66brm Samba Member
Joined: January 25, 2010 Posts: 2526 Location: Perth Western Australia
Posted: Thu May 17, 2012 6:42 pm Post subject: 2007 Head Cam combinations |
Hi Guys, picked up a cheap 1835 that I am going to rebuild into a 2007cc, just looking for suggestions on cam, CR and heads for a DD
Ancillaries are 40IDF's 30 vents, A1 sidewinder, in a 1964 T1, stock trans, 010......
I was thinking something like a WebCam 163 (seems between an Engle W110 and 120) with ACN L3's, at 8.5 CR. Thinking I'll probably need dual springs with this combo.
Or should I think about larger valves up to 40 x 35.5's? _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
| modok wrote: | | I am an expert at fitting things in holes, been doing it a long time |
j8bug Samba Member
Joined: September 26, 2008 Posts: 1646 Location: When we were all (213) Los-Angeles
Posted: Thu May 17, 2012 7:09 pm Post subject: |
here's my 2007cc combo in my 62 daily.... tims stage 1s (40x35s), 9-1cr, engle 120, 44 webers, 1 5/8 exh. 125 horse/125 torque. love it!!! _________________ Frank Ochoa said; "I still have my convertible bug from high school. Now that Gramps is out Im going to make some changes but Im still going to keep it Cal-Style, you know, all original but lowered with some alloys"
Fred one of the original members of The Bus Boyz said; "We were the first to ever Cal-Style a Bus.. No one was doing it back then". |
66brm Samba Member
Posted: Thu May 17, 2012 7:12 pm Post subject: |
Sounds like it would rip, whats the low rpm drivability like? _________________ Aust. RHD 66 Type 1
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7557 Location: Whittier,CA
Posted: Thu May 17, 2012 7:26 pm Post subject: Re: 2007 Head Cam combinations |
Yeah, with a 2 liter you can effectively use bigger valves. DRD/AC.Net L5 heads or Tims Stage 1, can't go wrong with either of those. Never used a Web 163 but if you are looking at something a little different you might consider Steve Long's SLR cams. These are the old Erson grinds. Something like the XR296, 296/254 duration, 0.366/0.512 lift w/1.4 rockers. DRD sells SLR cams and he says this cam is great for a street motor, lots of pull to 6k. Probably work really well with the 40IDF's. You can also get a set of reground parkerized lifters to go with the SLR cam. _________________
| Mitey62 wrote: | | Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on. |
| RockCrusher wrote: | JB weld the case halves....that'll keep the fretting to a minimum.  |
j8bug Samba Member
Posted: Thu May 17, 2012 8:32 pm Post subject: |
| 66brm wrote: | | Sounds like it would rip, whats the low rpm drivability like? |
Its a pleasant cruiser like any other. just got back from a 30 mile drive to check out a vert for sale and it was a wonderfull drive. Its not a high winder like some of my other motors Ive had in that bug but it can still take care of business if tempted  _________________ Frank Ochoa said; "I still have my convertible bug from high school. Now that Gramps is out Im going to make some changes but Im still going to keep it Cal-Style, you know, all original but lowered with some alloys"
mark tucker Samba Member
Joined: April 08, 2009 Posts: 8487 Location: SHALIMAR ,FLORIDA
Posted: Thu May 17, 2012 8:38 pm Post subject: |
| the one darth sugested has low lobe lift,(witch I like ) witch should be a good one and last a long time just use the 1.4 rockers like he said and it should be the butterflyes eyes.(I would use a 1.55 or 1.6 ratio,but the 1.4 would be nice) |
66brm Samba Member
Posted: Thu May 17, 2012 8:53 pm Post subject: |
Yeah I think its a line ball on the L5's, reading Johns (ACNet) description it may be over kill on the porting side but the valve size would suit.
I'll have a gander at Tims heads( Their website seems to be gone)
I run 40 intakes on my current 1600cc but want this combo to be better matched _________________ Aust. RHD 66 Type 1
Posted: Thu May 17, 2012 9:15 pm Post subject: |
This website is no longer available. That's not good. Here's their ad in the Samba classifieds: http://www.thesamba.com/vw/classifieds/detail.php?id=1069091
On the L5's, you can never have too much port work. 40 x 35.5's match up very well with 90.5mm P/C's. 42 x 37.5's....that's over kill right there. _________________
vwsb74 Samba Member
Posted: Thu May 17, 2012 9:47 pm Post subject: |
| j8bug wrote: | | here's my 2007cc combo in my 62 daily.... tims stage 1s (40x35s), 9-1cr, engle 120, 44 webers, 1 5/8 exh. 125 horse/125 torque. love it!!! |
what is your jetting? do you have a dyno graph?thanks _________________ 74 super beetle
2011 ford explorer
2010 mazda 3 hatch back |
66brm Samba Member
Posted: Thu May 17, 2012 10:00 pm Post subject: |
Darth, would the 256 deg (Web Cam 163)/(SLR XR296) 230 deg durations make a huge difference?
Will be running 1.25 rockers, is it worth considering running different lobe centres? or advance/retard the cam as the engine will see most of its time between 2500-4500rpm with occasional squirts to 5000+ _________________ Aust. RHD 66 Type 1
Posted: Thu May 17, 2012 10:39 pm Post subject: |
The Web 163 has 249 duration while the XR296 is 254. Not a huge difference in performance but you wouldn't notice the drop off in power as much above 4500 with the XR. However, the XR296 is designed for 1.4 rockers. With 1.25's your lift would be about 0.457" compared to the 163's 0.479". As far as running different lobe centers or advancing or retarding the cam....Time to call in the experts. All I can suggest is contact the guys at Web cam or Steve Long Racing for their advice. _________________
modok Samba Member
Joined: October 30, 2009 Posts: 8612 Location: Colorado Springs
Posted: Thu May 17, 2012 10:52 pm Post subject: |
I have ran many cams in my 1955/2007cc combos
by far the web 163 and web 110 are my favorites, quiet and the 240 LB open valve springs seem to cope just fine
if the carbs and exhaust is tuned right you can pull smooth from very low rpms even with that web 110 (I was just marveling at that today on the way back from work , we don't need no mild cams )
port velocity makes more difference than anything, ported 043 castings like the panchitos are the way to go, or something similar |
66brm Samba Member
Posted: Thu May 17, 2012 10:56 pm Post subject: |
Yeah I was also looking at Brothers oval ports potentially, keeping the port size reasonable so port velocity is good, then throttle response doesn't lag behind.
modok, the 240 lb springs you mention are they a HD single or dual?
I think overall any of the heads that have been mentioned will work well, just need to find the right ones _________________ Aust. RHD 66 Type 1
modok Samba Member
Posted: Thu May 17, 2012 11:04 pm Post subject: |
The heads I am running now are mostly copies of how berg used to do them, the intake ports do not look big, that's for sure
My springs are fancy oval wire beehive singles, but you can get the same pressure out of strong HD singles shimmed close to bind or perhaps cb dual springs setup easy
so I take it you didn't buy that big old low compression sucker you were looking into? |
Cptn. Calzone Samba Member
Joined: June 27, 2007 Posts: 1009 Location: S>E>Alabama
Posted: Fri May 18, 2012 4:27 am Post subject: cam |
I recently stepped up to the web 163 after speaking with q uite a few folks who run them in a 2 ltr bus. Heads are Timms 1 1/2 Dell 40s sidewinder header. Looking foward to the torque and pull for my work truck SC. _________________ 71 Westy, Quintilla 67 912 Porsche 67 SC currently in paint!! |
66brm Samba Member
Posted: Fri May 18, 2012 10:27 pm Post subject: |
| modok wrote: |
Nah, it wasn't a bad deal but would need to be stripped down for full flow mods etc, I just couldn't justify $5000+ shipping only to pull it down for more work, with this 1835, most of its been done but not done well, but at least the AH case is sound, I'll do a clean up of whats in it and take some pics, the heads are worked over and flycut bigtime, running thick shims under the barrels to correct the CR, the combustion chambers are really odd shapewise.
But what do you expect for $400? The full flow is really funny screw a bolt into the pump body, and cut the head off with an angle grinder, then weld a hydraulic fitting to a stock cover and drill a hole in it. _________________ Aust. RHD 66 Type 1
66brm Samba Member
Posted: Sun May 20, 2012 5:11 pm Post subject: |
Did a thorough clean up on the case yesterday, 1st line bore, the bearings on the crank still have the ink stamps visible, I think I have a name for the heads.......anti Bergs, weld up the chambers for heaps of squish (even on the plug side), insert larger valves, flycut till you remove the first cooling fin, get down to 40-45cc chambers then slap 2mm spacers under the barrels to get the CR down, and run a 911 fan with dual KDuds  _________________ Aust. RHD 66 Type 1
modok Samba Member
Posted: Sun May 20, 2012 5:13 pm Post subject: |
THat's crazy!
66brm Samba Member
Posted: Sun May 20, 2012 5:16 pm Post subject: |
Oh and I forgot to mention they put the step back in, but only 1mm or less  _________________ Aust. RHD 66 Type 1
Posted: Sun May 20, 2012 5:29 pm Post subject: |
Now THAT'S thinking outside the box!
Ship it to California for a dyno test.......betcha get at least 205 HP! _________________
