Porsche Sealing washers on 36 hp
Rwoodshvac
Rwoodshvac is offline
PostPosted: Mon May 14, 2012 11:03 am    Post subject: Porsche Sealing washers on 36 hp Reply with quote
I came across these Porsche 356/912 Sealing washers and gaskets.
The washers are beveled for the use of an o ring gasket
What are your thoughts on these being used on a 36 hp case?
I really like the design and the idea of not have to use a gasket sealer . on the nuts and wahsers.
Plus the Porsche look with the acorn nuts.
Feedback welcomed
57 Ragtop Semaphore Sedan
48 Aluminum Case drilled tapped, Full Flow Filter
Porsche 356 B Crankshaft 74mm
Porsche 356 B Rods
Shasta Cylinders with JE Pistons 80mm
WW Okrasa Heads worked by Ron Chuck
Speedwell Ratio Rockers 1.25
Dual Valve Springs w/Lash Caps
Blackline Racing Lifter Inserts, Manton Push Rods
34 Pbic Carbs rebushed by Mr Okrasa
Custom Okrasa Intakes enlarged to 34mm
Gene Burg Sump
Fram bypass Filter with Okrasa Oil Cooler
slalombuggy
slalombuggy is offline
PostPosted: Mon May 14, 2012 2:24 pm    Post subject: Reply with quote
Good enough for Porsche, good enough for VW. Can't see why these wouldn't work as long as the case surface is clean and fairly flat and pit free.
brad
sgmalt46
sgmalt46 is offline
PostPosted: Tue May 15, 2012 8:17 am    Post subject: Reply with quote
yes run them! . they look cool. ive seen them used on 36's. i still would use a dab of sealer under the washer to be safe but not needed. i just hate any kinds of leaks.
ONEBADBUG
ONEBADBUG is offline
PostPosted: Tue May 15, 2012 7:32 pm    Post subject: Reply with quote
Or use Statoseals.
https://www.pegasusautoracing.com/productselection.asp?Product=3245
