ajl1971 Samba Member
Joined: December 09, 2010 Posts: 89 Location: New York
Posted: Tue May 15, 2012 4:13 am Post subject: Running out of choices |
Spoke to Tiger at A1, cant be modified, the system was not designed to accept filter/pump. I tried 3 more small filters, none of them cleared, waiting for the last filter to arrive today, if it does not clear I have in order a Maxi 3 oil pump from CB, you can see it here
http://www.cbperformance.com/catalog.asp?ProductID=195
Item 1798
Hopefully if we have to replace it it will come out easily. We will see
Thanks |
Muffler Mike Samba Member
Joined: October 10, 2002 Posts: 1054 Location: Lawndale Ca.
mark tucker Samba Member
Posted: Tue May 15, 2012 7:16 am Post subject: |
make sure you dont run thick oil with the filter pump!!! it has small very small gallys in it(everyone I have seen do)and all I have seen used have had the drive tang boogered up from to thick oil. 5-20 or the thickest oil would be a 10-30. if you use synthetic it would even be better. rember the oil pump is the heart of your engine you dont want to strangle it, and it needs to pump as freely as possiable.kinda like putting a noose around your neck, how long will you last. use thiner oils with those things.easyer pumping makes more horse power and better mpg. |
Posted: Tue May 15, 2012 4:14 pm Post subject: |
I dont see how this application will work for me. What Im trying to do is to relocate the oil flter and the only way I know of will be to setup a full flow system with the Maxi 3 oil pump that CB performance sells.
If you have the details how this will work let me know.
Believe me, I want to use the easiest way possible. |
Posted: Tue May 15, 2012 4:31 pm Post subject: |
ajl1971 wrote: |
Sorry about that. Sometimes I am not very clear and maybe I am miss understanding your problem.
This item is designed to spin on inplace of the filter. Much shorter then a filter. Then hook up in and out hoses to a remote located filter. So you would need another filter adaptor hanging off something like the bumper bracket. Does that help? _________________ Muffler Mike
http://MufflerMike.com |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Tue May 15, 2012 5:38 pm Post subject: |
Try 85225 or 84348 Carquest filters. Both are chrome and very small. _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
Posted: Wed May 16, 2012 2:43 am Post subject: |
MURZI wrote: |
Try 85225 or 84348 Carquest filters. Both are chrome and very small. |
OK I will give it a try but I must say that I tried a really small Wix and it did not clear but I will check one out and see, its ridiculous tight in there.
Thanks |
Posted: Wed May 16, 2012 2:46 am Post subject: |
Muffler Mike wrote: |
ajl1971 wrote: |
This item is designed to spin on inplace of the filter. Much shorter then a filter. Then hook up in and out hoses to a remote located filter. So you would need another filter adaptor hanging off something like the bumper bracket. Does that help? |
YES.
Ah ok, the picture of the part does not show the back of it so I was a little confused, this might work then since Im looking for the easiest and more effective solution. Thanks Buddy !, now I got it.
I would like to know the Cons of this if any. |
wompninja Samba Member
Joined: July 06, 2008 Posts: 2147 Location: Salt Lake City
Posted: Wed May 16, 2012 9:23 am Post subject: |
The cons are you have more leak points and it won't work as well as a true full flow, but it should work. _________________ Pics of my 1970 Satin Black Type 1 build |
Cptn. Calzone Samba Member
Joined: June 27, 2007 Posts: 1855 Location: S>E>Alabama
Posted: Wed May 16, 2012 8:21 pm Post subject: oil filter |
That would probably work if the hoses are thermally protected from the heat generated by the header. Still need a remote filter location somewhere. _________________ 71 westfalia
67 912 Porsche Quintilla
67 Single Cab aka my work horse |
