Felipe de Espaņa Samba Member
Posted: Thu May 17, 2012 8:52 am Post subject: Shocks |
Asking the choir that sings here each and every day.......
Mine is a totally stock,(not lowered) 2nd owner 64 coupe.
Have had it for over 20 years and from what I can tell the
Shocks on my girl have never been replaced. Ball joints and tires
are fine as is the tire pressure. Needless to say, ride is a little bumpy.
What does the Samba choir recommend for replacements?
Brand? Gas or not? Positive and Negatives would be greatly
appreciated? She's still running the 1300 motor. I'm not planning
on heading to Laguna Seca maybe Pacific Coast Highway!
Muchos Thank You's!!
F. de Espaņa
Mine? 64, 2nd owner. Glad you asked. |
kingkarmann Samba Member
Posted: Thu May 17, 2012 9:09 am Post subject: |
I originally installed Bilstein gas shocks. Way to hard for a stock ride. Swithcked to Boge oil. Much better  _________________ Retired Sambanista |
sactojesse Samba Member
Joined: November 21, 2006 Posts: 1947 Location: Sacramento, California, USA
Posted: Thu May 17, 2012 9:46 am Post subject: |
Agreed. Boge oil for ride quality. I haven't found any gas shock that works well in the light front end of a ghia. Even my light-pressure KYB GR2s, which are more comfy than Gas-A-Justs, are pretty stiff in front. _________________ 1966 Karmann-Ghia convertible |
Posted: Thu May 17, 2012 10:09 am Post subject: |
Great! Looks like Boge Oil it is. I read that these are the
closest to factory or originals out there on the market.
Would most of the Choir here agree?
Thanks for the answers kingk. and sactojesse!
F. de Espaņa
jjjjjoey Samba Member
Joined: January 20, 2009 Posts: 152 Location: So. Cal.
Posted: Thu May 17, 2012 2:13 pm Post subject: |
I was just thinking about my car's shocks the other day...saved me the search. _________________ ________
67 Ghia n00b |
Murdlem Samba Member
Joined: February 06, 2004 Posts: 370 Location: Cheney, Washington
Posted: Thu May 17, 2012 4:59 pm Post subject: |
And since we are on this topic, what is best for lowered with adjustable beam in front? _________________ Eric Meldrum
70 Ghia Coupe
72 Ghia Convertible |
Posted: Fri May 18, 2012 9:59 am Post subject: |
| Murdlem wrote: | | And since we are on this topic, what is best for lowered with adjustable beam in front? |
For an adjustable front beam, you will need shorter shocks. I'm running the KYB GR2 low pressure gas shocks in front w/ my adjustable front beam and they are still pretty stiff, but I don't mind.
http://www2.cip1.com/ProductDetails.asp?ProductCode=KYB-343208
I don't often recommend anything made by EMPI, but they do make a lowered/shorter fluid front shock that will likely ride better than the GR2s I have, but I haven't personally tried them.
http://www2.cip1.com/ProductDetails.asp?ProductCode=C13-9653 _________________ 1966 Karmann-Ghia convertible |
c21darrel Samba Member
Joined: January 22, 2009 Posts: 1066 Location: San Dimas
Posted: Fri May 18, 2012 10:57 am Post subject: |
Not all adjustable beams will need the short shocks. I bought them first and could not get them to extend enough to fit. Got the regular length KYB GR2's and they fit fine. I am lowered with drop spindles and narrowed adjustable beam.
rickpereira Samba Member
Joined: May 25, 2010 Posts: 202 Location: Sydney, AUstralia
Posted: Sat May 19, 2012 1:36 am Post subject: |
agreed with c21darrel
have to return my lowered shocks for the same reason, i couldnt extend mine enough to fit even with the beam adjusted all the way down and no drop spindles. |
Posted: Sun Jun 17, 2012 2:11 pm Post subject: |
That is what I was thinking. So, is there any reason NOT to go with the oil shocks mentioned earlier in this thread for the adjustable front beam? _________________ Eric Meldrum
70 Ghia Coupe
Volfandt Samba Member
Joined: March 15, 2012 Posts: 398 Location: Knox County, East TN
Posted: Mon Jun 18, 2012 5:47 am Post subject: Good topic |
Good topic. I'll have to address my rear shocks and perhaps even the fronts come winter time.
I currently have coil over shocks on the rear and I'm pretty sure they're a main contributor to my somewhat rough ride.
There just seems to be a lack of shock absortion with those coil overs.....
I actually like the "stance" of my Ghia at this point and figure the rear may sag when I switch over to oil filled shocks.
I dunno, will cross that bridge when I gets to it, I rekon
Dave _________________ 1972 Karmann Ghia, the Dragon slayer....
1949 Chevrolet 3100 1/2 ton pkup.
1966 Wheel Horse 856 (gear)
1966 Wheel Horse 876 (hydro) |
andk5591  Samba Member
Joined: August 29, 2005 Posts: 8893 Location: State College, PA
Posted: Mon Jun 18, 2012 6:37 pm Post subject: |
Not sure if Ghias are the same as a type 1, but Aircooled.net sells a properly valved GR2 for lowered applications. Most places sell a way too stiff shock. _________________ D-Dubya Manx clone - 63 Short pan,1776.
Max - 73 standard project at wife's request and your gonna die when you see this one. |
Posted: Mon Jun 18, 2012 7:27 pm Post subject: |
WoW!
My post from back in May made it
back up to the top! I still haven't made
the jump to the Boge's yet but, my
VW pals all agree with the stock set up
and past members replies. Mucho's Thank
You Samba Choir members!
F. de Espaņa
Posted: Tue Jun 19, 2012 12:16 pm Post subject: |
| andk5591 wrote: | | Not sure if Ghias are the same as a type 1, but Aircooled.net sells a properly valved GR2 for lowered applications. Most places sell a way too stiff shock. |
Yes, that's what I have on the front of my ghia. The GR-2s are stiffer than Boge fluid shocks, but not as ridiculously stiff as the KYB Gas-A-Justs. _________________ 1966 Karmann-Ghia convertible |
Zack1978 Samba Member
Posted: Sat Nov 17, 2012 2:21 pm Post subject: |
So where do you buy Boge shocks from? Are they expensive?
What about Monroe Monro-Matic Plus? Are they of good quality? The price for the Monroe's is cheap.
Zack _________________ 1972 Coupe
Posted: Sat Nov 17, 2012 2:30 pm Post subject: |
Are Sachs shocks the same brand as Boge? I noticed that Rockauto has Sachs rear shocks but not Sachs front shocks. Where is the best place to buy this brand? I would buy the rears from Rockauto.
Thanks,
Zack _________________ 1972 Coupe |
Posted: Sun Nov 18, 2012 2:40 pm Post subject: |
bump.....any more shock info? _________________ 1972 Coupe |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 8125 Location: Black Forest, CO
Posted: Sun Nov 18, 2012 3:40 pm Post subject: |
| Zack1978 wrote: | | Are Sachs shocks the same brand as Boge? |
They are now. The shocks I got early this year have both brand names on them.
Max _________________ The only thing more expensive than cheap parts is mixing cheap parts with stupidity. |
Posted: Sun Nov 18, 2012 4:10 pm Post subject: |
| Max Welton wrote: | | Zack1978 wrote: | | Are Sachs shocks the same brand as Boge? |
Max |
Where did you get them from? How much were they?
Posted: Sun Nov 18, 2012 5:01 pm Post subject: |
I actually had them sourced through the local ACVW shop. I don't shop by price and I really don't remember what I paid for them.
"Boge" is stamped on the shock while the "Sachs" name is on a sticker. So I'm hoping these are still the Boge shocks just being sold through Sachs. They've been working well on my type-3 and don't squeak like the cofaps I took off.
