Reduction Gear Box conversion to swing axle
Forum Index -> Performance / Engines / Transmissions Share: Facebook Twitter
Paulfive5
Paulfive5 is offline
PostPosted: Thu May 17, 2012 8:34 pm    Post subject: Reduction Gear Box conversion to swing axle Reply with quote
I have a bus transmission with reduction boxes that seems to be fried. When I was pushing the buggy, the transmission seemed to be in gear when the gear shifter was in neutral, and when I pulled the 40hp engine, the input shaft pulled out of the transmission. Is it an easy swap to a swing axle from a bug? How weird is it inside the transmission? Are the reduction boxes easy to split and remove? This is all on a piece of poo bugggy that probably won't see too much hard use.
mcmscott
mcmscott is offline
PostPosted: Fri May 18, 2012 8:27 am    Post subject: Reply with quote
A t-1 swing has the ring gear on the oppisite side of the trans, you will have to flip the ring gear, reset backlash, then r-r reduction boxes. I f you don't flip the ring gear you will have 4 reverse gears and one weak foward gear
Paulfive5
PostPosted: Fri May 18, 2012 8:56 pm    Post subject: Reply with quote
Sounds like I'd be better off changing the whole thing and get rid of the reduction boxes. The spring plates on my reduction boxes are not notched to fit around the axle tube for a swing axle. Is it a big deal to change spring plates?
mcmscott
mcmscott is offline
PostPosted: Sat May 19, 2012 7:31 am    Post subject: Reply with quote
That depends on your torsion housing, If a t-1 housing was used then its a direct swap, if the original builder used a t-2 housing then a little fab work is in order
mcmscott
mcmscott is offline
Sterling VW
Sterling VW is offline
PostPosted: Mon Oct 28, 2013 9:59 am    Post subject: Reply with quote
im considering do the same thing on a brush buggy im building. i think my gear reduction bus trans is junk, not sure, rubber covers from trans to shafts are toast so id assume its junk......my tortion cover sticks out very far unlike my other buggies....i. need to find out what type it has befor i go much further.anyone got some pix/model years of the tortion covers so i can tell diffrence?
Happy motoring from Sterling's Mobile VW Repair Smile
View user's profile Send private message Send e-mail Facebook Classifieds Feedback
Reply to topic    Forum Index -> Performance / Engines / Transmissions All times are Mountain Standard Time/Pacific Daylight Savings Time
