iWANTBUS Samba Member
Joined: November 06, 2007 Posts: 247 Location: United States
Posted: Mon May 14, 2012 7:39 pm Post subject: Subaru conversion problem |
Quick question,
I have 74 bus and I just finished the subaru conversion, I had it all ready to go and thought it all done right to find the my motor was not turning, took a better look at it and my cluctch is touching my bell housing.....I put a vanagon clutch on , was that not the right clutch for the 74 bus transmission?
Or did I buy the wrong adapter?
Thanks in avance. |
grandpa pete Samba Member
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51129 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon May 14, 2012 8:56 pm Post subject: Re: Subaru conversion problem |
iWANTBUS wrote: |
..I put a vanagon clutch on , was that not the right clutch for the 74 bus transmission? |
Wrong clutch/flywheel, you'll either need the flywheel off the 74 or a later bellhousing and starter. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon May 14, 2012 9:16 pm Post subject: |
You need to find yourself a '76 or later Bay/Vanagon bellhousing and starter. |
VDubTech Samba Member
Joined: December 29, 2002 Posts: 9142 Location: Syracuse, NY
Posted: Mon May 14, 2012 9:52 pm Post subject: |
....the reason being that a '74 had either a 210mm or a 215mm flywheel and clutch depending on the month of production, and a '76 and newer Bus and Vanagon both had a 228mm flywheel and matching clutch components. You need either all earlier parts, or all later parts....a mix match won't work as you unfortunately found out. _________________ First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote: |
a measurement of your rod would be extremely useful. |
notchboy wrote: |
my dad wasnt a belittling cock when he tought me how to wrench on cars. |
EverettB wrote: |
One photo = good for reference.
10 photos = douchebaggery |
Posted: Tue May 15, 2012 4:16 am Post subject: |
VDubTech wrote: |
You need either all earlier parts, or all later parts....a mix match won't work as you unfortunately found out. |
Should have explained my point better, but with the more powerful engine I would suggest keeping the stronger 228 mm clutch and finding the later bellhousing and matching items needed to be able to use it. |
Bendejo Samba Member
Posted: Tue May 15, 2012 9:34 am Post subject: |
I ran into this issue on my watercooled swap. when the engine with adaptor plate was tightened onto the trans, it would not turn. Loosen nuts and it was free again. It ended up needing the input shaft trimmed about 10mm to keep from binding in the pilot bearing. I hope this helps. |
markd89 Samba Member
Joined: November 04, 2005 Posts: 657 Location: Los Angeles
Posted: Tue May 15, 2012 1:05 pm Post subject: |
Bendejo wrote: |
That's a good point and it's in the Kennedy docs. It depends which trans you have. For the 091 shortening was needed. For an 002, I'm not sure.
Post pics!!
Mark
78 Bus TDI Conversion |
tristessa Samba Member
Joined: April 07, 2004 Posts: 3992 Location: Portland, OR
Posted: Tue May 15, 2012 5:51 pm Post subject: |
markd89 wrote: |
It depends which trans you have. For the 091 shortening was needed. For an 002, I'm not sure. |
It also depends which engine you have. I had to trim my 002 input shaft with a JH-code VW inline, but I know of an ALH TDI that didn't need trimming with an 002 transaxle.
.. all of which is fairly irrelevant to the OP's Subaru swap. |
