drumrooster Samba Member
Joined: January 06, 2013 Posts: 36 Location: SOMERSET,KY
Posted: Sat Oct 26, 2013 7:28 pm Post subject: Super beetle carb setup to run?? |
stock dual port motor with a porsche style pipe..I"d like to get a new carb set up for the street? something with a elect choke and good for gas milage and just a good running carb..any suggestions to what set up woul be best?? would a dual carb set up use alot more gas? and would duals make a power difference?
or should i just run a single webber? or holley? if the performance is enough improvenemt then 2 carbs? or not thanks for yr time.. |
modok Samba Member
Joined: October 30, 2009 Posts: 26789 Location: Colorado Springs
Posted: Sat Oct 26, 2013 10:10 pm Post subject: |
The single carb setups generally suck in most respects, but do well in certain applications, like offroad or mild big CC engines.......
For a near stock engine kadrons are good, dual IDFs are great too but I'll admit they do take a bit more $$ and knowledge.
Dual 36mm Dellortos or weber IDFs get the best MPG out of anything available. Yeah they look huge but they use less fuel
Chokes are usually not needed with dual carbs, witht eh accelerator pump shooting right into the head you really don't need chokes! |
Quokka42 Samba Member
Joined: December 02, 2010 Posts: 3117 Location: Melbourne, Australia
Posted: Sun Oct 27, 2013 1:26 am Post subject: |
The progressive and other single carbs can be made to work on appropriate engines. Once your duration gets too big, it becomes difficult to tune, and eventually you will run into trouble with the capacity of the end castings, especially if you have also increased capacity. Single barrel dual carbs also put a limitation on how much cam you can run.
Kadrons and dellortos are no longer available new, so if you buy second hand you might get stiffed. Reliable places sell some good rebuilt units, but run close to the cost of IDFs.
If your engine is fairly close to stock, run the progressive or ICTs for your application. Otherwise you might as well go straight to the IDFs. _________________ There has only ever been one man who was perfect, and they nailed Him to a cross. |
Posted: Sun Oct 27, 2013 6:53 pm Post subject: carbs? |
so yr sayin the progressive single carb would be fine? wow! those others are high $...single progressive kit $389.. |
modok Samba Member
Posted: Sun Oct 27, 2013 7:05 pm Post subject: |
Don't spend more than 150$ on it, that's all you'll get for a weber progressive kit used.
see? http://www.thesamba.com/vw/classifieds/search.php?...ton=Search
only suckers spend 400$ for that junk setup
But due to the large number of suckers buying them new there is a surplus of good used ones......... many with very low hours |
Posted: Sun Oct 27, 2013 7:33 pm Post subject: CARB |
thats ounds more like it thanks for the info if u happen to see a good one hit me up |
sactojesse Samba Member
Joined: November 21, 2006 Posts: 2655 Location: Sacramento, California, USA
Posted: Mon Oct 28, 2013 10:39 am Post subject: |
modok wrote: |
Dual 36mm Dellortos or weber IDFs get the best MPG out of anything available. Yeah they look huge but they use less fuel |
Agreed. Dual Dellorto 36 DRLAs or Weber 40 IDFs would be my choice on a stock 1600 DP.
I wouldn't touch a progressive with a 10 foot pole, except maybe to push it off a cliff. _________________ 1966 Karmann-Ghia convertible |
