micromotor Samba Member
Posted: Sat May 05, 2012 4:04 pm Post subject: 1962 Single Cab ATE Steering Box |
Can anyone tell me what color the ATE Steering Box should be for a 62 Single Cab? I'm planning on painting the tube black and the box gray. Also, after looking at pictures it looks to be like the tube that holds the horn wire is the same as a brake line? It looks like it goes only about an inch past the bracket ? Mine is gone. Can anyone confirm or deny? Finally, any tips on servicing the steering box where the mileage on the vehicle looks to be low, about 50,000 miles. Finally, I thinking of using 140 wt gear oil instead of the 90. Any thoughts?
Thanks
Micromotor |
Snoop Bob Samba Member
Posted: Sat May 05, 2012 5:58 pm Post subject: |
John Deere Corn Head Grease.
http://www.thesamba.com/vw/forum/viewtopic.php?t=421677&highlight=corn+head+grease _________________
BarryL wrote: |
Put your lips onto the little tit with the hole in it inside and make a good seal. You can suck and blow but with a little resistance. It gets better after it's wet. |
EverettB wrote: |
I would be interested in knowing the sizes of the various shafts. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69823 Location: Phoenix Metro
Posted: Sat May 05, 2012 10:06 pm Post subject: |
As far as I know - Black steering box.
The box shouldn't need anything special on a Bus with 50K.
You could check the adjustment per the manual anyway.
Change the oil if it's been sitting.
If it starts leaking, it could need the lower or the output to the drag link seals replaced. _________________ How to Post Photos
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24759 Location: Olympia Wash Rinse & Repeat
Posted: Sun May 06, 2012 7:18 am Post subject: Re: 1962 Single Cab ATE Steering Box |
micromotor wrote: |
Also, after looking at pictures it looks to be like the tube that holds the horn wire is the same as a brake line? It looks like it goes only about an inch past the bracket ? Mine is gone. Can anyone confirm or deny? |
Early buses (pre1960?) have the grounding wire to the horn wrapped in a metal wire for a little more road protection.
Stick with 90 Wt. and a new output seal. _________________ In Stereo, Where Available! |
Posted: Sun May 06, 2012 9:14 am Post subject: |
EverettB wrote: |
If it starts leaking, it could need the lower or the output to the drag link seals replaced. |
Now That I have the Steering Box off, I can confirm that it was originally black.
The box had what looks to be an original safety wire seal and it was fully packed with a thin grease. Definetly not 90wt. The insides look great. No dirt, water, or rust. |
Posted: Sun May 06, 2012 9:22 am Post subject: Re: 1962 Single Cab ATE Steering Box |
So 1962 would be just the wire?
Is there any kind of seal where the wire exits the box or do I just use some silicon?
Thanks |
slow36hp scott wimberley
Joined: August 09, 2004 Posts: 3113 Location: mukilteo washington
Posted: Sun May 06, 2012 10:03 am Post subject: |
Just checked our 1960 (DEC59 built) walk thru camper conversion and it has the armor wire wound around the ground wire.
Check the 1963 (MAR63 built) SC we have and does not have the armor wire. Just a black plastic sheath around the wire, and NO sealant.
Think will get over to the 1962 Wounded Westie project today and check the ground wire on it. _________________ In Stereo, Where Available! |
Posted: Sun May 06, 2012 12:06 pm Post subject: |
micromotor wrote: |
John Deere Corn Head Grease as mentioned above. The antique Ford guys run it in their steering boxes and swear by it. It is the closest thing anyone has found to the original grease for steering boxes. Some on here use it. Here are some links below. I picked mine up from my local JD dealer.
http://www.deere.com/wps/dcom/en_US/parts/batteries_and_fluids/maintenance_fluids/grease/grease.page
http://www.google.com/search?sourceid=navclient&am...&pbx=1 _________________
BarryL wrote: |
EverettB wrote: |
sventinker Samba Member
Joined: June 10, 2009 Posts: 1481 Location: the sandbox
Posted: Sun May 06, 2012 10:14 pm Post subject: |
My 62 had the protective metal sheath for the wire but it was damaged. _________________ April 3rd 62 standard mgr/pw
374 North American equipment
Includes 6 popouts
025 Safety belts
195 Adjustable bench seat/backrest (until 1963)
dawerks wrote: |
Perfection only comes with delusion. |
http://www.oacdp.org/ |
Rusting Hulk Samba Member
Joined: August 20, 2002 Posts: 646 Location: Malvern UK
Posted: Mon May 07, 2012 12:33 am Post subject: |
I also use a 'steering box' grease, in the rebuilds i do, i think VW changed to grease in 67 and all early bay boxes that i have done have grease in.
The wire hole doesn't need sealing, there is a tube inside and the oil/grease level is below the top of the tube _________________ 64 356 C Coupe |
Posted: Mon May 07, 2012 5:40 am Post subject: Re: 1962 Single Cab ATE Steering Box |
Looks like the "metal wire wrap" is a replacement part. Can anyone tell me what it is called and where it is available?
Thanks |
Posted: Mon May 07, 2012 6:26 am Post subject: |
Our FEB62 SO-34 westie does not have the wire wrap. _________________ In Stereo, Where Available! |
Posted: Wed May 09, 2012 3:37 pm Post subject: Wire Wrap |
Anyone know a source for the "wrapped wire" shown in this pic
Posted: Wed May 09, 2012 9:41 pm Post subject: |
Eric&Barb wrote: |
Our FEB62 SO-34 westie does not have the wire wrap. |
my April 62 did but not sure it was stock I still have the old box I should clean it up and check it out also had an elbow. _________________ April 3rd 62 standard mgr/pw
Includes 6 popouts
025 Safety belts
dawerks wrote: |
Posted: Mon Jun 25, 2012 5:43 pm Post subject: Source for wrapped wire cover |
So this is my SC with my substitute wrapped wire cover installed. I used some NOS wire feed welder liner and I think it looks great. |
