Wheres my fuel gone?
Robbo112233
Robbo112233 is offline
PostPosted: Thu May 17, 2012 2:02 pm    Post subject: Wheres my fuel gone? Reply with quote
My MPG is terrible, it never used to be bad but now it is terrible. It must be something wrong.
Its been bad for a while now, i thought it was the Carb so i rebuilt it but its still bad.
I have a 1973 with a 1200 engine. Running a 31 Pict 4 carb.
What could be the issue? What could i check?
Sorry if i left some information out, lemme know if you need more.
1973 Bug
Beetle Bums VW Club member
Archie's Photo Gallery
pafree
pafree is offline
PostPosted: Thu May 17, 2012 2:15 pm    Post subject: Reply with quote
timing being off will effect the gas mileage. wouldn't hurt to check the valve gap before checking the timing and then readjust the carb.
what is the ethanol percentage over there now?
Robbo112233
PostPosted: Thu May 17, 2012 2:41 pm    Post subject: Reply with quote
I will check my valves and the timing. Then readjust the carb. Thanks.
And i have no idea how much ethanol Confused
1973 Bug
djkeev
djkeev is offline
PostPosted: Thu May 17, 2012 4:22 pm    Post subject: Reply with quote
Pull your engine oil dipstick, is it way too full?
If yes, fuel pump is shot.
Dave
(o\ ! /o) (o)=l=(o)
1974 Super Convertible
http://www.thesamba.com/vw/forum/viewtopic.php?t=482968&highlight=rust+repair
Creating a 69 1/2 Ghia Convertible out of a 69 Coupe and a 70 Convertible
And the newest arrival!....... 86 Vanagon Westy!
TjdTaylor
TjdTaylor is offline
PostPosted: Thu May 17, 2012 7:29 pm    Post subject: Reply with quote
Dave
I dont get it.
1974 SuperBeetle Build
Beetle Bums VW Club Member
Jamies74sb wrote:
I can't see myself cutting up my super beetle . Maybe a oval or 61 or so with the small windows
jays
jays is offline
PostPosted: Thu May 17, 2012 7:32 pm    Post subject: Reply with quote
Dave
I dont get it.
the fuel that should just stay still is instead going to the engine through the fuel pump.... a leak.
1970 Käfer
TjdTaylor
PostPosted: Thu May 17, 2012 7:42 pm    Post subject: Reply with quote
oh
slione
slione is offline
PostPosted: Thu May 17, 2012 7:43 pm    Post subject: Reply with quote
Did you check your fuel lines? You could have cracks in the rubber/fabric-covered hoses and not realize it.
What about your tank? Any pinholes? I had a small leak that I did not notice for a while but when I pulled the tank and I found the rust hole. Until then I thought my fuel gauge was broken.
1974 SB Vert Orange Bug - Getting there, slowly but surely
Robbo112233
PostPosted: Fri May 18, 2012 3:51 am    Post subject: Reply with quote
Dave
Checked this, the oil is fine. If anything i may need to top it up. But its whinin the lines.
I have checked all this, replaced all fuel lines and removed the tank. There is a rusted area on the tank but it is only very slight surface rust. No holes of other areas of concern.
1973 Bug
djkeev
djkeev is offline
PostPosted: Fri May 18, 2012 5:34 am    Post subject: Reply with quote
Well, in that case maybe your neighbor is messing with you removing gas at night?
or more realistically..........
It is time for a complete tune up check. Adjust the valves, do a proper electrical tuneup and make carb adjustments.
Also make sure your fuel system isn't "percolating" after shut down and fuel is seeping into the cylinders with a hot engine.
Keep in mind that some of these engines for whatever reasons don't get good fuel mileage and you may just have one of them.
but if you used to get good mileage, you should be able to again.
Dave
(o\ ! /o) (o)=l=(o)
Robbo112233
PostPosted: Fri May 18, 2012 7:44 am    Post subject: Reply with quote
Dave
The neighbour has been giving me dodgy looks.......
But yeah, i will be doing a complete tuneup next week, hopefully i can get back to the kind of MPG i was getting a few months back
1973 Bug
