porschpow Samba Member
Joined: May 21, 2005 Posts: 1058 Location: Hamilton, NJ / Flanders, NJ
Posted: Mon Apr 30, 2012 11:46 am Post subject: Greasing up rubber hoses |
I need to get the 12mm hose onto the midle top of the fuel tank (vapor/overfill) COuld you use Grease without it breaking down the rubber?? Is this a danger. I mean obviously you just use a little bit, but I am worried that if I do this the grease might shorten to life of the rubber. Any thoughts??? _________________ -1973 Volkswagen Bus Westy (Weekender)
1.8 liter from 1.7(original)
-2011 Subaru Outback
-1986 Honda Magna |
mikewire Samba Member
Posted: Mon Apr 30, 2012 11:51 am Post subject: |
I use carb spray or silicone spray. CRC brand in the red bottle, it's magic! _________________ 1972 9 Passenger Deluxe Non-Walkthrough | 2003 Audi A4 Avant 1.8TQT REVO Stage 2 | 2000 VR6 Jetta Bright Green Pearl | 1980 Lago Caddy JH 1.8 CIS
My 1972 Deluxe build thread
www.bigskyeuro.com |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 5383 Location: Edmonds, WA.
Posted: Mon Apr 30, 2012 12:00 pm Post subject: |
dude. rename this thread to "lubing up rubber" ....hahahaha  _________________ MINE - 1978 Westfalia ~ Maisy ~ FI, Hydraulic Valves, Electronic Points, 2.0 (NEED A SET OF HEADS, PM ME IF YOU HAVE A SET)
DAD's - 1972 Westfalia ~ Sticky ~ 1.7(?) 914 motor, allison electronic ignition, electric fuel pump, dual webers w/o choke.
“Don't cry because it's over, smile because it happened.”
“Those who mind don't matter, and those who matter don't mind.” |
hazetguy Samba Member
Posted: Mon Apr 30, 2012 12:18 pm Post subject: |
Yeah unfortunately the nearest NAPA is far from me. There is an Autozone near me
Would the CRC (carb/silicone spray) ruin the rubber ???
Only reason is that my dad always used grease for everything, lol _________________ -1973 Volkswagen Bus Westy (Weekender)
-1986 Honda Magna |
skills@eurocarsplus Samba Member
Joined: January 01, 2007 Posts: 3954 Location: sticksville, ct.
Posted: Mon Apr 30, 2012 12:20 pm Post subject: |
X2 for the carb or brake clean trick. It will help hoses slide on and evaporate after a minute. Imho if you use any kind of lube you run the risk of it breaking down the rubber or popping off because it is so slick. _________________
| VWsArent4Hippies wrote: | | Whenever I click on the baywindow forum I feel like I'm entering a place where most people have no sense of reality |
| schell '59 wrote: | | The honor system works for boy scouts..not in real business |
| modok wrote: | | It was in the instructions back when stuff came with instructions |
| curtis4085 wrote: | | as most your information you give is crap anyway |
| bugger101 wrote: |
skills, you never win with cheap vw people |
| This is a fine use for WD40. Good old soapy water may work as well, but can cause rust in places. |
ewdb92 Samba Member
Joined: September 24, 2010 Posts: 185 Location: Fredericksburg VA
Posted: Mon Apr 30, 2012 12:55 pm Post subject: |
I always had good luck with windex for foam and rubber components (esp the front engine compartment seal) _________________ Erik
71 Camper
http://zerotosixtyeventually.wordpress.com/ |
nathansnathan Samba Member
Joined: April 14, 2008 Posts: 1219 Location: Laguna Beach, CA
Posted: Mon Apr 30, 2012 1:41 pm Post subject: |
| Wildthings wrote: | | This is a fine use for WD40. Good old soapy water may work as well, but can cause rust in places. |
WD40 is mostly derived from mineral oil which is a petroleum product and will degrade rubber. Afaik there are no good uses of WD40. |
ccpalmer  Samba Member
Joined: September 17, 2006 Posts: 3518 Location: Ann Arbor, Michigan
Posted: Mon Apr 30, 2012 1:48 pm Post subject: |
| ewdb92 wrote: | | I always had good luck with windex for foam and rubber components (esp the front engine compartment seal) |
I've heard that windex is bad for window rubber... _________________ '71 Westy
'77 Bay/rusty shed on wheels
Chris Palmer
Cocobolo Co., LLC
ccpalmer.com |
RatCamper Samba Member
Joined: November 13, 2008 Posts: 3307 Location: Australia
Posted: Mon Apr 30, 2012 1:50 pm Post subject: |
Am I the only one that uses a container of near boiling hot water for rubber hoses? I had to use that trick on brake booster hose, fuel hoses and various others. The booster hose was especially fun. I used it to replace the black plastic ones, but the largest size available was a couple of mm too small. Got it on anyway. Still sealed perfectly years on. It makes the rubber really soft briefly so you have to work fast. _________________ Vehicle: 1975 Special order delivery walkthrough panel based pop-top camper (LCA / Sunliner). Motor: Nippon 1.8L Single port Wasserboxer, Transmission: 3 rib 002. |
Posted: Mon Apr 30, 2012 1:55 pm Post subject: |
| RatCamper wrote: | | Am I the only one that uses a container of near boiling hot water for rubber hoses? I had to use that trick on brake booster hose, fuel hoses and various others. The booster hose was especially fun. I used it to replace the black plastic ones, but the largest size available was a couple of mm too small. Got it on anyway. Still sealed perfectly years on. It makes the rubber really soft briefly so you have to work fast. |
Sounds like a great idea. Just be sure to completely dry things off - heat gun could also work or a hair dryer to be safe. _________________ '71 Westy
Chris Palmer
Cocobolo Co., LLC
ccpalmer.com |
ewdb92 Samba Member
Posted: Mon Apr 30, 2012 2:35 pm Post subject: |
| ccpalmer wrote: | | ewdb92 wrote: | | I always had good luck with windex for foam and rubber components (esp the front engine compartment seal) |
I've heard that windex is bad for window rubber... |
Never heard that before. Might depend on how often and how much you use. So far I have not had any issues with the rubber degrading. _________________ Erik
71 Camper
Posted: Mon Apr 30, 2012 2:45 pm Post subject: |
| ewdb92 wrote: | | ccpalmer wrote: | | ewdb92 wrote: | | I always had good luck with windex for foam and rubber components (esp the front engine compartment seal) |
Never heard that before. Might depend on how often and how much you use. So far I have not had any issues with the rubber degrading. |
I think the ammonia is said to dry out rubber. _________________ '71 Westy
Chris Palmer
Cocobolo Co., LLC
ccpalmer.com |
Posted: Mon Apr 30, 2012 2:46 pm Post subject: |
| ccpalmer wrote: | | RatCamper wrote: | | Am I the only one that uses a container of near boiling hot water for rubber hoses? I had to use that trick on brake booster hose, fuel hoses and various others. The booster hose was especially fun. I used it to replace the black plastic ones, but the largest size available was a couple of mm too small. Got it on anyway. Still sealed perfectly years on. It makes the rubber really soft briefly so you have to work fast. |
Sounds like a great idea. Just be sure to completely dry things off - heat gun could also work or a hair dryer to be safe. |
That's true. Heat gun could be risky. Hair dryer would take a while but should work.
Honestly I've found the traces of water on the hoses evaporate off pretty quickly if the water is hot enough. I can see where trapped moisture could be an issue in some circumstances though. I mean a few stray molecules of water don't bother me if they get trapped between a reinforced hose and a brass barb fitting, but when it's a ferrous fitting it is a slightly different story. _________________ Vehicle: 1975 Special order delivery walkthrough panel based pop-top camper (LCA / Sunliner). Motor: Nippon 1.8L Single port Wasserboxer, Transmission: 3 rib 002. |
Posted: Mon Apr 30, 2012 2:47 pm Post subject: |
| RatCamper wrote: | | ccpalmer wrote: | | RatCamper wrote: | | Am I the only one that uses a container of near boiling hot water for rubber hoses? I had to use that trick on brake booster hose, fuel hoses and various others. The booster hose was especially fun. I used it to replace the black plastic ones, but the largest size available was a couple of mm too small. Got it on anyway. Still sealed perfectly years on. It makes the rubber really soft briefly so you have to work fast. |
Honestly I've found the traces of water on the hoses evaporate off pretty quickly if the water is hot enough. I can see where trapped moisture could be an issue in some circumstances though. I mean a few stray molecules of water don't bother me if they get trapped between a reinforced hose and a brass barb fitting, but when it's a ferrous fitting it is a slightly different story. |
As long as the water was actually boiling it should dry out very quickly. _________________ '71 Westy
Chris Palmer
Cocobolo Co., LLC
ccpalmer.com |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 733 Location: Seattle, WA
Posted: Mon Apr 30, 2012 3:14 pm Post subject: |
If the hose is suitable for use with gasoline and its vapors, how could a little grease hurt it? _________________ '67 bug: seized by the authorities
'71 kombi: not yet seized by the authorities |
Posted: Mon Apr 30, 2012 3:18 pm Post subject: |
how much was the bushing? a 2 dollar at most piece of rubber? use spit, and if that eats the rubber...buy another one...  _________________ MINE - 1978 Westfalia ~ Maisy ~ FI, Hydraulic Valves, Electronic Points, 2.0 (NEED A SET OF HEADS, PM ME IF YOU HAVE A SET)
Posted: Mon Apr 30, 2012 3:30 pm Post subject: |
| Stuartzickefoose wrote: | how much was the bushing? a 2 dollar at most piece of rubber? use spit, and if that eats the rubber...buy another one...  |
It's the 90 degree breather/vapor hose on the top of the fuel tank ('72 and early '73 IIRC), behind the firewall, where you won't easily see it and/or replace it. Do it once, the right way, and you won't mess with it for a long time. _________________ 1972 9 Passenger Deluxe Non-Walkthrough | 2003 Audi A4 Avant 1.8TQT REVO Stage 2 | 2000 VR6 Jetta Bright Green Pearl | 1980 Lago Caddy JH 1.8 CIS
Posted: Mon Apr 30, 2012 3:31 pm Post subject: |
| mikewire wrote: | | Stuartzickefoose wrote: | how much was the bushing? a 2 dollar at most piece of rubber? use spit, and if that eats the rubber...buy another one...  |
It's the 90 degree breather/vapor hose on the top of the fuel tank ('72 and early '73 IIRC), behind the firewall, where you won't easily see it and/or replace it. Do it once, the right way, and you won't mess with it for a long time. |
got it.  _________________ MINE - 1978 Westfalia ~ Maisy ~ FI, Hydraulic Valves, Electronic Points, 2.0 (NEED A SET OF HEADS, PM ME IF YOU HAVE A SET)
