Annealing copper on exhaust manifold rings
Jockomo
Jockomo is offline
PostPosted: Fri May 04, 2012 9:44 am    Post subject: Annealing copper on exhaust manifold rings Reply with quote
Mr. Atwell suggests annealing the copper rings before installing them:
Use an infrared gun to measure the surface temperature of the rings by moving the flame away for a moment and once you hit 900F
I don't have an infrared gun to measure the temperature, any suggestions as to how to tell when I get to 900? I guess I can try over and over until it doesn't ring when tossed on the ground, however I don't want to damage the ring.
suggestions?
'75 Westy with '78 2.0L engine.
SGKent
SGKent is offline
PostPosted: Fri May 04, 2012 9:46 am    Post subject: Reply with quote
it will turn colors. Heat gun at HF is inexpensive and useful in other places
Steve aka Merlin the Wrench
formerly Steve's Racing and Engine Blueprinting. Wrenching since 1967.
bdamico on GF wrote
"When I was your age I'd plan out all sorts of stuff for the future and almost none of them came true. Just wonder if it's worth trying to be a crystal ball. "
Mal evolent
Mal evolent is offline
PostPosted: Fri May 04, 2012 10:13 am    Post subject: Reply with quote
old schol English motorcycle technique: heat it in a fllame til it's orange and drop it in a pan of water.
73 Beetle, Ghia front brakes, Type 3 rear brakes, 1776, Solex 34 Pict-3, Bosch SVDA, '97 Mustang seats
[77 Westy M plate decoded]
Baja Bugs for Volkswagen Virgins: Index
WyzeOwl
WyzeOwl is offline
PostPosted: Fri May 04, 2012 10:53 am    Post subject: Reply with quote
Correct me if I am wrong, but I believe that if you want to anneal (soften) the copper you should let it air cool. Dropping it in water will temper it thus hardening the copper.
mtcamper
mtcamper is offline
PostPosted: Fri May 04, 2012 11:19 am    Post subject: Reply with quote
Drop them on the ground before and the noise it makes when it hits the ground is very metallic, after annealing them they just make a thud sound when dropped
Wildthings
Wildthings is offline
PostPosted: Fri May 04, 2012 1:52 pm    Post subject: Reply with quote
I just don't buy that this needs to be done. I guess if the bore up in the heads is really bad it might be needed, but if everything is close to original spec it should not be necessary.
File the flanges flat with a big bastard file and then round the edges of the flange a bit with a smaller one and you should be set.
VDubTech
VDubTech is offline
PostPosted: Fri May 04, 2012 2:28 pm    Post subject: Reply with quote
You're wrong. Heat it up red hot, drop it into a pan of water and you're ready to go. Drop one on the ground that isn't annealed and drop an annealed one, you'll hear the difference in the tone. I always do this when installing an exhaust and haven't had a leak yet.
If you do it on a concrete floor, once the concrete pops, it's hot enough, drop it in the water.
As for whether it's necessary, everything I have read says to do it. It takes 5 minutes and I've never had an exhaust leak at the head using this method. Little extra insurance never hurt anyone. Makes sense to me that a softer copper gasket would seal better.
First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote:
a measurement of your rod would be extremely useful.
notchboy wrote:
my dad wasnt a belittling cock when he tought me how to wrench on cars.
One photo = good for reference.
10 photos = douchebaggery
SGKent
SGKent is offline
PostPosted: Fri May 04, 2012 3:16 pm    Post subject: Reply with quote
don't drop it from too high, they will bend when they are soft. It is a super tip for anyone building a T4 engine. It was something I would not have guessed had not the old pros like Richard or VDubTech, BusDaddy etc pointed it out when I first came back to buses and bought a T4 bus.
VDubTech
VDubTech is offline
PostPosted: Fri May 04, 2012 3:18 pm    Post subject: Reply with quote
Good point Steve, definitely worth mentioning.
Jockomo
Jockomo is offline
PostPosted: Fri May 04, 2012 3:25 pm    Post subject: Reply with quote
Thanks guys, you are all awesome.
Smile
Millennium Falcon
Millennium Falcon is offline
PostPosted: Fri Oct 19, 2012 6:47 am    Post subject: Reply with quote
Are there any tips for removing the copper rings from the cylinder heads?
I have my heater boxes and exhaust off in order to file and even up the manifold mating surface but the old copper rings are remaining firmly in place. Seems like a pretty soft area to dig them out of with out causing a bit of damage.
"Don't worry, she'll hold together . . . You hear me, baby? Hold together!" -Han to the Falcon
1972 White Campmobile
1700 cc Type IV
Dual Solex 34 PDSIT2/3
busdaddy
busdaddy is offline
PostPosted: Fri Oct 19, 2012 7:03 am    Post subject: Reply with quote
There's a few ways to go at it, pry bars like this can often get under the inside edge when the bar is placed across the port:
Or dinging it with a dull screwdriver or chisel across the middle of the straight sides of the oval can bend the ring enough to lift the rounded ends.
Wanted, 68-73 westy OG plaid curtains, singles OK.
Millennium Falcon
PostPosted: Fri Oct 19, 2012 7:09 am    Post subject: Reply with quote
Thanks for the good ideas to work with. Thanks busdaddy.
1700 cc Type IV
