Remove TDC Sensor Without Damaging It? Its Out. PIC
Forum Index -> Vanagon/Eurovan Share: Facebook Twitter
Vanagon Nut
Vanagon Nut is offline
PostPosted: Thu May 10, 2012 11:32 am    Post subject: Remove TDC Sensor Without Damaging It? Its Out. PIC Reply with quote
Hi all.
It looks like this part is "permanently" in position and will crack when removed but....
Can one remove it w/o damaging it?
Am doing this with engine installed. (need easier access to plenum mount bolt).
Assuming it cracks, what are chances of material falling into clutch housing?
Thanks
Neil.
1981 VanaJetta 2.0 Westy "Jaco"
1988 Westy To Be Named! :^)
Vanagon VAG GAS engine swap Google Group:
https://groups.google.com/group/vanagons-with-vw-i...irect=true
My Air Cooled Vanagon to 15º Jetta ABA swap pages:
https://sites.google.com/site/tubaneil2/15degreeengineconversion
Vanagon Nut
PostPosted: Thu May 10, 2012 12:00 pm    Post subject: Reply with quote
Never mind. It's out.
FWIW for any other newbs, this part is a press fit to a collar on the block.
It comes out but I would assume that given age of plastic, one would be hard pressed to get it out w/o damaging collar on it. It looks like PO tried to do same.
Neil.
danfromsyr
danfromsyr is offline
PostPosted: Thu May 10, 2012 12:49 pm    Post subject: Reply with quote
I tend to snip the wire for it very close to the sender.. and leave it in the case if it doesn't feel like budging..
always wanted to find a practicle use for it. but prefer to not have extraneous wires cluttering & confusing the engine compartment.
VW Club of Central New York SPRING VW GTG
Upstate NY 2013 VWCCNY events
NY State VW Camping 2013 season events
Vanagon Nut
PostPosted: Thu May 10, 2012 1:24 pm    Post subject: Reply with quote
For sure.
I'd like to leave it with wire as I like the "original" look (this being a relatively low mileage rig, want to preserve) but all it'll do is confuse the next owner.
That darn thing though is in the way of plenum bracket nut; the only reason I took it out.
Neil.
Reply to topic    Forum Index -> Vanagon/Eurovan All times are Mountain Standard Time/Pacific Daylight Savings Time
