theDrew Samba Member
Joined: May 17, 2011 Posts: 297 Location: Vancouver, WA
Posted: Fri May 04, 2012 10:52 am Post subject: |
and how much should I put in my 1.9? _________________ 1985 Vanagon Campmobile w/ 2005 EJ253 SOHC
1974 Super Beetle |
kamzcab86 Samba Member
Posted: Fri May 04, 2012 11:36 am Post subject: |
| theDrew wrote: | Can some one spell out to me exactly what I do with MMO? When, how long, etc?
Put it in a run it for a bit BEFORE the oil change? Or put it in after with fresh oil? |
I put in between 4-8 oz. of MMO with every oil change (i.e. it goes in with fresh oil). Two years now and rarely a clatter from my 2.1.
Edit: Had wrong amount (forgot there are two sizes of MMO bottles). _________________ ~Kamz
2000 Jetta VR6
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 2080 Location: Cascadia
Posted: Fri May 04, 2012 11:50 am Post subject: Lifter (not oil) thread update |
Tick came back on my off brand car, but then again it's a diesel with a whole different lifter arrangement--more akin to inline VW lifters. Fired up the van and it ticked for like one full revolution and then silenced. _________________ --Casey
'89 Bluestar
"Endeavor to persevere" |
Terry Kay Samba Member
Joined: June 22, 2003 Posts: 6959 Location: "The No Spin Zone"
Posted: Fri May 04, 2012 12:48 pm Post subject: |
Seeing as how your not driving the Van every day the lifter's are bleeding off.
Do the Van a favor and drive it more,& the lifter's won't be clacking on start up.
It's a major design flaw, and the best you can do is run a quart of MMO in the oil 24/7/365.
It'll improve the weak lifter arragement as much as possible---other than having some non-draining lifter's manufactured. _________________ T.K.
http://community.webtv.net/VanStuff/VanagonWestfalia
http://community.webtv.net/VanagonUsedParts/VanagonParts
"Ingorance Is A Powerful Tool If applied at The Right Time, Even Usually Surpassing Knowledge"
(E.J. Potter) |
riceye Samba Member
Joined: March 09, 2006 Posts: 1158 Location: Caledonia, WI
Posted: Fri May 04, 2012 6:41 pm Post subject: |
On the upside, STP adds ZDDP to the oil. I add it to top up when changing the filter after the first 5000 miles on my 8-10,000 (annual) Mobil1 15w-50 oil change interval. Good for the next 3-5000 miles.
MMO a hundred miles or so before an oil change. Happy lifters. _________________ '87 Westy Weekender - daily driver on salt-free roads
'96 4runner-latest winter beater. The '98 Tacoma 4x4 rusted out!
There's gonna be some changes made. |
nemobuscaptain Samba Member
Posted: Fri May 04, 2012 6:44 pm Post subject: Re: WBX lifter clatter |
| Zeitgeist 13 wrote: | My van isn't a daily driver by any stretch, and is really more of a weekend warrior intended for hauling all manner of hardware and junk as required. Because it sits for extended periods of time, it can frequently experience the annoying lifter bleed-down syndrome. Based upon some recommendations I'd received from reputable folks, I bought some STP to address this condition. I poured the stuff in and let it sit overnight. When I started it up in the morning, there was not one hint of lifter tick to be found. I also poured a jar in my other off-brand vehicle which has roughly the same amount of miles and a slight lifter tick. The result of both applications: No ticks.
YMMV |
What weight oil were you running before you put the sludge in? _________________ Nemo, 91 Multivan, Cincy
Win the Raffle Bus from Salem Imports!!!!! http://www.naturalbus.net/naturalbus.net/Rafflebus.html
www.Fullmoonbusclub.com
http://autos.groups.yahoo.com/group/ohiovalleytribe/
My favorite youtube site these days for learning auto body basics: https://www.youtube.com/user/ButlerCollision?feature=watch |
Posted: Fri May 04, 2012 7:23 pm Post subject: |
I run Delo 15w40 in all my rigs...ugh, we're talking about oil again. _________________ --Casey
'89 Bluestar
Posted: Fri May 04, 2012 8:12 pm Post subject: |
Guess what??? There are directions on the bottle.  |
Posted: Fri May 04, 2012 8:15 pm Post subject: |
| As far as I am concerned the best long term solution is to run synthetic oils. It is all the broken down burned up additives that create the slug and varnish that coats engine parts. Since synthetics require far fewer additives you get far less crud building up in your oil. |
Posted: Fri May 04, 2012 8:17 pm Post subject: |
| riceye wrote: | On the upside, STP adds ZDDP to the oil. I add it to top up when changing the filter after the first 5000 miles on my 8-10,000 (annual) Mobil1 15w-50 oil change interval. Good for the next 3-5000 miles.
MMO a hundred miles or so before an oil change. Happy lifters. |
Have you checked the amount of ZDDP in STP lately? The last time I checked (which was 3-4 years ago) it was about the same as SN save the catalyst motor oils. |
morymob Samba Member
Joined: November 09, 2007 Posts: 2737 Location: east-tn
Posted: Sat May 05, 2012 3:53 am Post subject: |
| I put a pint in each change and leave it there, oil change due so i'm leaving the MMO out and see, also T.K. i agree about no STP in oil, only rod brng i ever spun had that in the oil,??, never again,not a vw eng tho. |
Posted: Mon May 07, 2012 11:16 am Post subject: Update on the update |
The van's sat for the last few days. I just fired it up and the clattah is back.
Soooo...
Snake oil #1: fail
I like what some folks mentioned about trying Snake oil #2, in order to remove the build up of varnish, so I may try that during my next oil change. _________________ --Casey
'89 Bluestar
RicoS Samba Member
Posted: Mon May 07, 2012 11:20 am Post subject: |
| insyncro wrote: | | . . . I use straight K1 to clean the internals....essentially MMO without the red dye. |
OK, I give. What in the hell is K1?
Richie |
Posted: Mon May 07, 2012 11:22 am Post subject: |
kerosene _________________ --Casey
'89 Bluestar
dhaavers Samba Member
Joined: March 19, 2010 Posts: 2064 Location: http://g.co/maps/zt72q
Posted: Mon May 07, 2012 11:23 am Post subject: |
K1 = highly refined low sulfur kerosene (like super clean diesel fuel) _________________ 86 White Westy Weekender
"The WonderVan" |
Posted: Mon May 07, 2012 11:55 am Post subject: |
Get the oil out of it, fill it with K-1, K-2, K-3 --who cares?
Clean the crap out a the engine, re-load wih the right oil--short yourself one quart so the Marvel will fit--and run the hell outa it.
Then cross yor finger's that whoever, wherever you got the thing from did't flog it to death & never serviced it.
These engines are known to rattle afer sitting awhile anyway.
The lifter's will bleed down, compounded by ( now ) glue in the crankcase.
Clean it out, run marvel all the time in the oil & the possibilites of the lifter's rattling will lessen--maybe it will go bye-bye.
Clean is good, gluing it up is bad. _________________ T.K.
(E.J. Potter)
Posted: Mon May 07, 2012 12:05 pm Post subject: |
I've owned the van since '04 and purchased it from the original owners. It just needs to hang on until I have time/money to drop the Audi V6 in there. _________________ --Casey
'89 Bluestar
Posted: Mon May 07, 2012 6:05 pm Post subject: |
| Zeitgeist 13 wrote: | | I run Delo 15w40 in all my rigs...ugh, we're talking about oil again. |
Well, there are basically two potential problems, crud or wear. When those lifters wear you get to the point of needing heavier oil. I had a WB that would clatter unless I ran SAE30, despite numerous attempts at cleaning it with MMO/CD2/ATF and all that other stuff. Only switching to a thicker oil worked.
When you are talking about hyd lifters, it's hard to avoid talking about oil. There are plenty of people out there running 5w30 or 0w20 (because that's what they ran in their Honda) who can't figure out while their lifters clatter in their 30 year old VW bus. _________________ Nemo, 91 Multivan, Cincy
Posted: Mon May 07, 2012 6:25 pm Post subject: |
| nemobuscaptain wrote: | | Zeitgeist 13 wrote: | | I run Delo 15w40 in all my rigs...ugh, we're talking about oil again. |
When you are talking about hyd lifters, it's hard to avoid talking about oil. There are plenty of people out there running 5w30 or 0w20 (because that's what they ran in their Honda) who can't figure out while their lifters clatter in their 30 year old VW bus. |
There are plenty of people that run 20w50 and can't figure out why their lifters clatter in the 30 year old VW either. |
