Vintage Man Samba Member
Joined: November 11, 2010 Posts: 73 Location: An Octopus's Garden
Posted: Sat May 12, 2012 11:24 am Post subject: Fuel Pump Wires? Help |
I recently rebuilt the wires for my fuel pump but forgot where they go.. Its a 66 Squareback electric pump, two wires.. one is ground but i dont know where the power wire hooks into?
Would love some help.
Thanks!  |
blankmange  Type 3 Darksider
Joined: July 17, 2004 Posts: 11640 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Sat May 12, 2012 11:40 am Post subject: Re: Fuel Pump Wires? Help |
| Vintage Man wrote: | I recently rebuilt the wires for my fuel pump but forgot where they go.. Its a 66 Squareback electric pump, two wires.. one is ground but i dont know where the power wire hooks into?
Thanks! |
we'll need a bit more info, since a '66 square would have had carburetors and a manual pump...
perhaps a pic or two? _________________
| 19super73 wrote: | | You wouldn't understand intelligent humour even if it slapped you upside your SOS pad head. |
póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
Posted: Sat May 12, 2012 11:43 am Post subject: Re: Fuel Pump Wires? Help |
| blankmange wrote: | | Vintage Man wrote: | I recently rebuilt the wires for my fuel pump but forgot where they go.. Its a 66 Squareback electric pump, two wires.. one is ground but i dont know where the power wire hooks into?
Thanks! |
perhaps a pic or two? |
All i can say is that it has an electric pump. It was converted to 12v and that it does have dual dellorto carburetors. I know the brand of the pump.. http://vwparts.aircooled.net/Facet-Electric-Fuel-Pump-3psi-p/1008.htm
Sorry, i dont know too much about it. |
Tram  Samba Socialist
Joined: May 02, 2003 Posts: 16858 Location: The human race, AKA 'God's Edsel'
Posted: Sat May 12, 2012 11:52 am Post subject: |
Where on the car is the pump located? _________________ Give A Pal a Hand!
www.happytrailsfarm.org
May 4, 1970... Never Forget.
RIPRW
"Hell is- other people."- Jean- Paul Sartre |
Posted: Sat May 12, 2012 12:22 pm Post subject: |
| Tram wrote: | | Where on the car is the pump located? |
Under the tank, attached to the front end. Im just trying to figure out where the wires go. there are only two. |
Posted: Sat May 12, 2012 12:45 pm Post subject: |
| Vintage Man wrote: | | Tram wrote: | | Where on the car is the pump located? |
Right. The ground should attach to the body, and the best place for your + would be off of the key switched portion on the bottom of fuses 9-10 (where they're bridged at the rear bottom of the fuse box). Be sure to put an inline 16 amp (red) fuse to your electric pump. _________________ Give A Pal a Hand!
RIPRW
Posted: Sat May 12, 2012 12:59 pm Post subject: |
| Tram wrote: | | Vintage Man wrote: | | Tram wrote: | | Where on the car is the pump located? |
Right. The ground should attach to the body, and the best place for your + would be off of the key switched portion on the bottom of fuses 9-10 (where they're bridged at the rear bottom of the fuse box). Be sure to put an inline 16 amp (red) fuse to your electric pump. |
GREAT!! thank you kindly!  |
Posted: Sun May 13, 2012 4:54 pm Post subject: |
Can you specify which side on this photo? http://www.thesamba.com/vw/archives/info/wiring/66type3fuses.jpg
Thanks. |
Posted: Sun May 13, 2012 5:15 pm Post subject: |
| Vintage Man wrote: | | Tram wrote: | | Vintage Man wrote: | | Tram wrote: | | Where on the car is the pump located? |
Thanks. |
Last two fuses on the right- Wipers, stop lights, turn signals, warning lights, gauges- the key- activated stuff. _________________ Give A Pal a Hand!
RIPRW
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 10621 Location: Kimball, Mi
Posted: Sun May 13, 2012 5:20 pm Post subject: |
| Tram wrote: | | Vintage Man wrote: | | Tram wrote: | | Vintage Man wrote: | | Tram wrote: | | Where on the car is the pump located? |
Thanks. |
Last two fuses on the right- Wipers, stop lights, turn signals, warning lights, gauges- the key- activated stuff. |
You should also add an impact switch to turn the pump off in case of an accident (and you can't turn off the key). Ford makes a nice one that can be found in a bunch of their cars (usually in the left rear corner section of the trunk), or get a new 1 from the dealer for around 10 bucks. _________________ Bob 65 Notch S with Sunroof
71 Notch ...aka Krunchy; build pics here; http://www.thesamba.com/vw/forum/viewtopic.php?t=240540 -tear down
64 T-34 Ghia...aka Wolfie, under construction... http://www.thesamba.com/vw/forum/viewtopic.php?t=412120 |
Posted: Sun May 13, 2012 5:35 pm Post subject: |
Thanks. |
THANKS! |
| Bobnotch wrote: | | Tram wrote: | | Vintage Man wrote: | | Tram wrote: | | Vintage Man wrote: | | Tram wrote: | | Where on the car is the pump located? |
Thanks. |
You should also add an impact switch to turn the pump off in case of an accident (and you can't turn off the key). Ford makes a nice one that can be found in a bunch of their cars (usually in the left rear corner section of the trunk), or get a new 1 from the dealer for around 10 bucks. |
There is a ford dealer near my home.. ill go check it out. |
