Fouled Plugs -Dumb Question
Bohdan
Bohdan is offline
PostPosted: Thu May 10, 2012 5:14 am    Post subject: Fouled Plugs -Dumb Question Reply with quote
Okay, okay this is probably a stupid question, but are fouled plugs cleanable and reusable? and if so, how? Mighty obliged
Semper_Dad
Semper_Dad is offline
PostPosted: Thu May 10, 2012 7:11 am    Post subject: Reply with quote
Depends on how fouled they are. I've cleaned a set or two with just a wire brush. They do make special cleaners. Essentially a mini sandblaster. Cracked insulators and worn electrodes are the real death of a plug.
I tend to replace my plugs yearly regardless of mileage. I rotate the old set go into my field replacement parts bag.
74 VW Thing - Walküre
78 GMC Motorhome - Valhalla
"Patina" my ass, that's rust
Recovering Split Bus Addict
Washington State 181 (Thing) Registry - current tally: 58
World 181 Registry Map: http://www.zeemaps.com/394427 Gitm registared boys!
Officially, there are only 98 181s in the world
rsorak
rsorak is offline
PostPosted: Thu May 10, 2012 8:13 am    Post subject: Reply with quote
Much easier and cheaper than that device above is a propane torch....just heat the working end of the plug till it turns white again.
Rick '71 Westfalia & '73 Thing
Bohdan
Bohdan is offline
PostPosted: Fri May 11, 2012 5:18 am    Post subject: Reply with quote
Interesting subjects. Wonderful. Propane torch? Bascially, just burn off the carbon. Thx
Mal evolent
Mal evolent is offline
PostPosted: Fri May 11, 2012 9:01 am    Post subject: Reply with quote
you can never get all of the sand out of a sandblasted plug. I will try the torch thing, but I won't waste my time and my cylinders with sand blasting
73 Beetle, Ghia front brakes, Type 3 rear brakes, 1776, Solex 34 Pict-3, Bosch SVDA, '97 Mustang seats
[77 Westy M plate decoded]
Baja Bugs for Volkswagen Virgins: Index
Wildthings
Wildthings is offline
PostPosted: Fri May 11, 2012 12:25 pm    Post subject: Reply with quote
If the plugs are really fouled sand blasting will only buy you a little time. Prolonged sandblasting will round the edges of the electrodes and wear at the insulator. Shouldn't be that hard to blow the sand out of there though if you have shop air and a good nozzle.
You can chip the dry crud that sometimes builds up around the electrode off with a knife blade or a dental pick, but you don't want to scratch the insulator as scratches make good conductors for high voltage electricity.
