not leave home without them. I have pulled a rabbit out of the hat, or bag, more than once.
Driving an old VW around the northeast is like taking a buggy out in the desert. If you did not bring it with you, you will not find it. |
Posted: Thu May 17, 2012 3:41 am Post subject: |
I made it back from Catskill mountians last night. Over 600 miles of all kinds of reasons to get lower mileage.
Two solid days of driving in the rain, huge mountians, and over 500 pounds of people and luggage.
I still got 36 MPG overall. I ran at the posted speed limits, and did not baby the car at all. A lot of the high mountians I ran in 3rd gear at the 55mph speed limit, passing trucks and a lot of the small rice burners people are buying to save on gas.
The engine ran well. Not one hickup. No overheating at all using regular fuel. When I started the trip, the engine only had 400 miles on it. I could tell, the more miles It got on it, the better it ran.
I wish I had built this engine years ago. |
dawie Samba Member
Joined: July 27, 2008 Posts: 217 Location: Cape Town, South Africa
Posted: Thu May 17, 2012 4:59 am Post subject: |
Congratulations. That is excellent results, especially seeing that you were not sparing the horses! |
AlteWagen Troll
Posted: Thu May 17, 2012 1:42 pm Post subject: |
Congrats on the mpg!!
Are you running the 77mm pistons and late dp heads? |
Posted: Thu May 17, 2012 2:16 pm Post subject: |
That's so cool, nice job, great mpg average!
I do a lot of road trippin'. In the last 6 months we've taken 2 trips out to the Mojave Desert, driven to Lake Havasu twice in my Metro, towed the racecar down to Phoenix in March with my Gal's minivan. Then did a Reno-Death Valley-Las Vegas road trip in April.
You've just inspired my next road trip. I need to ready my '62 bug for a fall trip up the Medocino coast or something. It's got a fresh big-bore 40hp rebuild and brakes that need breaking in |
Posted: Thu May 17, 2012 2:36 pm Post subject: |
Yes. Stock 77mm barrels and VW dual port heads. The chamber overlaps the cylinder a small amount. But I felt there is enough sealing surface to work. I did make spacers to center the barrels in the heads. Time will tell if I made the right choice. I think once the carbon builds up in the little recess, it won't make a differance.
I did a compression test before I installed the motor. With freshly honed cylinders and unseated rings it got between 125 and 130lbs compression. All I did was spin the engine over with a 1/2" pull bar and socket while it was sitting on the bench.
It runs well on regular gas with the compression at 8.1. Just high enough for a good burn with the FK-65 cam I'm using. |
Posted: Thu May 17, 2012 2:44 pm Post subject: |
We all do a lot of work on our cars. What good are they if we don't use them? I hope I can get more of us on the open road to enjoy the hobby. I just made my road trips cheap again. Next is a trip to the shore. It's been too long since I did some surf fishing. I just have to figure out how to carry a 11ft surf rod on the car ! |
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7543 Location: Whittier,CA
Posted: Thu May 17, 2012 3:21 pm Post subject: |
With respects to your combustion chamber overlaping the cylinder a small amount, I think it may be better if you take a more proactive approach to the carbon buildup. Rather than let it build up over time, which could lead to a hot spot for preignition, I think it would be better to run some cleaner, Seafoam or the like, to keep the chamber as clean as possible. Tom Simon mentioned this in a post above. Just a thought, may prevent problems down the road. _________________
Mitey62 wrote: |
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on. |
RockCrusher wrote: |
JB weld the case halves....that'll keep the fretting to a minimum. |
Posted: Fri May 18, 2012 2:32 am Post subject: |
Darth, I don't know if the Seafoam is a good idea or not. If I start to encounter preignition or overheating, I may try it.
The overlap on the barrel edge is about .050. I have torn good running engines down that have had much thicker deposits on the chambers and exhaust valves. I'm sure you have seen this as well. Time will tell if it matters or not. |
krusher Samba Member
Joined: September 24, 2002 Posts: 7652 Location: europe
Posted: Mon May 21, 2012 1:32 am Post subject: |
bugguy076 wrote: |
I like the idea of stroking a small displacement engine. You can gain back low end torque. If I had the parts, I would have built it this way.
I think most get the idea of what I was tring to achieve. I built a reliable engine at a low cost. I can recoup what I spent in a short time.
I increased the mileage by at least 10mpg over the stock 1600 that was in the car.
While the low end torque suffered a little from the smaller cc's, the overall way the car drives is about the same. And it is snappy, too. At higher rpm's this 1300 out performs the 1600. Nice to have that extra kick in the pants when jumping on the expressway.
I don't think there is a perfect combination. Just many ways to get about the same results.
This was an experiment to see if I could improve my gas mileage. And I did that without spending much. |
I would think the TQ is suffering because of to much duration for the small capacity, I would have gone for a smaller cam with more lift. _________________ (06:31:07) RoachGhia: "i drink dick way too fast" |
Posted: Mon May 21, 2012 2:40 am Post subject: |
Not true, it has good torque for what it is, a 1300. The FK-65 cam has a lot of duration.(280deg.) But a lot of the duration is before and after.050 lift. That just bleads off some of the compression and is very gentle on the valve train. That is why I raised the compression to 8.1 running on regular fuel. The running duration is only [email protected] lift.
If I was buying a cam for the 1300, I would have used something else. The FK-65 was just laying around and I felt it would work in this engine with 1.1 rockers.
Like I said, this engine was built mostly from parts I had. I spent very little to build it. That doesn't mean that it was not well thought out. A lot of machine work went into this project so all the parts would work well together.
I would like to put the car on a dino to see what the horsepower and torque numbers are. Instead, I'll spend that money on gas to go somewhere. |
Posted: Wed Aug 15, 2012 4:13 am Post subject: |
Update on engine......With over 5000 miles on it now, everthing is working well. Mileage and power has not droped off. I think the overlap of the cylinders will not be an issue. Engine heat has not been a problem in this hot summer. Normal oil changes and valve adjustment show no problems. I tried tuning for higher mileage, have not found anything to improve it. I'm using 135 mains in the Kad's. Tried 130's and the mileage fell off and the heat incressed too much. I am going to try smaller venturis when I find a set, might improve velosity of mix.
Average mileage has stayed at 37mpg. Back roads are no problem, but when running on the expressway it must stay under 3300rpm to keep mileage up. That means at 65mph speed limit. Mileage drops off fast if running with traffic at 70mph.
Lady friend and I are heading for the shore again in a few weeks. Hoping to gain a little more mileage with flatter roads and lower elevation.
Happy motoring............ |
Posted: Wed Aug 15, 2012 7:25 am Post subject: |
That is excellent fuel mileage! With 5,000 miles on your motor, now is a good time to change to a quality synthetic motor oil like Redline..... _________________
Mitey62 wrote: |
Posted: Wed Aug 15, 2012 9:57 am Post subject: |
bugguy076 wrote: |
Good mpg numbers.
When trying for better figure why were you changing the mains? cruise is done on idles.
when you do a jet change and go leaner you will also probably need to alter timing as leaner mic likes more advance, so your higher temps could have been from the new fuel air ratio not being liked by the old timing.
Any idea or your idle and main air fuel ratios? _________________ (06:31:07) RoachGhia: "i drink dick way too fast" |
andy198712 Samba Member
Joined: December 05, 2010 Posts: 1209 Location: Cornwall - UK
Posted: Wed Aug 15, 2012 10:45 am Post subject: |
My stock 1200sp went from mid to low 20's uk mpg, I used megasquirt to control the crank fired ignition and I now get 37mpg driving the same places and speeds, thats like 50% better!!! |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7182 Location: Videbaek Denmark
Posted: Wed Aug 15, 2012 11:25 am Post subject: |
Hello.
Yes, very nice results.
I think the reason to why the edge is so apparent at about 3300 rpm wrt fuel consumption, is that that is where the engine begins to really suck from the main circuit in the carbs. To even that out you will have to bump the CR so the engine gets more efficient in that range. But then you will most likely not be able to run on 87 pump gas anymore. You could also reduce the venturi size to 26 mm. Then the overlap becomes much more soft. But you will be in for a serius rejet to get it right.
A stock vacum distributor will not work that well with the vacum system of the Kadrons. It can of course be made to. - Take a deep look at a late model type 3 distributor, and copy the spring tension from that one, or simply use one. That will get you a long way in the right direction.
T |
