Phildor Samba Member
Joined: April 24, 2011 Posts: 53 Location: Norwalk, OH
Posted: Tue May 01, 2012 5:40 pm Post subject: Stripping out the threading on water pump |
I'm trying to reattach the thermostat housing to the water pump on my 84. Each time I try to thread the bolts that run through the housing into the pump, they begin to tighten before snapping into free rotation and, as I can see upon removing them, taking the threading of the water pump with them.
I don't understand what has caused the aluminum to weaken or what I should do about this. I didn't remove the water pump as part of my original project, doing the cylinder heads. Any advice or input would be helpful. Thanks. _________________ '84 Vanagon GL 4-speed |
IdahoDoug Samba Member
Posted: Tue May 01, 2012 5:49 pm Post subject: |
I don't know what others will suggest, but I would personally take the bolt to a machine shop and come home with a thread cleaning tool. Some call it a thread chaser and there are other names. It's intended to clean existing threads, not cut new ones so it's fairly easy to use.
DougM _________________ Two fully locked 80 Series LandCruisers. 2013 Subaru Impreza boxer. 1990 Audi 90 Quattro 20V |
rubbachicken Samba Member
Joined: October 05, 2004 Posts: 1531 Location: nesting in socal
Posted: Tue May 01, 2012 6:35 pm Post subject: |
if you have enough aluminum to tap the thread deeper into, then do it that way, other than that you will need to use a thread insert like a helicoil, or if you can find someone to do it, a wurth, timesert, they are the best i've used _________________ lucy our westy
lucy's BIG adventure
lucy is 1985, with 2.1 Digifant, 4 speed manual
nesting in socal |
Posted: Fri May 04, 2012 11:51 am Post subject: |
I'm going to run a tap through both spots.
Thanks for the input, guys. _________________ '84 Vanagon GL 4-speed |
70coupyel Samba Member
Joined: September 06, 2006 Posts: 1224 Location: So.Cal
Posted: Fri May 04, 2012 11:57 am Post subject: |
Get a bottom tap. Or grind off some of the lead on a standard tap to get full threads deeper into the hole. _________________
| TheAndante wrote: | | Saying that specs are different than dimensions doesn't make sense. Porsche specs/VW specs/engineering specs are nothing but a series of dimensions,sizes,percentages,measurements, etc. |
70 KG Coup
83 Westy Waterboxer |
