A1 Header wont clear Oil Filter
Forum Index -> Performance - Engines/Transmissions Share: Facebook Twitter
ajl1971
ajl1971 is offline
PostPosted: Sat May 12, 2012 4:07 pm    Post subject: A1 Header wont clear Oil Filter Reply with quote
Does anyone had a problem installing an A1 Sidewinder 1 1/2 tubing Header (J-Pipe) with this setup :
http://vwparts.aircooled.net/Bugpack-32mm-Bypass-Filter-Oil-Pumps-p/3030-10-3030-11.htm.
The oil filter does not clear, it hits the header.
Any sugestions how to make it work.
Thanks
spanky324
spanky324 is offline
PostPosted: Sat May 12, 2012 4:12 pm    Post subject: Reply with quote
Smaller filter i use a vw rabbit filter(smaller diameter)
ajl1971
ajl1971 is offline
PostPosted: Sat May 12, 2012 4:19 pm    Post subject: Reply with quote
Im actually using Mahle OC-28 and still.
Do you happen to know the code for the one you use so I can try to get it ?
Thanks
Nubby
Nubby is offline
PostPosted: Sat May 12, 2012 5:32 pm    Post subject: Reply with quote
Can you relocate the filter? My A1 fits no problem but my filter is off to the side?
bsairhead
bsairhead is offline
PostPosted: Sat May 12, 2012 5:48 pm    Post subject: Reply with quote
It's a pump filter, no full flow, no relocate.
Nubby
Nubby is offline
PostPosted: Sat May 12, 2012 8:12 pm    Post subject: Reply with quote
I would go with Vintage Speed if you can.
ajl1971
ajl1971 is offline
PostPosted: Sat May 12, 2012 9:55 pm    Post subject: Reply with quote
You are right, I cant relocate the oil filter.
ajl1971
ajl1971 is offline
PostPosted: Sat May 12, 2012 9:56 pm    Post subject: Reply with quote
I already spent the money on this one.
Nubby
Nubby is offline
PostPosted: Sat May 12, 2012 10:42 pm    Post subject: Reply with quote
He adjusted mine. I sent it back and he fixed it. Give Tiger a call. Very good reputation.
spanky324
PostPosted: Sun May 13, 2012 4:32 am    Post subject: Reply with quote
I use the Wix equivalent to ph2870a Fram
ajl1971
ajl1971 is offline
PostPosted: Sun May 13, 2012 5:55 am    Post subject: Reply with quote
That is great to know, I left him a vm last friday, I will try to call him again on Monday. Thanks I did not know he could do that.
I will let you know.
ajl1971
ajl1971 is offline
PostPosted: Sun May 13, 2012 6:00 am    Post subject: Reply with quote
Which one, for some reason my setup is very tight, I use Wix 51515, did not work, OC-25 which is the smaller, OC-49, none of them work. The pipe that curves going to the J-pipe is the one in the way. Another guy suggested to use the one for a Rabbit but Im waiting for him to reply to see if I can get it locally.
Cptn. Calzone
Cptn. Calzone is offline
PostPosted: Sun May 13, 2012 7:15 am    Post subject: sidewinder Reply with quote
.The oil filter will bake in that location regardless of how small the filter is!Do a remote location for the filter . Leave the A-1 as is it will work great. CB sells a Maxi in out pump that you can then mount a remote filter to and even a remote cooler as well. This will serve you better in my humble opinion than the filter pump.The header costs a whole lot more than both the filter pump and the maxi pad Exclamation
71 westfalia
67 912 Porsche Quintilla
67 Single Cab aka my work horse
[email protected]
john@aircooled.net is offline
PostPosted: Sun May 13, 2012 10:28 am    Post subject: Re: sidewinder Reply with quote
If you run a filter pump you need the Flanged version of the Sidewinder, which puts the 1/3 J-tubes in the STOCK location. The inboard location is stupid (IMO), it not only interferes with filter pumps, but also the stock thermostat, and Sled Tins.
It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net
ajl1971
ajl1971 is offline
PostPosted: Sun May 13, 2012 4:43 pm    Post subject: Reply with quote
Which way is better, Do a remote location for the filter or get the flange that John is talking about. Any pictures ?
[email protected]
PostPosted: Sun May 13, 2012 5:17 pm    Post subject: Reply with quote
if you want to get on the road quickly, this may help.
http://vwparts.aircooled.net/Amsoil-Oil-Filter-SUPER-SHORT-Oil-Filter-Pumps-p/eao58.htm
ajl1971
ajl1971 is offline
PostPosted: Sun May 13, 2012 5:32 pm    Post subject: Re: sidewinder Reply with quote
Hi, is this what you are referring to ?
http://www.cbperformance.com/catalog.asp?ProductID=1875
ajl1971
ajl1971 is offline
PostPosted: Sun May 13, 2012 5:45 pm    Post subject: Reply with quote
John, Im willing to try it however I happen to have a Mahle OC-25
http://motorsports8.tripod.com/id36.html and it wont clear either,its 3.5 long, unless the one you are suggesting is smaller. The clearence is notnthe diameter of the oil filter its the length.
Cptn. Calzone
PostPosted: Sun May 13, 2012 6:30 pm    Post subject: oil Reply with quote
Yes the CB pump posted is the one. Not a bad alternative considering where you are at this stage of the game. Just take off the anodized cover and make sure the inner oil passages are not restricted or have any metal boogers . This will end the search for a small filter that still will get cooked by the header.You will have filtration, and clearence.
71 westfalia
ajl1971
ajl1971 is offline
PostPosted: Sun May 13, 2012 6:35 pm    Post subject: Re: oil Reply with quote
Do you know who has one ? CB are out of stock but I will call Daniel tomorrow just in case the inventory is off.
Reply to topic    Forum Index -> Performance - Engines/Transmissions All times are Mountain Standard Time/Pacific Daylight Savings Time
