Dash knobs - how to remove
Allyn132
Allyn132 is offline
PostPosted: Mon May 21, 2012 6:30 am    Post subject: Dash knobs - how to remove Reply with quote
Just finished removing my dash pad but cannot figure out how to remove the vent knobs, wiper knob... basically all of them. I had to cut through the dash pad material to remove it, but the knobs are still there - don't want to destroy them, just remove them - any help?
Thanks... Allyn
Q-Dog
Q-Dog is offline
PostPosted: Mon May 21, 2012 6:42 am    Post subject: Re: Dash knobs - how to remove Reply with quote
Thanks... Allyn
You didn't HAVE to cut the pad to remove it ... you CHOSE to cut the pad to remove it. Most of the knobs unscrew. The air vent knobs pull off.
Brian
'69 Dune Buggy, http://www.thesamba.com/vw/forum/viewtopic.php?t=419624
'69 Beetle Convertible, http://www.thesamba.com/vw/forum/album_page.php?pic_id=1026416
'70 Beetle, http://www.thesamba.com/vw/forum/viewtopic.php?t=544918
jwold
jwold is offline
PostPosted: Mon May 21, 2012 9:33 am    Post subject: Reply with quote
You need an escutcheon tool to actually remove the switch from the dash, a quick search will find you more info. The knobs just screw off. No need to hack up the dashboard pad, though replacements are available.
Allyn132
Allyn132 is offline
PostPosted: Mon May 21, 2012 10:33 am    Post subject: Thanks! Reply with quote
I deserved the "you idiot" reply. However the dash was literally crumbling so I had already ordered the replacement from Wolfsburg.
OK - screw off or pull off + the "E" tool... thanks!
JerryMCarter1
JerryMCarter1 is offline
PostPosted: Mon May 21, 2012 11:18 am    Post subject: Reply with quote
I think some of them screw off counter clockwise --
Experience always triumphs over hearsay and You get to select which theory to believe
Joel
Joel is offline
PostPosted: Mon May 21, 2012 2:46 pm    Post subject: Reply with quote
Yep, wipers, headlight and hazard unscrew ccw and the 2 vent knobs just pull straight off.
If the headlight switch is old and worn it may just spin and spin so disconnect the battery pull the knob right out so you can stop the spindle turning with needle nose pliers.
You don't need the tool to remove the switch collars though, it helps but needle nose pliers in the 2 slots has never failed me yet.
Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle
jwold
jwold is offline
PostPosted: Mon May 21, 2012 2:59 pm    Post subject: Reply with quote
I think circlip pliers will do the trick as well. Those suckers can get stuck pretty good though.
oda5000
oda5000 is offline
PostPosted: Mon May 21, 2012 4:09 pm    Post subject: Reply with quote
just use small needle nose pliers to get the metal rings off, no need to buy a tool unless you plan on doing it multiple times.
