truckfridge vs. engel mt45 question
Goto page 1, 2  Next
Forum Index -> Vanagon/Eurovan Share: Facebook Twitter
pushkick
pushkick is offline
PostPosted: Mon May 14, 2012 12:20 pm    Post subject: truckfridge vs. engel mt45 question Reply with quote
i know this has been discussed on other threads.
there is a big price difference between the truckfridge tf45 ($499) and the engel mt45 ($910) is there a big performance difference? they both have similar features 12/110 and fridge or freezer modes of operation. the current draw on the truckfridge is a little higher on the low end 1.7 -2.7amps
vs engel .7 - 2.5 amps. external size is a little smaller on the truckfridge.
who has one and how long on battery or how many watts on solar do you need?
thanks for any help
i see said the blind man to his deaf dog
i am going to quit smoking and drinking and die a healthy man. gotta laugh
there is no deed to the planet earth
ohlott
ohlott is offline
PostPosted: Mon May 14, 2012 12:47 pm    Post subject: Reply with quote
I run truck ridge and love it. I keep it running 247. I have a 135 watt panel up top and a group 27 110ah under the bench seat. It keeps up fine.
Solar panel have come Down a lot since I installed mine. About 100.
Good luck. Lots of good set ups on here. Search. Solar
83.5 westy 2.2 subi
davevickery
davevickery is offline
PostPosted: Mon May 14, 2012 3:12 pm    Post subject: Reply with quote
the truckfridge guy was offering a samba discount which brought the price down even further and maybe free shipping to
o. there was a post about it recently.
jackbombay
jackbombay is offline
PostPosted: Mon May 14, 2012 5:15 pm    Post subject: Reply with quote
I had a vitro frigo (identical to the truck fridge, or close to it) and I also have an engel mt 45. The engel holds a more consistent temperature, 40* out? 33* inside, 102* out? 33* inside. It does seem to run less than the vitro frigo too.
I do like a front loader quite a bit more though. Having a small freezer in the truck fridge is also pretty nice, because every time you set up camp and make a martini with ice from your freezer you'll feel like a boss Cool
Gas struts to pop your top easily!
Samba ad here.
DIY artificial rain gutters (ARGs)
pushkick
pushkick is offline
PostPosted: Tue May 15, 2012 1:22 pm    Post subject: Reply with quote
how does the truck fridge hold up with outside temps 95-100 deg f ?
berkeleyjack
berkeleyjack is offline
PostPosted: Tue May 15, 2012 1:28 pm    Post subject: Reply with quote
GoWesty has the Whynter 65Q on sale in their eBay shop right now:
http://www.ebay.com/itm/Whynter-65-Quart-Portable-Fridge-Freezer-/360432690709
All-grain homebrewer with a 1990 Vanagon Carat.
J Charlton Premium Member
J Charlton is offline
PostPosted: Tue May 15, 2012 1:48 pm    Post subject: Reply with quote
it holds up well. The duty cycle is just increased with the commensurate draw on the battery. Interior temp remains constant
March 2013 HIGH top availability: Flagstaff 2, Toronto 1, PNW 0, Colorado 0, Virginia 0
Now accepting $250 deposits for "roll out" pricing for ADVENTUREWAGEN tops. inner shells and bulkheads
"Roll out" group production in progress (June 11) a very short window of opportunity to add to it is open
Gutter mounted side and top racking for hightops
http://northamericanhightops.com
http://canadianhightops.ca
mblotz
mblotz is offline
PostPosted: Tue May 15, 2012 7:16 pm    Post subject: Reply with quote
my initial trial run with my truck fridge (tf65) didnt last as long as i expected. park in late afternoon it seemed like the fridge was not running anymore by morning? walmart group 27 marine 105ah battery with my calculations should be running for 30-35 hrs. granted this was in NM desert but still.
trying to decide if my battery is bunk or my fridge is running to much. and if i should ad another battery (210ah then) or if im just crazy and need to spend more time with it.
of course i did not have my multimeter along to know what my charge was
thoughts?
PostPosted: Tue May 15, 2012 8:32 pm    Post subject: draw Reply with quote
If your battery had the full charge available, then it should not have been drawn down to below operating voltage in the (say) 10 hours. I think that the max draw of the TF65 is well under 10 amps - so even at 100% duty cycle, your battery should have lasted.
idahoskier
idahoskier is offline
PostPosted: Tue May 15, 2012 8:48 pm    Post subject: Reply with quote
Just ran my TF65 on its maiden voyage in Moab. I didnt check voltages much but did get this series:
15:00=12.38V
17:00=12.33
10:30=11.90
I expected fridge alone to be good off a full battery (101 AHr @ 12.8V) for about 48hrs if it wasnt in the middle of the desert and I didnt run anything else. I was in the middle of the desert, it was 85-90 F, and the sun was blazing on the fridge side of the van till about 19:00. Night temps were around 55 F. I also ran the stereo (18x4 RMS) and amp (40x2 RMS) for 2-3 hours turned up louder than I ever listen to it in the van. We were in and out of the fridge a bunch and it was turned up to the max. I used the stock galley light all night. The popsicles stayed frozen and I even made a tray of ice for drinks. The fridge was very full Very Happy Im satisified with this but YMMV.
85 Westy w/ 2.2L Subaru
91 Westy w/ 2.5L Subaru
pushkick
pushkick is offline
PostPosted: Fri May 18, 2012 8:49 pm    Post subject: who is the truck fridge guy? Reply with quote
is there a web site ? couldnt find the post
thanks
bruce
joseph928
joseph928 is offline
PostPosted: Fri May 18, 2012 9:02 pm    Post subject: Re: who is the truck fridge guy? Reply with quote
thanks
bruce
Blue Bay Bus Big Rig Gifts. com type in van and get a 5% off + free shipping! If van does not work call them they will help, had to do this yesterday when I got my tf-49. Very Happy best price by far that I found!
1987 syncro westy tin top sun roof GW2.3 rear locker decoupler custom bumper roof rack Gary Lee tire rack lift south african grill big brakes rhein alloy 15 BFG AT 617 gears ShadyBoy awning 140 watt rear 85 watt front solar mppt truckfridge automatic fire extinguishing system - 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley - Dodge 4500 4x4- 1987 tin top westy Jetta 2.0 ABA 1.8 head, 55 watt solar automatic fire extinguishing system -Just sold my 84 Westy
mblotz
mblotz is offline
PostPosted: Sun May 20, 2012 11:54 am    Post subject: Reply with quote
i think i just have a problem with my fridge--so maybe not all related to battery. i started it up 4 hours ago (9am) and it was at 50 degrees inside. i put maybe 15 sodas (from cool garage floor) and maybe 8 cold beers from house fridge. 4 hours later with dial set to 7 (max) i am at 60 degrees. hmm--i actually warmed my beer instead of cooling it--damnit
westyventures
westyventures is offline
PostPosted: Tue May 22, 2012 12:39 pm    Post subject: Re: who is the truck fridge guy? Reply with quote
Or, you could support the 'little guy' who actually brought the fridges to light to this crowd, tested them extensively, offers free advice, photos, and technical installation help, etc. BRG does not. Is it worth saving 5%? Wink
Karl Mullendore
www.westyventures.com
www.propexusa.com
Propex Heatsource US-HQ and Truckfridge sales and installation.
(Traveling in the PNW June/July!)
joseph928
PostPosted: Tue May 22, 2012 9:31 pm    Post subject: Re: who is the truck fridge guy? Reply with quote
Blue Bay Bus Sorry, yes! $489.95 less 5% = $24.50, and free shipping! Call me cheap. Very Happy
Hegamon
Hegamon is offline
PostPosted: Wed May 23, 2012 2:47 am    Post subject: Fridge Anti-theft Reply with quote
With these options, the fridge is now exposed in the cabin and not screwed into/hidden by the cabinetry. Do either of these options allow for a security system that bolts them to the floor in a way that deters theft? I see that gowesty has a mounting system, but it would be just as easy to for a crook to slide the fridge out by pushing the button as it would be for me.
whynotvw
whynotvw is offline
PostPosted: Wed May 23, 2012 8:44 am    Post subject: Re: Fridge Anti-theft Reply with quote
I have Engel mt45 and I put a beach towel over mine sometimes and that hides it pretty well. I also installed a alarm.
bosruten
bosruten is offline
PostPosted: Wed May 23, 2012 8:47 am    Post subject: Re: Fridge Anti-theft Reply with quote
I once had so much beer in my cooler, the park warden could not confiscate(it is not supposed to be outside, unattended) because of the weight! You could try that. Smile
'87 Syncro Weekender
pushkick
pushkick is offline
PostPosted: Wed May 23, 2012 3:05 pm    Post subject: here is what i have found out Reply with quote
$959 +sh engle mt45 66lbs 1.5 cu ft. 12/24dc/120 power 25.5(w)X 14.3(d) X 20(h) .7->2.5amp @12 vdc fridge/freezer
$499+ sh truckfridge55 42lbs 2.0 cu.ft. 12/130 power 25.5(w) X 20(d) X 20(h) 1.67-2.7 amp @12 vdc or 40 amps/24hrs - 65 amps/24hrs fridge/freezer
$450 whynter 57lbs 2.5cu.ft. 120ac/12vdc 28(w) X 17.5(d) X 21(h) 1amp ac- 2.75 amp dc fridge/freezer
$599 danzer 75lbs 1.8 cu. ft. 12 vdc 26.5(w) X 23(d) X 30.5(h) (refridge).4 amps -(freezer).97amps or 114watt/day - 280watt/day fridge or freezer not both
this is the information i have so far.
madspaniard
madspaniard is online now
PostPosted: Wed May 23, 2012 3:53 pm    Post subject: Re: Fridge Anti-theft Reply with quote
same here
you can also use a security cable thru the handles like those used in bicycles
Reply to topic    Forum Index -> Vanagon/Eurovan All times are Mountain Standard Time/Pacific Daylight Savings Time
Goto page 1, 2  Next
