aeromech Samba Member
Joined: January 24, 2006 Posts: 5966 Location: Ocean Beach, California
Posted: Wed May 09, 2012 8:48 am Post subject: Something to consider... Engine fire system |
I'm not connected in any way to this but thought I'd share with you guys.
http://www.bdoutdoors.com/forums/boat-accessories/427275-automatic-halon-system.html _________________ Licensed Airframe and Powerplant Mechanic
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Type 2 1971 (2 ea.) 1978
VW Jetta
VW Passat
SGKent Samba Member
Joined: October 30, 2007 Posts: 17503 Location: State Capitol CA (Sacramento)
Posted: Wed May 09, 2012 9:26 am Post subject: |
sounds like a reasonable solution. _________________ Steve aka Merlin the Wrench
formerly Steve's Racing and Engine Blueprinting. Wrenching since 1967.
bdamico on GF wrote | Quote: | | "When I was your age I'd plan out all sorts of stuff for the future and almost none of them came true. Just wonder if it's worth trying to be a crystal ball. " |
Jim Bear Samba Member
Joined: March 25, 2006 Posts: 258 Location: Warwick, RI
Posted: Wed May 09, 2012 11:32 am Post subject: fuel vapor monitor |
I wonder if the fuel vapor monitor would be set off by some of our more 'odiferous' engine bays. _________________ STOP FRACKING
"You're either on the bus, or you're off the bus." ~kk
'74 Weekender
Ophelia |
Posted: Wed May 09, 2012 11:54 am Post subject: |
Probably only one way to find out. _________________ Licensed Airframe and Powerplant Mechanic
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
WestyMan1971 Samba Member
Joined: March 27, 2008 Posts: 671 Location: The Granite State
marekv8 Samba Member
Joined: January 24, 2006 Posts: 273 Location: Louisiana
Posted: Wed May 09, 2012 2:04 pm Post subject: |
I don't have one in a my '71 Bus, but my Beetle is equipped with a Safecraft Halon set-up-- with nozzles aimed at both throttle bodies and directly under the fuel cell where the pump is located. The big red PULL knob is awfully tempting for the kids.
BusterBrown Samba Member
Joined: December 15, 2009 Posts: 1322 Location: Arizona
Posted: Wed May 09, 2012 2:38 pm Post subject: |
I like the one I saw in the "Up in Smoke" thread awhile back. It's operated by the driver up front with a valve under the seat. Instead of sensors that turn it on, it's the driver.
http://www.thesamba.com/vw/forum/viewtopic.php?t=2...;start=140
| jure-slo wrote: | How to make a cheap fire extinguishing system:
What you need:
How you put it together:
VW engineers designed a hole for exact this purpose:
Make some holes in the tube where it passes the Eberspacher:
This is where it comes out in the engine compartment:
Next time you see flames in the rear view mirror just open the valve, park the bus and slowly get out....
The engine will shut off automatically because of the CO2, also the electric fuel pump which is operated by the gen. light.
If it works? Hope to newer find out... |
_________________ 1978 Sage Green Westfalia
1969 Delta Green/Cloud White Transporter
1977 Senegal Red/Atlas White Transporter
Life is short. Can I have some of yours? |
Posted: Wed May 09, 2012 4:06 pm Post subject: |
| I have been toying with the idea of getting an Elide Fire ball. Assuming they actually work as claimed, they are as close to KISS as you can get. |
grandpa pete Samba Member
Joined: July 06, 2008 Posts: 1311 Location: St. Petersburg, FL
Posted: Wed May 09, 2012 8:50 pm Post subject: |
OK , I'll bite; Whats an elide fireball? _________________ 69 tintop camper 1600 DP |
Posted: Wed May 09, 2012 9:13 pm Post subject: |
| grandpa pete wrote: | | OK , I'll bite; Whats an elide fireball? |
This is the shortest video I could find (47sec), but it isn't in English. Shows what the fireball does about halfway through.
http://www.youtube.com/watch?v=C1Le0ILHZGc |
Posted: Wed May 09, 2012 11:55 pm Post subject: |
| WestyMan1971 wrote: | The fireball is pretty cool, but aren't there issues with using dry chem with engines?
I've heard it will destroy parts that might otherwise be salvageable. |
Have no idea on the effects of dry chemicals, but if it is fully consumed there won't be much of anything worth salvaging. |
jtauxe Samba Member
Joined: September 30, 2004 Posts: 2159 Location: Northern New Mexico
Posted: Thu May 10, 2012 6:48 am Post subject: |
I have always wanted to install a fire suppression system. I have never wanted an engine fire system, though.
I wonder how the FireBall does with gasoline fires... [edit:] They say it works on Class A, B and C: http://elidefireball.com/index-1.html
It's not as cool or expensive as the remotely-activated Halon systems, but, it certainly is simple. Even if the dry chemical screws up some components, it could save the engine and the bus.
I like it. Now - where to find one? Who sells these? _________________ John
"The bus came by and I got on. That's when it all began..." - Garcia/Weir/Kreutzman
Long gone: 1969 and '78 CE Transporters, Westies: 71, 76, 77, 76, 77, 71, 73, 77
For sale: 1974 Westy Automatic
Current projects: 1975 Single Cab, 1978 RHD Double Cab 2.0-L FI
http://vw.tauxe.net
Posted: Thu May 10, 2012 6:49 am Post subject: |
I repaired a 1978 bus that had been in a small engine fire. The owner shot it with dry chemical. I pretty much just washed it off and don't remember the chemical causing any damage.
I also repaired a Vanagon that had an electrical fire up under the dash which was caused by some previous owners poor electrical skills. The new owner hit it heavily with dry chemical up under the dash and in through the radiator area. It pretty much ruined any electrical connections at the fuse block. The chemical caused severe corrosion turning copper connections green. I tried using vinegar to neutralize but it was pretty much a lost cause. The Vanagon was driveable but was going to have gremlins from then on. The worst part was the smell. I couldn't get rid of that. _________________ Licensed Airframe and Powerplant Mechanic
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
dorney Samba Member
Posted: Thu Mar 28, 2013 7:54 pm Post subject: Elide fire ball |
Gentlemen,
I have been reading a lot about fire systems, and I am no expert, but was attracted to the Elide fire ball to mount in the engine compartment of my bus as a passive suppression system. I bought 2 from a supplier in Canada (Word of Mouth Hydroponics) for $35 ea.
Caveat Emptor: they have an expiration date---5 years from date of manufacture. The seller, of course, omitted this fact and sent me two that only have 1 year left on their clock. He was not, shall we say, sophisticated....and when I called him, he went into a long explanation about the dates not being "real" and how you can still eat K-rations from WW2! Yes, he really said that.
Anyway, if you buy these things, be aware they have a shelf life! I was not. |
Posted: Thu Mar 28, 2013 8:04 pm Post subject: Re: Elide fire ball |
| dorney wrote: | Gentlemen,
Thanks for the info, I had never looked for an expiration date before. Too bad the seller won't come clean on this. Maybe a complaint to eBay would help. |
Posted: Thu Mar 28, 2013 10:24 pm Post subject: Re: Elide fire ball |
| dorney wrote: |
Caveat Emptor: they have an expiration date---5 years from date of manufacture. The seller, of course, omitted this fact and sent me two that only have 1 year left on their clock. He was not, shall we say, sophisticated....and when I called him, he went into a long explanation about the dates not being "real" and how you can still eat K-rations from WW2! Yes, he really said that. |
That's...hilarious. "Expiration date? We don't need no stinking expiration date!"
Hoody Samba Member
Posted: Thu Mar 28, 2013 10:41 pm Post subject: |
| Looking to install a fire suppression system in my Bus. The only set up I have seen in a Bay is from Oppossum. Has anyone else installed a system in there engine compartment? I would like to put a halon system with the tank in the dished part of the spare tire and plumb it from there. I would rather have an automatic set up but maybe the manual pull under the front seat is the way to go. Anyone? |
Hot Rod Harp Samba Member
Joined: March 02, 2008 Posts: 36 Location: Englewood, New Jersey
Posted: Fri Mar 29, 2013 9:35 am Post subject: |
I looked at race style automatic systems, nice but pricey.
Stroud 9302 - Stroud Safety Fire Systems
http://www.jegs.com/i/Stroud/877/9302/10002/-1
Product images may differ from actual product appearance.
One of the most dependable Halon 1301 and FE-36 systems available, Stroud Safety Fire Systems are safe to use under the most extreme conditions. Stroud has been protecting drivers and equipment for over 20 years. They continue the tradition with a range of fire suppression delivery systems for all motorsports.
One pound of Halon 1301 & FE-36 discharged for every 50 cubic feet of enclosed volume will achieve a 5% concentration in the air. This is sufficient to extinguish most fires with a substantial margin of safety. Stroud Safety Systems are designed to achieve the concentration within ten seconds, where upon combustion cannot occur. Any size enclosed area will be protected as long as a 5% concentration of Halon 1301 or FE-36 is present. Once the agent is diluted with fresh air to below the 5% concentration, the system begins to lose its effectiveness.
Halon 1301 & FE-36 has proven effective on the flammable portions of Class A fires (wood, paper, etc.), Class B fires (flammable liquid and gas), and Class C fires (electrical). It has also been found effective on deep-seated Class A fires if sufficient soaking time is allowed to dissipate the heat.
The DuPont Company concludes that Halon 1301 & FE-36, when used in concentrations of up to 7% by volume for several minutes, can be used in the presence of humans with a high degree of safety. Research has proven that concentrations of up to 7% by volume of Halon 1301 or FE-36 produce no harmful lasting physical effects on humans. However, in concentrations exceeding 7%, tests have shown that subjects experience feelings of lightheadedness and reduced dexterity. Under normal conditions, the agent does not have corrosive or other adverse effects on metal or plastic components.
Five-pound systems include bottle, head, mount, clamps, 3' pull cable, two 3-port nozzles (180°), one 6-port nozzle (360°), fittings, and 25' of tubing. Ten-pound systems include the same except a 6' pull cable replaces the 3' pull cable. |
1967250s Samba Member
Joined: May 02, 2007 Posts: 341 Location: on the road to wisdom
Posted: Fri Mar 29, 2013 11:19 am Post subject: |
| What about using straight CO2? |
