VicVan Samba Member
Joined: July 01, 2015 Posts: 1845 Location: Vancouver Island, BC
Posted: Tue May 29, 2018 9:53 am Post subject: A/C Compressor - Cracked mounting bracket |
Hi,
New van, new problems!
When I bought the van (1990, 2WD, Westfalia, factory AC) , it didn't have an A/C belt. I tried to put one on yesterday to test it, and I found out two things:
1/ All the adjustment hardware is missing (on the left part of the unit, to adjust the belt tension). Is this easily sourceable/replaceable? Anybody have any pictures?
2/ Slightly more concerning, this:
Is this repairable? On a scale that goes from duct tape to buying an new compressor and overhauling the entire system what's my best bet?
Cheers
JB _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Zeitgeist 13 Samba Member
Posted: Tue May 29, 2018 10:00 am Post subject: Re: A/C Compressor - Cracked mounting bracket |
You need a new compressor. This is a good opportunity to go through the system with a flush and reseal _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32638 Location: Reading Pennsylvania
VicVan Samba Member
Posted: Tue May 29, 2018 10:47 am Post subject: Re: A/C Compressor - Cracked mounting bracket |
Thanks for your input. I guess we'll spend the summer without A/C, see how it goes, and then I'll decide if we really missed it or not!
That will be a project for this winter, in addition to all other things I've postponed to winter.
djkeev wrote: |
I see the threaded rod in your photo for the A/C adjustment.
Are the other bits gone?
Dave |
Yes. I believe there are four parts: two threaded rods and two sliding nuts. I only have the one threaded rod, the others are MIA. Does the new compressor have these, or do I still need to find some? _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Posted: Tue May 29, 2018 11:17 am Post subject: Re: A/C Compressor - Cracked mounting bracket |
Check the classified section here for all the mounting bits you need. I've stopped driving my van until I resurrect the A/C after the engine swap. Once it gets close to 70F, it's just too miserable without the cool stuff circulating. _________________ Casey--
y u rune klassik? |
