Rwoodshvac Samba Member
Posted: Mon May 14, 2012 11:03 am Post subject: Porsche Sealing washers on 36 hp |
I came across these Porsche 356/912 Sealing washers and gaskets.
The washers are beveled for the use of an o ring gasket
What are your thoughts on these being used on a 36 hp case?
I really like the design and the idea of not have to use a gasket sealer . on the nuts and wahsers.
Plus the Porsche look with the acorn nuts.
Feedback welcomed
 _________________ 57 Ragtop Semaphore Sedan
Vinatage Speed build
48 Aluminum Case
Porsche 356 B Crankshaft 74mm
Porsche 356 B Rods
Shasta Cylinders with JE Pistons 80mm
WW Okrasa Heads worked by Ron Chuck
34 Pbic Carbs rebushed by Mr Okrasa
Custom Okrasa Intakes enlarged to 34mm
Gene Burg Sump
Fram bypass Filter with Oil Cooler
+ A Full flow filter System |
slalombuggy Samba Member
Joined: July 17, 2010 Posts: 3795 Location: Canada 306
Posted: Mon May 14, 2012 2:24 pm Post subject: |
Good enough for Porsche, good enough for VW. Can't see why these wouldn't work as long as the case surface is clean and fairly flat and pit free.
brad _________________ BB Buggy 121.253mph @ Bonneville 2012
http://www.youtube.com/watch?v=57hMyJmIU10
Raisin cookies that look like chocolate chip cookies are the main reason I have trust issues |
sgmalt46 Samba Member
Posted: Tue May 15, 2012 8:17 am Post subject: |
| yes run them! . they look cool. ive seen them used on 36's. i still would use a dab of sealer under the washer to be safe but not needed. i just hate any kinds of leaks. |
ONEBADBUG Samba Member
Joined: January 27, 2004 Posts: 67 Location: SPOKANE, WA
