Another '69 Coupe joins the gang
Endopotential
Endopotential is offline
PostPosted: Thu May 03, 2012 11:26 pm    Post subject: Another '69 Coupe joins the gang Reply with quote
Hi all,
After months of soaking in your collective experience and laughs, I finally took the plunge and got a '69. Picked it up in LA, and brought it up to SF. Happily she (is there consensus that all Ghia's are girls? Very Happy ) still has the original black California plates.
Thanks for providing such a great forum. Enjoy!
Here it is in SoCal getup, at the PO's home. I didn't get to take home the K5, sadly.
At her new home in foggy Pacifica.
I'm thinking she looks better with a cleaner look.
I know you purists out there will groan, but I think the PO did a fine job with the interior. Clean, but restrained. And oh, such comfy seats.
Last edited by Endopotential on Fri May 04, 2012 10:55 pm; edited 3 times in total
Endopotential
PostPosted: Thu May 03, 2012 11:31 pm    Post subject: Dynamite! Reply with quote
One of the selling points for me was also that the PO really cleaned up the interior metal. It was sanded down, covered in POR 15 throughout, and then plastered with some fancy tin foil. I haven't driven in a whole lot of other Ghia's for comparison, but the ride is pretty reasonable for a 40 year old car.
Though I have read that some of you are against gluing anything down to the floor boards given moisture concerns?
Your thoughts?
61 BUS Premium Member
61 BUS is offline
PostPosted: Fri May 04, 2012 7:11 am    Post subject: Reply with quote
Though I'm a bit of a purist myself (the Porsche seats in my 74 notwithstanding), I do like this car. The black exterior paint looks great on a Ghia. It does take some guts to paint a car gloss black, as every little ding and dent will show up when it's done. Very nice.
I would be inclined to remove the foil from the floor if it is glued on and replace it with something that can be easily taken out to dry the floor if (when) you get a few leaks.
61 Bus, 76 Porsche 911, 84 Porsche 928, 07 Porsche Cayman
mlhsquared
mlhsquared is offline
PostPosted: Fri May 04, 2012 7:33 am    Post subject: Reply with quote
Although I don't disagree with 61 Bus, if you choose to remove it, that will be a chore. That stuff really sticks well.
Nice car, and I also like the "cleaner" look better.
Mike
'67 Ghia Coupe "Lumpy"
The Panhandle Aircooled Club: www.panairvws.com
rusty57
rusty57 is offline
PostPosted: Fri May 04, 2012 7:49 am    Post subject: Reply with quote
Leave the dynamat in there. Much quieter ride. Inspect the area frequently and dry it out( vent it ) once in a while. Make sure there's a drain hole. Perhaps the POR-15 will do its job.
67 Ghia coupe
www.TagDefender.com
sactojesse
sactojesse is offline
PostPosted: Fri May 04, 2012 9:54 am    Post subject: Reply with quote
Nice car! I recall checking it out in the classifieds and liking pretty much everything about it except for the upholstered dash. I used to own a 1969 ghia coupe for nearly 20 years and was daydreaming about getting another one. Best year for a driver ghia, IMO. 1st year of the IRS and last year of the small taillights and front blinkers. Smile
1966 Karmann-Ghia convertible
mstencel
mstencel is offline
PostPosted: Fri May 04, 2012 11:20 am    Post subject: Reply with quote
Nice Ghia! Nice K5, too. I had an 89 K5. I miss that truck. In the 5 years I had it, it never let me down.
Greezy Joe
Greezy Joe is offline
PostPosted: Fri May 04, 2012 4:26 pm    Post subject: Reply with quote
Nice find Very Happy
Current:74 Ghia Coupe w/ 2276
71 Ghia Vert w/ 1835
07 GMC Truck
04 Chrysler Crossfire
73 Harley FLH 93 cid
89 Harley 883 Sportster (1200)
Owned before: 58, 69 Ghia Coupes, 64 Canvas Sunroof, 68, 72, 73, & 74 Bugs, 63 Single Cab, 65 Bus, 66 & 70 Camper
"You have to be smarter than what you're working on"
swavananda
swavananda is offline
PostPosted: Fri May 04, 2012 4:48 pm    Post subject: Reply with quote
nice one
that looks like a black mamba shifter, very pricey. what is the engine set up ? if they installed that shifter , i'm sure they put other top end parts as well
Basketcase
Basketcase is offline
PostPosted: Fri May 04, 2012 5:15 pm    Post subject: Reply with quote
that is sweet! I like the cleaner look too.
Endopotential
PostPosted: Fri May 04, 2012 9:10 pm    Post subject: Reply with quote
swavananda wrote:
nice one
Thanks all for the kind comments and input.
Dang, I'm constantly amazed how sharp your eyes are. Black Mamba indeed. Worked a lot better after I replaced that shift rod bushing though!
So far I've managed to replace the window rubber and heater boxes. No more choking on fumes, hurrah! Couldn't have done it without all the fine reads on this forum.
Shifter was the most "bling"ed out part of the car, I'm afraid. Engine is a basic 1776cc dual port, dual Solex carb. For those other sharp eyes out there, yes it has an upgraded alternator.
Endopotential
PostPosted: Fri May 04, 2012 9:13 pm    Post subject: Reply with quote
The K5 unfortunately didn't come with the Ghia, bummer.
Though I think the little guy could've fit underneath that monster truck.
Now how much collective crap would I get from the group for mounting swan neck mirrors??? I like the older, more classic look and it balances out the empty right side of the car.
Basketcase
PostPosted: Sat May 05, 2012 2:24 am    Post subject: Reply with quote
your car
your $$
do what makes you happy
Rome
Rome is offline
PostPosted: Sat May 12, 2012 4:41 pm    Post subject: Reply with quote
You won't get any crap from me. Although my '64 Ghia came with the swan neck mirror on the driver's front cowl, I relocated it to the front edge of the door. Then added a matching one on the passenger door. Since the mirror is much closer, you see a bit more than if it were in that "far away" stock location for '64. And having a matching one on the right door enables you to also actually see something out of it. If you try to install a swan mirror on the right side cowl to match the original factory location on the left cowl, the field of vision is blocked by the windshield post. On your '69 I think the swan mirror would go well.
Do you still have the driving lights? Might want to reconsider installing them for nighttime driving, or for FLASHING slowpokes out of the left lane when you come up on them with your 1776.
Here's my '64 with driving lights and the L&R mirrors-
ovghiaguy
ovghiaguy is offline
PostPosted: Sat May 12, 2012 5:40 pm    Post subject: another 69 Reply with quote
for the carpet I used industrial velcro I got at home depot so the carpet can be removed if need be. works great.
61 BUS is offline
PostPosted: Sun May 13, 2012 4:42 pm    Post subject: Reply with quote
I just noticed that you're in Pacifica.....I grew up there. Lived up on the hill in Fairmont. Smile
Endopotential
PostPosted: Sun May 13, 2012 10:50 pm    Post subject: Reply with quote
Small world! Though I'm sure you're enjoying the endless sun in AZ, instead of our incessant fog.
That's a heck of a stable of cars you keep! How in the world do you ever decide which one to drive? Laughing
Endopotential
PostPosted: Sun May 13, 2012 10:53 pm    Post subject: Swan neck mirrors Reply with quote
Hi Rome,
Any chance you can post some close up pics of where you mounted your mirrors? And how did you go about filling in the hole where the original mirror was located?
Rome
Rome is offline
PostPosted: Wed May 16, 2012 3:29 pm    Post subject: Reply with quote
Here you go. Front tip of mirror base is 1" straight/level back from door front edge. Widest part of base at top is 1/2" straight down from the chrome trim.
When I relocated the mirror back in '85, I simply filled in the two small cowl holes from the original mirror location with filler. Might've been a dab of "gorilla hair", with fine filler on top.
