cmiller95 Samba Member
Joined: August 04, 2010 Posts: 1175 Location: Illinois
Mal evolent Samba Member
Joined: March 31, 2009 Posts: 1829 Location: Socorro, Nuevo Mexico
Posted: Sun May 13, 2012 6:00 pm Post subject: |
yes. they are mostly for show
if I make side bars they will attach to the body lift and the roll cage. ugly but functional _________________ 73 Beetle, Ghia front brakes, Type 3 rear brakes, 1776, Solex 34 Pict-3, Bosch SVDA, '97 Mustang seats
[77 Westy M plate decoded]
Baja Bugs for Volkswagen Virgins: Index |
larryvance66 Samba Member
Joined: January 27, 2009 Posts: 656 Location: Virginia
Posted: Sun May 13, 2012 6:03 pm Post subject: |
Yes, mine go through the quarter panel and then attach to the cage. bent both really bad rock crawling(don't ask) a couple weeks ago, no body damage and we pulled the bent nerf bars back out with a winch.  _________________ I got a Volkswagen for my wife....Best trade I ever made! |
thesatelliteguy Samba Member
Joined: January 06, 2007 Posts: 1230 Location: Santa Rosa CA
Posted: Sun May 13, 2012 6:04 pm Post subject: |
It didnt.
I wish i had pics of the damage. It bent the bar quite a bit. i had to cut out the bent piece and weld in a straight piece. _________________ Toyotas are so bumpy it makes me sick, literally.
My build Page http://www.thesamba.com/vw/forum/viewtopic.php?t=383878 |
enjoyther1de Samba Member
Joined: December 19, 2010 Posts: 268 Location: chino,ca
Posted: Sun May 13, 2012 7:37 pm Post subject: |
[quote="thesatelliteguy"]It didnt.
Comin in Hot! _________________ http://www.grassvalleyrec.com/HBB2/Brad_0001.wmv
A government that is big enough to give you everything you want is also strong enough to take everything you have. - Thomas Jefferson |
Posted: Mon May 14, 2012 7:58 am Post subject: |
| enjoyther1de wrote: |
Comin in Hot! |
Commin in REAL hot! I think i was at the beginning of 3rd gear in a stock trans. when i got on the brakes hard. So probably ~35ish mph. What fun! _________________ Toyotas are so bumpy it makes me sick, literally.
The Phil Samba Member
Posted: Mon May 14, 2012 5:07 pm Post subject: |
| thesatelliteguy wrote: | | enjoyther1de wrote: |
Comin in Hot! |
Commin in REAL hot! I think i was at the beginning of 3rd gear in a stock trans. when i got on the brakes hard. So probably ~35ish mph. What fun! |
you made the classic mistake. Should have pressed the clutch, flicked the wheel, while dumping the clutch out at HIGH rpms to slide that bitch around the corner.
I love doing that on dirt roads. _________________ "In case I don't see you, good afternoon , good evening, and goodnight."
My '66 Baja Build Page http://www.thesamba.com/vw/forum/viewtopic.php?t=456365
Free from the evils of facebook.
53 Chevy 3 window 1/2T |
Posted: Mon May 14, 2012 6:50 pm Post subject: |
| cmiller95 wrote: | i gotta try that sometime  |
We gotta be careful with our swingaxles. gotta make sure you have a "smooth" road to do it on, and that you are getting full power out of the motor so it helps hold down the swing axles. if done right, its super fun.
BUT please, be careful doing it in the first place. _________________ "In case I don't see you, good afternoon , good evening, and goodnight."
chubby53 Samba Member
Joined: February 17, 2005 Posts: 1633 Location: Eugene, Oregon
pafree Samba Member
Joined: August 16, 2005 Posts: 2168 Location: dayton, the one in texas
Posted: Tue May 15, 2012 10:05 am Post subject: |
i used the store bought nerf bars like curb feelers. going around trees, the bars would let you know that you were getting too close. they are not a good jack point for a high lift, stuck down the mud jack. i don't have a body lift to connect too but have thought about a beam system that would connect the nerf bars on both sides of the car and mount to the bottom of the car and tunnel. _________________ 1972 vw hunting truggy
sand it, fill it, paint it, throw some mud on it and then baja it. |
Posted: Tue May 15, 2012 10:45 am Post subject: |
I was able to use my body lift to attach my side bars. I think if you used a good sized tubing you could attach it to the tunnel and bolt to your side bars and it would be nice and stout., i still would be worried about hitting hard enough to bend it and your quarter panel though. _________________ My build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=385100 |
bossride Samba Member
Joined: September 10, 2008 Posts: 201 Location: Top of Mississippi.
Posted: Tue May 15, 2012 11:49 am Post subject: |
On a railbuggy thread the DesertDave guy said a lot of "tree bars" on race vehicles are made of a slightly smaller tubing and are removable, so they have some give, as opposed to welding a bunch of rigid bars that distort the main cage when hit. He said it was easier to replace a small portion that was designed to take impact than jolting the entire cage system. Just a thought, and might be of some help if one was designing something that tied into a roll bar... _________________ '59 Beetle.
'66 Beetle.
Yellow rail buggy. |
Posted: Tue May 15, 2012 12:35 pm Post subject: |
| bossride wrote: | | On a railbuggy thread the DesertDave guy said a lot of "tree bars" on race vehicles are made of a slightly smaller tubing and are removable, so they have some give, as opposed to welding a bunch of rigid bars that distort the main cage when hit. He said it was easier to replace a small portion that was designed to take impact than jolting the entire cage system. Just a thought, and might be of some help if one was designing something that tied into a roll bar... |
Damnit!! where was this comment when i built mine!! I used 1" X .095 at least pipe. Oh well, i'll just have to try not to go slammin into big ass stationary objects. LOL _________________ My build:
kbwakesk8 Samba Member
Joined: December 08, 2005 Posts: 1475 Location: Hacienda Heights CA
