vwlovr73 Samba Member
Posted: Wed Mar 09, 2016 2:04 pm Post subject: |
arizonabuckeye wrote: |
vwlovr73 wrote: |
grandpa pete wrote: |
vwlovr73 wrote: |
you are looking for uncovered door panels . the cost for an inexpensive set of 4 black ones is $65 . would it be easier to buy a cheep set for the cardboards ? |
That's my plan if I can't find just the uncovered panels - buy some cheap ones and rip off their covering. There's just something that feels so wrong about destroying something, know what I mean? |
It's for the "greater good " |
True, true. |
This would be an awesome thing to have in a digital format. Something we could take to a printer that has a wide format printer and have a template printed out. Would make creating your own panels much easier. |
It really would. If I think of it, i'll take some measurements of where everything is on the panel and the overall dimensions, and post that in the future.
My husband got me a set of plain new door cards from mid america. I ended up using those. I took them to the upholsterer a few weeks ago to make them match my seats, and I'm looking forward to seeing them finished. _________________ 1963 Beetle euro spec "Darrel" (since 2012)
Past - 1973 Beetle "Arthur" (owned 1998-2005)
Red River VW Club- http://www.redrivervwclub.com |
grandpa pete Samba Member
Posted: Sun Mar 27, 2016 9:29 pm Post subject: Re: My 63 Bug "Darrel" Back on the road after 34 years |
Just found your thread again ; it's coming along nicely .......I was getting frustrated that mine has gone on for 2 1/2 years...your going on 4 ; thanks ;I needed a little inspiration ......
thanks for keeping up with the postings _________________ 63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery |
cn63bug Samba Member
Joined: August 19, 2011 Posts: 114 Location: Mt. Juliet, TN
Posted: Mon Mar 28, 2016 9:26 am Post subject: |
vwlovr73 wrote: |
vwlovr73 wrote: |
vwlovr73 wrote: |
True, true. |
My husband got me a set of plain new door cards from mid america. I ended up using those. I took them to the upholsterer a few weeks ago to make them match my seats, and I'm looking forward to seeing them finished. |
I made my own door cards out of a material called palight. It's a PVC based material that is the same thickness as the original badly warped cards that I had. I removed the material from the original door cards and mounted them on the palight. I can post pictures of it later but they fit perfect.
I measured the original cards and created a file that I could use on our flatbed router at work and it cut perfectly. I have PDF of the templates that is actual size but they are for 65-66 though. I could make some patterns up if I could get access to an earlier card. Just a thought...
Drivers side
Passenger side
These are what the 65-66 look like. Again, I have a PDF of them at actual size if anyone would like it.
Chris |
Posted: Tue Apr 19, 2016 8:14 am Post subject: |
cn63bug wrote: |
I measured the original cards and created a file that I could use on our flatbed router at work and it cut perfectly. I have PDF of the templates that is actual size but they are for 65-66 though. I could make some patterns up if I could get access to an earlier card. Just a thought... |
These are awesome!!! _________________ 1963 Beetle euro spec "Darrel" (since 2012)
Posted: Tue Apr 19, 2016 8:25 am Post subject: Re: My 63 Bug "Darrel" Back on the road after 34 years |
After a couple of nice weekends it got cold here again and I don't have a heated garage. So the bug's been sitting there without interior, waiting on the next steps.
I got the headlight buckets sanded down and ready to paint. I did manage to spray a coat yesterday, need to sand more though. I did not do as smooth a job sanding as I'd thought.
Broke out the heat gun to scrape the remnants of the tar off the pans. It worked great. Only took an hour or so and I got all of it off except what's near the gas line
BRAKE LINE. Thanks Nancy
Wire brushed the rusty areas, lightly sanded, vacuumed, wiped, vacuumed again, used a tack cloth, put down some rusty metal primer on the areas that needed it. Going to sand a bit more then coat with gloss black. It's not perfect, but it'll do the job, and it's going to be under dynamat, closed cell, and rubber mats anyway. So I am thinking perfection isn't needed for this part of the project.
Also planning to get the stereo in, the front carpet, and the door panels. And re-install the rear fender with new brackets. That and some mechanical maintenance and then back on the road for the summer. Hoping to have it done in 4 weeks actually, because there is a club cruise it'd be fun to attend.
I didn't take any pics except this one of the rusty headlight bucket before I took off the parking light mount and started on it with the steel wool.
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Tue Apr 19, 2016 9:22 am Post subject: Re: My 63 Bug "Darrel" Back on the road after 34 years |
vwlovr73 wrote: |
Shouldn't be a fuel line inside? Brake line maybe? |
Posted: Tue Apr 19, 2016 9:26 am Post subject: Re: My 63 Bug "Darrel" Back on the road after 34 years |
nlorntson wrote: |
vwlovr73 wrote: |
I assumed it was fuel since it's a metal line and runs up next to the accelerator pedal. Could be anything in there as far as I know. It's running in through the firewall and up along the driver side of the tunnel, then disappears behind the pedals. I figured it might have gas in it and thus best not to heat it up. _________________ 1963 Beetle euro spec "Darrel" (since 2012)
Posted: Tue Apr 19, 2016 10:00 am Post subject: Re: My 63 Bug "Darrel" Back on the road after 34 years |
nlorntson wrote: |
YUP. Googled. Brake line.
I guess it's good not to heat that up either. _________________ 1963 Beetle euro spec "Darrel" (since 2012)
jmonheim Samba Member
Posted: Tue Apr 19, 2016 2:27 pm Post subject: Re: My 63 Bug "Darrel" Back on the road after 34 years |
yeah when I first saw the brake line in our bug I thought somebody ran it like this but after looking it up this stock? seems weird to me to be inside the car |
Posted: Tue Apr 19, 2016 2:28 pm Post subject: Re: My 63 Bug "Darrel" Back on the road after 34 years |
Posted: Mon Apr 25, 2016 7:50 am Post subject: Re: My 63 Bug "Darrel" Back on the road after 34 years |
Saturday my daughter was out with grandma, so I got in a full day working on the bug. Heat gun did a great job taking the remainder of the tar off. Easier than I expected. Primed and painted that. It isn't perfect, but it's going to be underneath the dynamat, closed cell foam, and then carpet/mats. So I didn't feel like it needed to be a mirror finish. I just wire brushed, then wire-wheeled it, hand-sanded, vacuumed, tack cloth, vacuumed, and tack cloth again. The surfaces weren't totally smooth, just due to the surface rust and other wear.
Finished working on my headlights. (Or I thought I did.) I'm just cleaning them up, doing a quick respray, and new seals. I think I said a while back that I got a replacement light from a friend last fall. I wanted the adjustment screw locations to match, I had one at 5 and 7 and one at 2 and 7. These new ones are both 2 and 7.
Got them all done with the new seals and all, and... and realized one of these things is not like the other. The one on the left is a bus headlight....
Sometimes all you can do is laugh. Another friend has a headlight for me 5 & 7 I think, so I'll pick that up later this week and start the process again. Learning experience: headlight buckets used to scare me with all their pieces but now i can tear one down in just a couple minutes time.
Then since it was such a nice day (before a cold front and rain came in), I decided to clean and spray my back bumper brackets before I put the bumper back on. I had bought new ones for the back after removing the thrashed ones last fall. Then thought to myself that I ought to do the front ones too while I'm at it. So I took off the front bumper. Then noticed the insides of the blades & guards were looking pitted, better take care of that too.
I sprayed them silver; I am not sure that's correct but I knew they're either supposed to be silver or grey. Sprayed the inside of the bumpers with self etching rust-stop. Then sprayed over that with the same silver. It's damn near sparkly in there, which isn't what I wanted. Hope it doesn't look too dumb reinstalled (but, when was the last time you looked inside a bug's bumper blade anyway?). In the future I plan to have them stripped, repaired, and re-chromed, so this is only temporary.
Up next...
-One more headlight.
-Polish up and re-install the bumpers
-Sound deadener/dampener... and a first for this bug... audio system. _________________ 1963 Beetle euro spec "Darrel" (since 2012)
sportin-wood Samba Member
Joined: September 12, 2010 Posts: 2008 Location: Texas
Posted: Mon Apr 25, 2016 9:15 am Post subject: Re: My 63 Bug "Darrel" Back on the road after 34 years |
I don't think the insides of the bumpers painted looks bad at all. Might have to steal that idea from you. _________________ .
Paused 66 project bug
"Relax, all right? My old man is a television repairman. He's got this ultimate set of tools. I can fix it." --- Jeff Spicoli |
Posted: Mon Apr 25, 2016 10:28 am Post subject: Re: My 63 Bug "Darrel" Back on the road after 34 years |
sportin-wood wrote: |
I don't think the insides of the bumpers painted looks bad at all. Might have to steal that idea from you. |
Cool! Once i get them mounted i'll put up another pic or 2 of how it looks. _________________ 1963 Beetle euro spec "Darrel" (since 2012)
Posted: Mon May 02, 2016 9:05 am Post subject: Re: My 63 Bug "Darrel" Back on the road after 34 years |
I always tell my kid that if she would pay more attention, she wouldn't make so many mistakes.
Should maybe take my own advice. Thanks to nlorntson for pointing it out in a graceful way....
Behold my sideways headlights and upside down bumper bracket seals.
In the above pic i hadn't done the bumper brackets yet.
At least this stuff is easy to fix. After the mixup with the bus headlight, I got another headlight from a friend -- but it ended up being just too rusted out to work with. Since I want to actually start driving the car again ASAP, I just cleaned up my non-matching light so I'd have a working set.
Does anyone know if the correct light is the one with the adjustment screws at 2 and 7, or at 5 and 7? I have one of each. I thought I read that it was 2 and 7, but then I read elsewhere that they changed to 5 and 7 in 12/62. I don't care a lot, but it would be nice to know (at this point I just want them to match!).
We also measured and put down the fatmat. I don't have a roller & didn't buy the kit, so I need to find something that'll work and do that before the next step. A beer bottle didn't work very well - FYI. Still have more of it to do (door panels), but it's slow going when your helper is 2 years old.
Next steps:
--Fatmat on the side panels/doors
--Closed cell foam
--Fix the headlights and bumper bracket seals
--Reinstall the bumpers
--Install speakers and receiver
--Partial interior install (not installing anything that overlaps with the headliner, since I'm not going to do the headliner this year)
After all that and some other details I'll need to get an alignment and then be able to drive it this season. I wish I was driving it today. Weather's perfect. _________________ 1963 Beetle euro spec "Darrel" (since 2012)
Posted: Mon Aug 22, 2016 11:23 am Post subject: Re: My 63 Bug "Darrel" Back on the road after 34 years |
It's been a while because the last time I tried to post, I had a lot of trouble with pics and gave up. Plus, summer!!
But we did get old Darrel put together enough to drive. Cut and installed yoga mats over the top of the sound deadener.
Then installed 4 speakers and a Bluetooth receiver. It operates via a switch in the glovebox.
I had planned to then start carpeting, but hit a couple of hitches and decided to wait until Fall. First off, I can't install some of the carpeting until I do the headliner, and that's not on the list this year. Second, the weather was either too cold or too hot to do the work, and I ran out of time before wanting to hit cruises and shows.
Installed my new rubber mats. Was pretty nervous to cut the holes for the e-brake and shifter, but I'm pleased with the result.
I think I told you I took the door cards to the same upholstery shop where my seats were done.... back in February. Well, they STILL are not done. He does great work but boy, does he have a backlog. Every show I attended this year, I had my pink and teal yoga mats on display... annoying. I hope he gets them back to me before next year's shows... _________________ 1963 Beetle euro spec "Darrel" (since 2012)
Posted: Mon Aug 22, 2016 11:36 am Post subject: Re: My 63 Bug "Darrel" Back on the road after 34 years |
We attended a couple of shows this year. I try to attend the Red River VW Club's VWs in the Valley Show in Fargo ND every year, the last weekend of July. They put on a great show with activities all weekend, wonderful hospitality. It's worth the trip if you're anywhere in the region.
Posted: Mon Aug 22, 2016 11:59 am Post subject: Re: My 63 Bug "Darrel" Back on the road after 34 years |
The other show we attended this year was Dubs at the Lake in Killarney, MB. Amazing show and camping extravaganza. Killarney is west of Winnipeg, MB so if you're up in Canada or the northwestern US, get there if you can. It's worth the trip.
We attended the 1st annual in 2014 also. It was Aug 19-21.
All of us at the US / CA Customs. There are 9 VWs (some in trailers) in this shot...
Great trip. Drove Darrel the 190 miles each way without any issues. Except, we felt like we lost our hearing by the time we got home. Darrel has his original window seals (or lack thereof) and rattles unbelievably at highway speed.
While at the show, I got opportunity to drive a friend's very clean '62 a short distance and it reminded me that you don't have to go deaf driving a bug (or, stuff the windwings with napkins, which we also did).
I've dealt with it long enough. Time to order new window seals. Next up: watch me struggle with installing them. _________________ 1963 Beetle euro spec "Darrel" (since 2012)
Posted: Wed Jul 31, 2019 7:33 am Post subject: Re: My 63 Bug "Darrel" Back on the road after 34 years |
Last weekend, we took Darrel to VWs in the Valley in Fargo, North Dakota. One of the biggest shows in the region, put on by our car club.
In the past year or so Darrel has had some front end and steering work as well as a bit of fuss about the engine. A good friend helped me really buff him out too, he's quite shiny as you'll see! Wanted to share some pics of Darrel from the show.
Posted: Wed Jul 31, 2019 7:41 am Post subject: Re: My 63 Bug "Darrel" Back on the road after 34 years |
Jeeze, he looks good enough to win a prize. |
Airstream65 Samba Member
Joined: January 28, 2019 Posts: 172 Location: Tulsa,Ok
Posted: Wed Jul 31, 2019 3:01 pm Post subject: Re: My 63 Bug "Darrel" Back on the road after 34 years |
Looks great! |
