Mixagolf1 Samba Member
Joined: November 22, 2009 Posts: 140 Location: Kiev, Ukraine
Posted: Mon Oct 08, 2012 12:30 pm Post subject: |
Some pics from the local gathering. My bug is the ugly one))
_________________ '73 1303
'07 Golf TDI |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Tue Oct 09, 2012 6:46 am Post subject: |
Mixagolf1 wrote: |
Bashr52 wrote: |
Nothing special about the rear of a super. Any STD IRS adjustable plate will work. |
Arrived from Cip1. Are they OK? I'm afraid that the torsion bar on my 1303 will be longer? |
Did you read the fine print?
Quote: |
Now you will be able to adjust the height of your rear suspension in just a few minutes! Urethane grommets recommended but are not included. Note: All adjustable spring plates are made to use the short (21 3/4) torsion bars. This is a stock torsion bar for the 1960-68 beetle with the solid 4 bolt torsion cap. (with no hole in center). When changing over you well also need to use our torsion cap # ACC-C10-4055 to replace your old ones with the hole. On the later model IRS dog leg (trailing /swing arm ) the bolt pattern is slightly different - and therefor you will need to drill one extra hole for proper installation. Will provide approx. 1-1/2 to 2 inches of adjustability
Posted: Wed Oct 10, 2012 12:01 pm Post subject: |
Bashr52 wrote: |
Hmm.. I read it but not very carefully. Now i have a pair of adjustable spring plates, a pair of original (they are so ugly!!) spring plate covers without holes. So i need a pair of short torsions to make this work... Or i may try to convert the new spring plates to work with long torsions, i think it can be done using a new and old plates together
What will be the better decision- to buy a new short torsions (maybe a more stiffer ones) or to use old and save some money? _________________ '73 1303
'07 Golf TDI |
Posted: Sat Feb 09, 2013 2:18 pm Post subject: |
So i'm back.
The Bug sits in the garage during the winter. By the time new windshield glass and side door glasses arrived. The original windshield is so heavily scratched i can't see nothing at night. Got the glass via JP Group:
Changed all the bulbs in the speedo with a new VDO. The result is amazing, the speedo looks just like it should. I love it
'07 Golf TDI |
Posted: Sat Feb 09, 2013 2:31 pm Post subject: |
The Spring will come soon and i have a great plans for the Bug. The first part of it is the body repair. Now i searching for the proper body shop, the difficult story...
The other part of the plan is to finish an engine build. I need a new heads and a carbs, because now i have SP heads from a 1200 (?) engine on a 1776 cylinders. I see there are a different head types: 040, 041, 044 and others. As i understand they have a different valve sizes, or anything else? I did a search and didnt found a clear description of differences between the heads.
Can you point me to some FAQ? Which heads will work the best in my 1776 engine if i want the perfomance on the first place? Thanks) _________________ '73 1303
'07 Golf TDI |
jkallhoff Samba Member
Joined: June 26, 2012 Posts: 76 Location: parma heights ohio
Posted: Mon Feb 11, 2013 6:32 pm Post subject: |
be prepared to spend some cash on heads. thats where the power is. a head with stock type valves will work great, with the 35 x 32 valves, its the package they come in. you get some cheap head and your looking at horrible cast and poor plug placement. not to mention a good port and polish on both the heads and the intake manifolds to match. lastly i would look at the chamber size, because this is direct influence of your compression. more specs on the rest of your motor will help us with pointing you to a good head for you, like your deck hight, what your goal ratio is. good luck on your build. |
Posted: Sun Sep 08, 2013 11:13 am Post subject: |
Long time no news, but there happened a lot of things.
I've started a body repair. First of all i removed all interior and electrics myself.
The hardest part was to find a right guys to do it all. First attempt was unsuccessfull, they dissassembled the body and then they started to play for time.
This lasted two month, then i took everything from them and found another shop. Then the work began. _________________ '73 1303
'07 Golf TDI |
Posted: Sun Sep 08, 2013 11:23 am Post subject: |
I've got some parts. All from JP Group, well known for the "quality". But the front side panels were very good!
'07 Golf TDI |
Posted: Sun Sep 08, 2013 11:31 am Post subject: |
green73 wrote: |
Nice bug! The rust don't look to bad. |
^^he he
In the new shop the events began to occur much faster. They removed the body from the frame. What a horror!!!
check out the self-made pans:
'07 Golf TDI |
Posted: Sun Sep 08, 2013 12:02 pm Post subject: |
All waste was removed from the frame:
And then the new pans were tryed on:
Then the front end was removed from the body:
'07 Golf TDI |
lovethatconvertible Samba Member
Joined: August 22, 2008 Posts: 1434 Location: Las Vegas N. V.
Posted: Sun Sep 08, 2013 1:36 pm Post subject: |
Mixagolf1 wrote: |
green73 wrote: |
That should Buff out Crazy work going on in that shop. Your Beetle is going thru a Major Rebirth. Keep em coming. |
kostya.lyt Samba Member
Joined: December 20, 2007 Posts: 71 Location: Pearland, TX
Posted: Tue Oct 08, 2013 8:21 pm Post subject: |
Great progress! _________________ '58 Type 1
'64 Type 1 |
Posted: Sat Oct 08, 2016 2:53 pm Post subject: |
kostya.lyt wrote: |
Great progress! |
So, after three years i have a real great progress
A lot of water under the bridge. The guy who did the work started good but not finished the job, i moved from occupied Crimea to Kiev (i live in Ukraine), moved the car with the belongings in a 5t truck, car moved to another shop in Dnepr (city) that was fortunately good. They finished the metal work and now the Bug is at the painting. The photo is more than month old:
The paint code will be Porsche L7A1. Stay tuned! _________________ '73 1303
'07 Golf TDI |
Posted: Sat Oct 15, 2016 12:44 pm Post subject: Re: 1303S from Ukraine-slow build |
Here are some pics of the process, if someone interested.
The previous shop did a good work on the front side, but they "tired" when it comes to rear side... Damn, how i hate this.
Covered an old rust with a new metal:
what the F**ck was that??
the same scheme was everywhere:
'07 Golf TDI |
Posted: Sat Oct 15, 2016 12:58 pm Post subject: Re: 1303S from Ukraine-slow build |
All this need to be redone!
The good news is that the new metal guy did a wonderful job with all this, and see how it looked after:
'07 Golf TDI |
Posted: Sat Oct 15, 2016 1:09 pm Post subject: Re: 1303S from Ukraine-slow build |
What was done at the front.
The front side repair panels are not a perfect quality as you probably know. The previous shop did the main work, but many small things left to do.
The fuel lid before:
after:
All suspension welding at the front was strengthened
Antenna hole shaved:
'07 Golf TDI |
Posted: Sat Oct 15, 2016 1:30 pm Post subject: Re: 1303S from Ukraine-slow build |
Preparing:
Rear wings were widened, we are building a Germanlook here!!
Stock rear wing vs wide one:
'07 Golf TDI |
Posted: Tue Oct 18, 2016 1:01 pm Post subject: Re: 1303S from Ukraine-slow build |
this is what i found on the local classifieds for $50 - envy if you want))
In a good condition, but has some weird holes in the middle. I think the number plate will cover them perfectly _________________ '73 1303
'07 Golf TDI |
wcfvw69 Samba Purist
Posted: Tue Oct 18, 2016 2:16 pm Post subject: Re: 1303S from Ukraine-slow build |
Wow.. lots and lots of work to revive that bug! Nice job.
I'm curious if you don't mind sharing. What did you pay for that bug there and how much $ have you put into it so far? I'm just wondering in the differences in cost there vs. the US.
Keep up the great work and look forward to your updates. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Wed Oct 19, 2016 1:28 pm Post subject: Re: 1303S from Ukraine-slow build |
wcfvw69 wrote: |
I'm the kind of guy who dont count everything, in this case it is good because otherwise i'll have a heart attack
I think that at this point it cost me around $10000 _________________ '73 1303
'07 Golf TDI |
