Rod side clearance
Forum Index -> Performance - Engines/Transmissions Share: Facebook Twitter
anthracitedub
anthracitedub is offline
PostPosted: Sun May 06, 2012 2:19 pm    Post subject: Rod side clearance Reply with quote
Im building s stroker 40.... I took my rods to work and used the surface grinder to remove material from both sides of the big ends. I ended up with rods that are < 0.900 inch wide.
I thought that I messed up and would have a ton of side clearance.
With the rods mocked up on the crank, I'm only getting .006 side clearance.
Is this way to tight? Should I regrind the rods about .003?
Or can I proceed with .006, my buddy at work said it would be fine at .006 and I would have better oil pressure.
modok
modok is online now
PostPosted: Sun May 06, 2012 3:06 pm    Post subject: Reply with quote
hmmm, well
usually set the side clearance at .012" min for high performance stuff, there does not seem to be any drawback and it allows plenty of float room for the crank and case to flex without putting side load on the piston (they do flex)
Oil pressure is a function of the oil clearance, not the side clearance
anthracitedub
PostPosted: Sun May 06, 2012 3:27 pm    Post subject: Reply with quote
I guess I'll take a little step back and give'em another scrub.... Try to get'em into .010. I have a graded true stone that I may try laying a piece of 320 paper on, with a little oil... I may be able to hand-hone them into shape.
modok
modok is online now
PostPosted: Sun May 06, 2012 3:39 pm    Post subject: Reply with quote
that should be good
make sure they are square, the sides don't have to be perfect but they need to be darn close
stealth67vw
stealth67vw is offline
PostPosted: Sun May 06, 2012 5:49 pm    Post subject: Reply with quote
Are 40 horse rods wider than 15/1600 rods? 15/1600 come in at .895" and most aftermarket Chinese rods I've measured can be in the .885" range.
John Bates
SOVW.org
modok
modok is online now
PostPosted: Sun May 06, 2012 6:13 pm    Post subject: Reply with quote
yes
In later engines they narrowed the rods and journal width, to make the crank's web between the two rod journals thicker and stronger
Reply to topic    Forum Index -> Performance - Engines/Transmissions All times are Mountain Standard Time/Pacific Daylight Savings Time
