candymustang66 Samba Member
Posted: Tue May 08, 2012 11:09 am Post subject: |
ive see many ignition switch fail. vast.
and all because they hang 5 lbs of keys of the poor thing
even new cars.
no, ive never changed out out on a guess. why would i do that.?
I'm not Paul Allen.
Some like to look at cars and failure rates,
but on this car, tell me , its got what?, 1 wire to start,
and 1 wire to crank? you need statistics on a 1 wire, car , really?
how many hours with a vm does it take to find that.?
answer
zero
you keep it connected , next time it fails. you see it in 1 nano second.
oh, it's zero. bugger me. (I GOT You , you lil gremlin)
also, my cars have a VDO volt meter, so i always know the battery is GO
and the GEN is a go. (like new cars have, ever wonder why?)
leaving me with , 1 silly wire, called 15. that lug on fuse #1 (rear side)
goes my hand dmm meter. (or to my logger if i get lazy)
if that fails, ign, switch or worse.
if i must run wires to the coil to my meter, then by George i do.
do or die. Guessing really does suck.
lest me explain worse
my right fues daisy chains the main power feed.
one day the brass on said pin, decided to be more corrosion than brass.
its pure brass, (love you VW for that fact) so my EMG.flasher would only fail
when the state inspector looks, dang me.
but my meter trap showed me which junction was failing.
a $10 tool, and just a bit of patience.
you can too. just do it. _________________ back to jeeps, my true love... I-6's
finding vw parts that are not junk (even new) , is way too hard!
mines done, and selling 68T1 with no paint. (primer) |
Renee59 Samba Member
Joined: December 01, 2011 Posts: 57 Location: Arcata Ca.
Posted: Tue May 08, 2012 5:51 pm Post subject: |
| Don't feel bad I had a 65 mustang that I had nothing but trouble with, made me so mad I shot it with a 22. |
ringomobile Samba Member
Posted: Tue May 08, 2012 8:21 pm Post subject: |
it left me on the hiway today after work... its definitely wiring/ignition.
ill look at it in winter time, i got other cool stuff that never lets me down.
in winter i'll do all that stuff you guys mentioned above, thanks for the help! |
Posted: Wed May 09, 2012 7:04 am Post subject: |
next winter, carry a meter and test leads
and use it to find WHO drops FIRST.
and a schematic of your car
print out
TAB Technical, wiring ,Type 1, year, (above click it)
then when it fails you have the meter and the road map to the correct area.
this long ago, we called being a boy scout.
always prepared. (the older the car the more tools and spares, i carry)
in a vw, it loves extra weight up front, i make it happy .
set:
points , coil, rotor, cap, 1156,1157s , spark plugs.
some tools and a meter, and full schematic,
if not , AAA towing options. _________________ back to jeeps, my true love... I-6's
JerryMCarter1 Samba Member
Joined: January 07, 2007 Posts: 6244 Location: N.W. Phoenix
Posted: Wed May 09, 2012 7:34 am Post subject: |
I installed a dead start plus a new ign switch - If the switch goes then I can use it to fire it up
This switch is wired completely separate from the existing ign wires
 _________________ Experience always triumphs over hearsay and You get to select which theory to believe |
Posted: Thu May 10, 2012 7:18 pm Post subject: |
i didn't like that idea at first, but after seeing yours jerry, i think its great.
my kids love the bug, i gotta come up with something.
and this way i can diagnose as it happens and i dont have to push!!
thanks |
Posted: Thu May 10, 2012 8:48 pm Post subject: |
keep the buggy rollin -- because it represents so many things in our own mind !
Jerry _________________ Experience always triumphs over hearsay and You get to select which theory to believe |
tekameleon Samba Member
Joined: February 23, 2011 Posts: 14 Location: Edmonton, Alberta, Canada
Posted: Thu May 10, 2012 9:03 pm Post subject: |
There's a reason that they made these....
It's pretty much guaranteed that you're going to need your tools on the side of the road from time to time.
Posted: Thu May 10, 2012 9:06 pm Post subject: |
no pic _________________ Experience always triumphs over hearsay and You get to select which theory to believe |
Posted: Sun May 13, 2012 9:12 pm Post subject: |
ok, so i took EVERYONES advice ( a little from everyone) and im gonna give this another shot
I wired in a push button to crank the starter(separate from other wiring
i got another switch for power to coil
i even have a spare spark plug and a really long wires for my push button switch so when it stops i can check for spark
oh ill get this figured out!!! |
TjdTaylor Samba Member
Joined: July 04, 2011 Posts: 1706 Location: Niagara Falls, Ontario
Posted: Sun May 13, 2012 9:31 pm Post subject: |
Mine died in a MicDicks drivethrough 3 times. I always have to turn it off because of the stinger, they cant hear me ordering. I couldnt get it atarted those three times and had to push it through. You know how dumb i looked? Ohwell, Ive got a badass car and youve got a sunfire Two times i got it into the parking lot, let it sit for a second and it fired up like nothing. The Other time, i ran out of gas and had my dad bring me some . That was about a week after i started driving it and before i realized how broken my fuel guage is. Now i just go inside.
Has anybody noticed that chrafenrude dissapeared and candymustang magically reappeared Makes you think _________________ 1974 Super Beetle
Beetle Bums VW Club Member
"If you can only be good at one thing, be good at cheating, that way, your good at everything"
| Jamies74sb wrote: | | I can't see myself cutting up my super beetle . Maybe a oval or 61 or so with the small windows |
Posted: Sun May 13, 2012 9:59 pm Post subject: |
ringo-- your are on the right track _________________ Experience always triumphs over hearsay and You get to select which theory to believe |
