evilphoton Samba Member
Joined: March 16, 2012 Posts: 284 Location: San Diego, CA
Posted: Wed May 09, 2012 10:21 am Post subject: |
if you're running the OG pressure plate, the fulcrums where the 3 arms pivot could be worn to the point that the arms are bottoming out on the pressure plate without putting enough pressure on the diaphragm spring to pull the plate away from the flywheel.
if you take it apart again, check for new shiny marks where the arms have been pushing against the pressure plate, if they're there, you need a new plate.
no freeplay would mean that you are into the "release" part of the clutch travel, that would bring the "friction point" closer to the top of the pedal travel. if that's where you are, either the cable has magically stretched or the throwout bearing doesn't have anything else to push against. |
notimp57 Samba Member
Posted: Wed May 09, 2012 11:50 am Post subject: new clutch now won't shift into gear |
Searching the internet came upon your page with the same problem I have 1968 VW semi automatic after we sealed engine put in new disc wont shift.
Just took engine out for third time searching for clues found the converter had lost the splines. now I am looking for a converter to replace the damage one any places where I canI buy one that will ship to Puerto Rico. |
troutbite Samba Member
Posted: Wed May 09, 2012 7:29 pm Post subject: |
| Problem solved...thanks for all the advice and taking time to help! The issue turned out to be the new clutch. I pulled the engine last night and took a thickness measurment on the clutch, with that I went to the local VW shop and referenced it against a new clutch they had on the shelf, the clutch I installed was about 0.5mm thicker...I had already checked the flywheel and it had been machined correctly, the pressure plate worked great prior to the new clutch install so the only thing it could be (I was hoping) was a thick clutch. Installed differerent new clutch tonight and there you go...shifts great. HArd to imagine that little difference could be such a problem. |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 5690 Location: (West) Tokyo, Japan
Posted: Wed May 09, 2012 7:36 pm Post subject: |
This was a problem a while back... new clutch discs too thick. What brand was it? Maybe you got one that had been sitting on a shelf for a while? _________________ AshMan40
'75 Beetle 1200LS (RHD)
"stock" 1600 w/ 34 PICT-3 carb & S/A tranny |
Posted: Wed May 09, 2012 7:39 pm Post subject: |
| It was a Sache (spelling?) |
Cusser Samba Member
Joined: October 02, 2006 Posts: 9465 Location: Hot Arizona
