Dave3d Samba Member
Posted: Tue May 15, 2012 8:06 am Post subject: Transmission play |
Hello.
I was pulling a bit on the transmission shaft (where it splines into the engine), and notice quite a bit of play (maybe 1/4 inch? ) when I pulled and pushed on the shaft.
Is this normal?
I dont remember my bug having that much play.
Thanks.
Dave |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 733 Location: Seattle, WA
Posted: Tue May 15, 2012 8:54 am Post subject: |
Not normal. Serious damage imminent. Take off bell housing and reattach/repair the input shaft. _________________ '67 bug: seized by the authorities
'71 kombi: not yet seized by the authorities |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 23871 Location: Surrey B.C. Canada, Land of the giant flying moose!
In out? or side to side?, the rear end of the input shaft isn't supported when the engine is missing so side play is normal, end play may be the beginning of bigger issues and could be worth a look inside. _________________ Rust NEVER sleeps and stock never goes out of style.
Wanted, 68-73 westy OG plaid curtains, singles OK. |
Dave3d Samba Member
Posted: Tue May 15, 2012 10:09 am Post subject: |
In/Out.
Not side to side.
Shifting has always been a bit difficult in 1st gear, and is really sloppy in all gears (seems like a mile and half to each gear, up, down, and to 3rd). |
bwiencek Samba Member
Joined: January 24, 2012 Posts: 101 Location: Kansas City
Posted: Tue May 15, 2012 10:47 am Post subject: |
in/out play is not good - I don't recall the endplay specs but it's no where near 1/4"! More like .0xx" - my guess is that the bearings are shot - at least that would be the cheapest fix - time to pull the tranny apart and repair/replace all the damaged parts - I'm going to guess with that much endplay you'll find metal shavings in the oil and if it's been run for a long time it may have damaged other bearings and parts (countershaft bearings, etc.) _________________ 73 bay window - brought home in boxes - work in process.
previous VW Busses: 69 with crank open sunroof, 70 standard, 71 westfalia camper |
Dave3d Samba Member
Posted: Tue May 15, 2012 10:59 am Post subject: |
Poop.
Well, looks like a rebuilt from rancho.
Thanks all. |
Dave3d Samba Member
Posted: Tue May 15, 2012 11:35 am Post subject: |
Could the tranny mess up the engine if I put the engine back in and drive it to the shop to have the tranny replaced?
What kind of damage could occur? |
Posted: Tue May 15, 2012 12:44 pm Post subject: |
Not likely, if you already have the engine out why have a shop do the transmission pull? _________________ Rust NEVER sleeps and stock never goes out of style.
Posted: Tue May 15, 2012 12:55 pm Post subject: |
| Dave3d wrote: | Could the tranny mess up the engine if I put the engine back in and drive it to the shop to have the tranny replaced?
Highly unlikely any engine damage will occur driving to the shop with a bad bearing in the transmission.
Before putting it back in and driving out there - pull the bolts holding the belhousing to get to inspect the input shaft where it goes into the transmission - Don't know what year you're working on but I know on the earlier ones there is a coupler that holds the 2-pc input shaft together - I'm thinking that it's the same thing on the later ones - you might get lucky that it came loose and all that needs to happen is tighten the coupler and re-install the snap ring.
Stand the transaxle in a bucket on the end with the nosecone pointing down and you won't even make a mess pulling it apart. It can be re-assembled with a light coat of RTV.
Someone that's been inside the later bus transmissions might be able to verify that it's the same setup. _________________ 73 bay window - brought home in boxes - work in process.
Dave3d Samba Member
Posted: Tue May 15, 2012 2:09 pm Post subject: |
Well, I am not physically able to do much on anything right now.
I am recovering from 8-11 blood clots in 1 leg, a massive pulmonary clot (that has resulted in heart and vein damage), and tons of smaller clots throughout the lungs.
So:
1. I just dont have the strength or stamina for pulling a tranny (I pulled the engine myself, but I also didnt have to do any strenuos work for that). I cant even get the engine back in by myself.
2. I know absolutely 0 about trannies. I can rebuild an engine, but trannies baffle me.
Thanks guys. |
skills@eurocarsplus Samba Member
Joined: January 01, 2007 Posts: 3954 Location: sticksville, ct.
Posted: Tue May 15, 2012 2:12 pm Post subject: |
| Dave3d wrote: | Well, I am not physically able to do much on anything right now.
and you're worried about a transmission? dam! take it ez and get better! _________________
| VWsArent4Hippies wrote: | | Whenever I click on the baywindow forum I feel like I'm entering a place where most people have no sense of reality |
| schell '59 wrote: | | The honor system works for boy scouts..not in real business |
| modok wrote: | | It was in the instructions back when stuff came with instructions |
| curtis4085 wrote: | | as most your information you give is crap anyway |
| bugger101 wrote: |
skills, you never win with cheap vw people |
Dave3d Samba Member
Posted: Tue May 15, 2012 2:52 pm Post subject: |
Well, I am 4 months out now.
the leg clots should be gone.
All of the little lung clots seem to be gone.
And, I have more good days than bad days now.
But, I just dont have the stamina/strength to do stuff myself.
My sister just came to live with us, and she is w/o a vehicle.
If I can get the bus going, she can drive it until she gets on her feet.
That way, I wont have to spend 2,500 on a car for her. (which, looks like I am going to end up doing anyway).
Plus, being lazy is what got me the clots in the first place.
Trying to move/work/get-off-my-ass as much as possible nowadays. |
SGKent Samba Member
Joined: October 30, 2007 Posts: 17528 Location: State Capitol CA (Sacramento)
Posted: Tue May 15, 2012 9:44 pm Post subject: |
where is bigbore? Maybe he could comment on this if he is still reading posts. _________________ Steve aka Merlin the Wrench
formerly Steve's Racing and Engine Blueprinting. Wrenching since 1967.
bdamico on GF wrote | Quote: | | "When I was your age I'd plan out all sorts of stuff for the future and almost none of them came true. Just wonder if it's worth trying to be a crystal ball. " |
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 2231 Location: Los Gatos,Ca.
Posted: Tue May 15, 2012 11:22 pm Post subject: endplay |
There are 5 different things to look at in regards to excessive
endplay on the output shaft.
The 2 most common being.1-Thrust surface on nose cone worn
but repairable.*
2..7mm Stud is unscrewed from mainshaft.*Also repairable
Then we have 2 snaprings that hold 3rd gear and 4 gear Which is Not
common for them to fail.
#5 is the mainshaft bearing in the shift housing.
This is what pounds the nose cone....
Please look at illustration #10 in VW transmission diagrams
@ www.longenterprises.com
Was this trans noisy before you found this problem? _________________ V.W.owner since 1967 |
Dave3d Samba Member
Posted: Wed May 16, 2012 10:11 am Post subject: |
Nope, no noise.
Just hard to shift into 1st gear, and very sloppy in all gears (my bug is very tight, with very little movement needed between 1st/2nd and 3rd/4th, and in-between 2nd to 3rd). The bus has a LOT of travel from 1st/2nd, and 3rd/4th, with a lot of travel going from 2nd to 3rd.
It just all feels very sloppy
The coupler has been recently replaced (as it is all new and shiny). |
